Question about Toshiba Computers & Internet
Can i just remove the monitor assembly toshiba laptop p5085d-s8935 and just use a n external monitor
Satellite 18.4'' p505d-s8935 want to remove the entire top half of black screen monitor and just use bottom half with external monitor working fine but dead black screen in the way of viewing external monitor
  • dave taylor Dec 08, 2012
    my external monitor works fine...just want to know how to remove dead top half of laptop that is just in the way
  • 47 Answers
You could do that. Here is an excellent guide to replacing that model laptop's lcd which will show you basically how to remove it as well.
http://www.laptopinventory.com/LaptopInventory.php/Toshiba/Satellite/P505D-S8935/LCD
Posted on Dec 07, 2012
Testimonial: "YOU ARE THE GREATEST!"
    looking to actually remove the entire top half of the laptop and discard so that i can see the external Samsung monitor that works just fine. Will the Toshiba laptop work hooked up to the external monitor with the top half of the laptop totally disconnedcted and tossed away?
    Sergeant:
  • 206 Answers
Hi
it depends plug in a external monitor to your vga port and see if it works.
if it works then you have to see when you disconnect the display inverter which is under the plastic cover that runs along the length of you power button and hinges.
if the external monitor still works or not.
if you plug in the external monitor in to the vga port and it dosnt work, you have to check the display inverter to see that its still connected or repalce it
cheers
3 Suggested Answers
perpetually
  • 360 Answers
SOURCE: how to restore a Toshiba Satellite P505D-S8935 PC
Try holding down the "0" (zero) key when you see the Toshiba logo when booting up.
Here is a site with links for your laptop, one of the them will have "your" specific procedure to restore from the "Recovery Partition".
http://www.techsupportforum.com/hardware-support/laptop-support/162525-laptop-recovery-instructions.html#post1450434
Posted on Jun 17, 2010
shibuda
  • 1812 Answers
SOURCE: forgot my cmos password need
It is difficult to reset the BIOS password.Only the reason it is the back door password and locate behind the BIOS chip .
I am giving a link you can try from here there is 50 % chance to reset the password.
Fallow the bellow link.
http://jevarax.wordpress.com/2008/08/08/how-to-clear-your-toshiba-bios-password/
Regard's
Shibuds
Posted on Jan 05, 2011
How to remove top cover toshiba p505d-s8935
The first four minutes of this video demonstrate the steps necessary to remove the LCD. After disconnecting the wires, you should be able to remove the lid as well.
Dec 08, 2012 | Toshiba Computers & Internet
Toshiba satellite p505d s8935 overheats when playing 3d games after about an hour or so. Not every time but often enough to be frustrating. I then have to let it cool off for about 15 minutes and then...
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Sep 19, 2012 | Toshiba Satellite P505D-S8935 Notebook
How do i remove the cd dvd drive
Turn off the Toshiba laptop, remove the AC adapter and any other peripheral devices, and close the lid.
Turn the laptop over.
Touch an unpainted metal surface to discharge any static electricity. Release the battery lock-usually located near the back of the laptop-and remove the battery from its bay.
Remove the screw holding the DVD drive in place.
Where the screw is located depends on your Toshiba's model, but in newer laptops-particularly the Satellite-the screw is located next to the Toshiba sticker.
Unlike the other screws, which are embedded into the laptop, the DVD screw is even with the rest of the laptop's surface.
Gently pull the DVD drive from its bay to remove it from the laptop
hope this helps
Sep 13, 2012 | Toshiba Satellite P505D-S8935 Notebook
Forgot my cmos password need to reset it in my toshiba p505d s8935 laptop
Regard's
Shibuds
Jan 05, 2011 | Toshiba Satellite P505D-S8935 Notebook
How do I change the hinges on my Toshiba P505D?
Remove the four rubber bungs at each corner of the screen cover then remove the four screws.
Luckilly Toshiba have thought about this problem!
If you offer the ninges up to the side of the screen, you will see how it is fixed.
Remove the covers fron the underside and the hard drive unplugs WITH CARE!
Unscrew the suround screws from the base and remove the top cover.
You can leave the keyboard in place.
You will see where the hinges fit to the base.
Replacement is the reverse.
Hope that helps.
Nov 29, 2010 | Toshiba Satellite P505D-S8935 Notebook
How to restore a Toshiba Satellite P505D-S8935 PC Notebook if you miss placed the cd that came with it
Jun 17, 2010 | Toshiba Satellite P505D-S8935 Notebook
Can you upgrade the graphics card on a Toshiba SaTELLITE P505D-S8000 laptop?
Some pc stores claims that they can do it but the cost is high and with a small extra amount of money you can by a new and better one pc. So my suggestion is no and believe me i searched for mines a lot.Hope that helped!
Mar 24, 2010 | Toshiba Satellite P505D-S8935 Notebook
I need a manual for my Satellite computer--model # P5050 S8936
Your model number is wrong. It is P505D-S8936.
The -S8935 should be the right one. Double check.
Paste this link as all one line in your browser:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2351123&rpn=PSPF0U&modelFilter=P505D-S8935&selCategory=3&selFamily=1073768663
(Hint: Copy and paste into notepad, make it all one line, then copy it to your browser)
Mar 19, 2010 | Toshiba Satellite P505D-S8935 Notebook
Computers & Internet Logo
115 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
