Question about Kenmore Dryers
Gas dryer turns but wont dry. Fuses seem to have contunuity, element heats up, there is a click and no flame. There was a aprox. 50% blockage of dirt and lint by the blower, but now is clear. Could th
8 yrs. old model # 110.74942300
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
You will need to replace the gas coils. Here is the kit to order.
Below is a video to show you how to make the repair.
Posted on Dec 07, 2012
localwonder
  • 6784 Answers
SOURCE: Kenmore Elite HE3 Gas Dryer - Heat flame will not ignite
The Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
Posted on Jun 20, 2009
milten1
  • 1304 Answers
SOURCE: My Bosch Axxis electric dryer Mod. # WTA3510UC
i would check the actual electrical connections, to both the unit, and the downline connections to that actual element itself, its unusual for an elemnt to only go a lilttle bit... it works or it doesn't...
since you seemed to be very knowlegable, ohm
out the element as well as your plug and outlet
ther emay be a loose connection somewhere
Posted on Oct 13, 2009
tonyhill
  • 50 Answers
SOURCE: Dryer taking too long to dry
If you can get the dryer outside, blow it out from the bottom with compressed air (using an air compressor or even a leaf blower). make sure the vent is clear and has no lint buildup. make sure the burner unit is also lint/dust free. If it is still heating, that is good news, and it is most likely a "breathing" issue. it also could be an issue with your gas pressure, however that is very unlikely. Best wishes in this project.
Posted on Oct 22, 2009
Testimonial: "Thanks Tony! I checked my outside vent and it was badly clogged with lint. Cleared that away and the dryer was immediately back to its old self!"
jsrock516
  • 5911 Answers
SOURCE: WHIRLPOOL LER5644AWO DRYER
If you are experiencing longer dry times and poor drying efficiency, the following link can give you some things to check before assuming you have a malfunction with the dryer:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
The number one cause of dryer heat related problems is poor exhaust ventilation. If the dryer can't breathe it will not dry efficiently and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter as the heating circuits begin to overheat. This can also become a fire hazard if not resolved. Read through the link provided and review some of the potential causes. Hopefully, this may save you a service call.
If you still have problems, please post back and let me know and I can tell you how to troubleshoot your heating circuits and/or assist you with identifying parts. Since your dryer IS heating (but poorly), I don't think you need parts. Just a good cleaning. I hope this helps you.
Posted on Dec 30, 2009
Testimonial: "this comment was very helpful, I had an idea of what was going on but wanted to make sure before i did the work. thank you very much for confirming."
heatman101
  • 43501 Answers
SOURCE: my dryer wont heat
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 06, 2010
THE DRYER WON'T DRY, ITS COLD
Hello there:
If your dryer will not heat up during it's cycle please try the folowing suggestions
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring
Sep 27, 2010 | Dryers
My kenmore dryer runs but not drying and no heat.plz let me know waht i should do?
Hi
If the dryer is not drying the clothes then you would need to check for the following things-
Electric Dryer---
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Gas Dryer---
2. Check for the continuity of the heating element in your gas dryer using a multimeter. Replace the element if continuity is not there.
3. Inspect the thermal fuse if it is burnt out, it is attached to the exhaust duct on the back panel of the gas dryer. Replace if necessary.
4. Check the igniter by first disconnecting it, and then place the probes onto the two contacts of the igniter. The meter should read under 100 Ohms of resistance, if it is above 100 then replace the igniter.
5. Check the continuity on the flame sensor. The sensors are usually located close by the igniter so are easily visible.
Hope this helps...
Daniel
Sep 25, 2010 | Kenmore 63942 Dryer
Dryer has warmth but clothes are not drying. vent is not clogged, temp set at regular,drum is turning What could be the Problem?
Hi
Electric Dryer---
Gas Dryer---
Hope this helps...
Daniel
Sep 25, 2010 | Maytag PYE2300AY Electric Dryer
Doe's not dry, No hot or warm air
Hi
Electric Dryer---
Gas Dryer---
Hope this helps...
Daniel
Sep 24, 2010 | Bosch WTMC1301US Electric Dryer
The dryer is not heating to dry the cloths.
Hi
Electric Dryer---
Gas Dryer---
Hope this helps...
Daniel
Sep 20, 2010 | Dryers
Drier stops drying while clothes are still wet.
Hi
Electric Dryer---
Gas Dryer---
Hope this helps...
