Question about GE (PSS26MSRSS) Side by Side Refrigerator
Freezer not freezing and refrigerator not cold
I have a GE side by side refrigerator. It's model GSH25SGRBSS. I have frost on the back panel of the refrigerator and my fridge is not cold at all to where I have to store my parishiable in the freezer to keep them from spoiling. In other words I have to use my freezer as my refrigerator. Can anyone help?
  • nadams25 Jan 12, 2009
    It's not clogged because that was the first thing I checked and cleaned and there was little to no dust on it. i just took the freezer panel off in the inside and it frozen over. Lettng it defrost now so I hope that will fix it. I know it may be a temporary fix but why is it not defrosting?
    Master:
  • 623 Answers
The most common problem is the condenser under the refrigerator is clogged with lint. Pull the unit away from the wall for clearance,tip it rearward, and have someone use a vaccum on the dust. Unplug the unit while working on it and remove what can slide around be careful not to damage the works underneath, as dirt is the whole problem.................. Get it clean as you can and reset to factory settings and leave it alone for 24 hours.
The FACT THAT IT IS STILL FREEZING MEANS THE WORKS ARE OK.!
If it still doesn't work correctly, you need freon added by aservice man, but I think cleaning is all you will need.
Posted on Jan 12, 2009
GE refrigerator isn't cold at all
you need to have the frig defrost the passage is in the back going from the frig to the freezer so if it is frosted in the back than the air is not moving correctly
Sep 18, 2012 | GE Refrigerators
I have a model GSS20DBMD side by side model,It has frost on the back of the freezer and the temp is not cold enough to freeze water in that section, also, the refrigerator side is not cold enough . the...
You must replace the defrost heater and defrost thermostat inside the freezer. Remove the shelves and bins,then remove the rear panel of the freezer to access the parts.
Sep 08, 2009 | GE Refrigerators
I have a Kenmore Cold Spot fridge, freezer on top. Fridge is warm, and freezer keeps freezing up on sides and bottom. I cleaned it all out, defrosted it, and it still freezes up and fridge still won't get...
Is this a self defrost model? Frost inside the freezer could be an air leak around the door gasket. Remove the back panel in the freezer and completely defrost the coils. Is the fan running in the freezer. That will make the frig not be cool. With the door closed peek in the gasket to make sure the light is shutting off, this will warm a frig also.
Eric
Jun 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE refrig side by side 7-8 yrs old will not freeze frig not cold
Generally, This would be a sealed system problem. An inefficient compressor or low refrigerant. If you notice a build up of frost on the freezer panel it might be a defrost problem, but, I am leaning towards an inefficient compressor.
Jun 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Refrigerator Not Cooling (TFX27ZPBGWW)
The unit isnt defrosting hence the ice on the back panel. Either your bimetal thermostat is open or the heating element is shot. Most GEs they come together so happy hunting. Those parts are behind the frosting panel
May 28, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
Freezer cold but things not frozen -frosting up. Fridge warm.
most of the time on ge its the defrost heater or defrost sensor in the freezer,that's why its freezing up.you can go to sears .com click on prats put in your modeal number and get yours parts-mike
Nov 30, 2008 | GE GTH18KBR Top Freezer Refrigerator
Amana side by side does not freeze nor does it get cold
first check you freezer back for frost if a lot of frost defrost the whole freezer ,,, then plug back in and see if it will work..
let me know
Jul 05, 2008 | Amana SXD524VW Side by Side Refrigerator
Ge side by side not cold enough in fridge or freezer
if there is no frost build up in freezer section sounds like a refrigerant leak
Apr 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
226 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
