I have a 36'olevia HDTV.......it has a detachable power cord and it also has a power switch in back. When I plugged it into the wall,turned on the power switch, and pressed the power button, I got no
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
The light is likely the standby light if it is on when set is off and goes out when set turned on or changes color when set comes on.
The fact the light is on should rule OUT the main fuse for the set, most likely the problem is the power supply itself inside the set
The Standby supply is part of the main power supply and when set is plugged in and off it runs 7/24.
Have you had problems where the set was "hard to turn on" or you had to try to turn it on several times before it would stay on?
Posted on Dec 07, 2012
Siliconchip
  • 52 Answers
SOURCE: Olevia LT42HVi - Need to toggle power switch on back of TV off/on all the time
You swapped the power strip. How about swapping the cord with another. Most LCD and Plasma TV used a cord similar to the cord use for the power supply of PC (IEC line plug). If still it doesn't work. Time to open the back to access the connector terminal which came loose (Due to heat) if not soldered directly to the power supply PCB. Just pinch the spade crimp, better still solder it. Make sure to lay the TV flat, face down on a smooth surface table if you're repairing it yourself.
Good Luck.
Posted on Dec 29, 2007
SOURCE: Power issue with Olevia LT23
this is bull do...The same thing happens with my TV I Have the Olevia 23" and the power will not turn on.
$700 shot, who cares about the rebate when it works on a short while...
Posted on Nov 24, 2008
SOURCE: Olevia LT26HVE Power issues?
Finally recieved an email from syntax olevia customer support after 1 month. a standard desktop computer power cord is all you need for your Olevia LT26HVE flat screen. We lost ours in a move and FINALLY have it up and running again...for only 9 bucks at RadioShack!
Posted on Dec 13, 2008
SOURCE: Power on problem for My Syntax Olevia LCD TV 23"
I have a 24" Olevia LCD TV. Same symptoms (Stdby LED is on, press power and it flashes off, then back on). The USB cable to the Service Port also worked. But being of sound technical mind, I figured this means that the PC is supplying the +5v to the circuit. What I did was disassebled the TV, carefully disconnected all the cables, and opened it up to reveal the circuitry. I looked over the circuit and noticed the 1000uf/16v capacitor at position CS21 was failed and bulging. I removed the cap, tested it and verified that it was indeed failed. I went to a local Radio Shack and picked up a 1000uf/35v electrolytic, after all, the value is what mainly matters as long as it's not lower voltage than the original. I replaced the new CS21 capacitor back in the circuit (it is polarity sensitive, so pay attention to what the original mounting position is). I reassembled the TV and Viola! Works! No need for the USB cable to the Service Port!
I hope this helps someone!
-Matt
Posted on May 18, 2009
SOURCE: Olevia Hi Def tv 242TFHD, won't turn on. Power
yes the capacitors your looking for are a 1000uf , 1500 uf , and on the other side of the heatsink a 680 uf. the tops will be slightly bowled. replace those with same type !not brand!, and youll be happy.(same thing happened to me, less than 2 years old also).
Posted on Dec 04, 2009
Tv come with no sound or pict.
Check whether the product is turned on.
Try another channel. The problem may be with the broadcast.
Is the power cord inserted into wall power outlet?
Check your antenna direction and/or location.
Test the wall power outlet, plug another product's power cord into the outlet where the product's power cord was plugged in.
If these tips don't work, you can also try to power cycle the TV. Turn the TV off and unplug it for about a minute. Plug it back in and power it back on to reset the settings back to factory default.
Oct 18, 2013 | LG 32LG30 32 in. LCD HDTV
My Olevia 37" LCD HDTV suddenly will not turn on.
power supply board is damaged,only working with standby power
Aug 15, 2011 | Olevia LT37HVS 37 in. LCD HDTV
My TV will shut off for no reason while it is playing. Is there a reason for this?
I have had the same problem. There is a switch on the back of the tv near the power supply outlet. Try turning the switch and wait a few minutes then turn the switch back on or you can detach the power cord for a few minutes and turn it back on. This has happened to me for the last year and that would work but now it is happening and I can't get it to come back on at all. Anyone have any ideas?????
Dec 15, 2010 | Olevia 237T 37 in. LCD TV
I HAVE AN OLEVIA HDTV MODEL 232513 IT DOESN'T TURN ON
Check the power source?Have power to the tv at all?Power LED light incation flashes?Yes?That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 21, 2010 | Olevia LT27HVX 27 in. LCD Television
I have an olevia tv model number 542-13-11 and it will not turn on. Any suggestions would be appreciated. lindafranks@hammondhenry.com
do you get a blue light on ? if you do that means you have power so..it could be the main-board is bad on the television. But if you have no blue light on the front of the television then you have no power. You could try switching the power switch on the back of the television several times and see if you get any type of blue light on the front of the tv. If you don't then try connecting the power cord to a power strip or straight to the wall.. if you still don't get power try disconnecting the power cord from the television overnight and then plug it back in and see if you get any sign of power.. if still no sign of power then the television power supply is bad and will need to be replace or repair..
Since the manuf. of OLEVIA is out of buss ..you have this 3rd party repair center that is able to provide you with a repair quote call this number 866-965-3842 the company is called Amergence Technology who is able to repair and service all OLEVIA HDTV products..
Jul 21, 2009 | Olevia LT42HVi 42 in. LCD Television
I have a Hayden SuperVac 3600, almost 10 years old. The unit still runs, but now when I switch to the power nozzle, it doesn't have power to turn that. I think this happened once before and maybe they...
The hose has fuseable link inside, generally a 3-7 amp. It is at the wall end underneath the hose cuff. Easy to replace as it crimps in line. If you have a meter you can also test the detachable hose to wall cord for continuity, then check the hose to handle as well.
You can also detach the hose to wall cord from the hose, and plug your power head directly into that cord,, then into the wall thereby eliminating the hose itself.
Hayden makes a serviceable hose. If damaged or the fuse blown it can be serviced by a good tech. If the fuse is blown you need to clean and inspect the power head as this may be the cause
Jun 20, 2009 | Hayden Industries SuperVac 6000 Central...
How do i install an xbox360?
Plug the power unit into to the back. Plug the AV cable to the back of the TV (match the colors) and the back of the Xbox. You'll either use the red/white/yellow if you have a regular tv, or the red/green/blue if you have an HDTV. Then switch the switch on the AV cable to the right setting (HDMI/HDTV or regular TV). Install the AA alkaline batteries in the controller (or the battery pack if you got the rechargeable battery kit). Plug the power cord into the power unit, then last plug the power cord into the wall. Wait a minute for the power unit to light up and then push the big green Xbox button in the middle of the controller down for three seconds and let it go. It should turn on. If not, find someone local to help you. This is all stuff covered in detail in the owners manual.
Jan 01, 2008 | Microsoft Xbox 360 Console
Good Luck.
Dec 21, 2007 | Olevia LT42HVi 42 in. LCD Television
Power problems
I have a 32'' olevia 232v hdtv. I had a similar problem where the tv stays on less and less as you use it longer and it gets warmer. I called customer service and they explained that its most likely a problem with it is doesnt have enough power to run well. They said turn the TV off, then hit the master turn off switch in the lower back of the tv, then unplug everything from the TV, then unplug everything from the wall. Then after 3 or 4 hours, plug all back in and try again. Then they said if i still have a problem, call customer service at 1 866 9 olevia
Sep 29, 2007 | Olevia LT37HVS 37 in. LCD HDTV
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Electro Med Services...