Daniel
Sep 20, 2010 | Miele Novotronic T230C Electric Dryer
DRYER WONT START,IT HUMS, MODEL #LNC8760A71
Hi
If the dryer is not turning on or is not drying the clothes then you would need to check for the following things—
Electric Dryer---
Gas Dryer---
Hope this helps...
Daniel
Sep 13, 2010 | Dryers
Appears to be working but not drying clothes
If the dryer is not drying the clothes then you would need to check for the following things—
Electric Dryer---
Gas Dryer---
Hope this helps...
Daniel
Sep 02, 2010 | LG Dryers
Just quit drying clothes
If it does not dry them all then the element is a good guess or the thermostat.
If it dries them but not all the way check that the moisture sensor is not turned down too far.
The following should help you.
How to Repair Heating Elements A dryer sometimes won't heat or heats too slowly because of a variety of reasons. By following the guidelines below, you can inspect the heating elements on a gas or electric dryer to pinpoint the source of the problem.
Troubleshooting the Gas Heater
In a gas dryer, heat is provided by a gas heater that is controlled by an air shutter. The gas heater is generally the source of no-heat or drying problems. You can often correct such problems by adjusting the air shutter on the gas burner, which is located along the bottom of the dryer.
To adjust the shutter, take out the screws and remove the panel that covers the gas flame. Turn on the dryer so the flame is burning. If the flame has a deep blue color and you hear air whistling around the burner, the air/gas mixture is receiving too much air. If the flame has a yellow tip, the mixture is not receiving enough air. Turn the thumbscrew or loosen the two screws slightly to increase or decrease the flow of air to the burner. Keep turning until the flame is a light blue color, without any yellow, and the whistling stops.
Gas dryers use an electric ignition device rather than a pilot light to light the gas heater: An element becomes hot and glows like the filament in a lightbulb. Electric ignition systems are always sealed; you can't adjust or repair them. If an electric ignition device fails, call a professional service person for replacement.
©2006 Publications International, Ltd.
In a gas dryer, heat is provided by a gas heater, controlled by an air shutter.
Electric dryers have self-contained electric heating elements.
Servicing the Electric Heating Elements
Electric heating elements, found in electric dryers, are self-contained units located in the back of the dryer. A defective heating element is frequently the source of no-heat or drying problems. Remove the back service panel to gain access to the elements.
The heating elements are located inside the heater ducts. If you think a heating element is faulty, test it with a volt-ohm-milliammeter (VOM) set to the RX1 scale. Disconnect the leads from the power terminals and clip one probe of the VOM to each terminal. The meter should read about 12 ohms. If the reading is higher than 20 ohms, the heater is faulty and should be replaced. Replace a faulty heater with a new one of the same type and electrical rating. A heater connected to a 115-volt line usually has an 8.4-ohm resistance; a heater connected to a 220-volt line usually has 11 ohms resistance.
The heater may also malfunction because it's grounded. To test for this, set the VOM to the RX1 scale and remove the leads to the heater. Clip one probe of the VOM to a heater terminal and touch the other probe to the heater housing. The meter needle should jump to a fairly high reading. If the needle flicks back and forth at a low reading, the heater is probably grounded and should be replaced. Here's how to replace the heater:
Step 1: Remove the back of the dryer. If necessary, also remove the cabinet top.
Step 2: Disconnect the leads and remove the screws that hold the duct in position. Then lift the entire heater unit out of the dryer.
Step 3: Remove the screws that hold the heating element in the duct.
Step 4: Slip the new heating element into the heating duct the same way the old one came out. Be careful not to damage the resistance coils. Replace the screws that hold the heating element in the duct, reconnect the leads, and screw the unit back into position.
Servicing the Fan
The most common dryer fan problem is lint clogging the air passages through the heater and through the dryer drum. To clear a clogged air passage, remove the back service panel of the dryer and back out the screws holding the air duct in place. Then reach into the duct and remove all the lint and dirt possible. Reassemble the parts.
Also inspect the fan for a loose screw connection where the motor shaft is set on the dryer's drum. Remove the back service panel, tighten the screw, and replace the panel.
May 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Kenmore gas dryer 110.97566200 gas dryer is running throught the cycle but no heat.
Your Heating Elements could have problemA dryer sometimes won't heat or heats too slowly because of a variety of reasons. By following the guidelines below, you can inspect the heating elements on a gas or electric dryer to pinpoint the source of the problem.
Aug 04, 2008 | Kenmore 63942 Dryer
Dryers Logo
52 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
