Question about John Deere Seat 4210 4310 4410 4510 4610 4710 Tractor
I need a john deere fuse box diagram for 4710 tractor
wireguy212
  • 1627 Answers
SOURCE: ELECTRICAL PROBLEM
Can't get you a diagram but i can tell you most electical problems on these tractors can be solved by replaceing the key switch/modual or cleaning corrosion from fuse holders.
Posted on Nov 10, 2009
blueextc3221
  • 15935 Answers
SOURCE: system creeps down even when tractor is operating.
There are 2 potential problems -
1. Leaking spool on the control valve - rebuild the vale.
2. Cylinder blow-by. Disassemble piston and replace the seals.
To test if its the cylinder - retract the cylinders all the way... remove the hoses on the blind end (non rod end) of each cylinder, and again pull the valve to the retract position.
If fluid continues to pour out of the cylinder - the piston seal is damaged, and the affected cylinder must be repaired.
To test if the valve spool is faulty - disconnect the a and b ports just after the valve. Turn on the system and check for seepage from the disconnected lines (without moving the lever).
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Apr 19, 2009
wilsodfarm
  • 986 Answers
SOURCE: 3020 carburetor ? john deere gas tractor, 3020
those carbs are real simple you will not have any problem
Posted on Jul 29, 2009
rwvanlue
  • 486 Answers
SOURCE: I have a John deere 317 tractor that does not start.
We will be testing for voltage to the points, coil, engine to tractor wiring harness, ignition switch
Tools needed:
volt meter to read 12 volts, or test light
1) with the points open: is there voltage at the connection wire at the points
If yes; adjust points to .020" and try to crank engine and check for spark
*** you may want to determine if condensor is connected to this wire also
if no
2) check point side (neg or - ) of coil for voltage
if yes, engine should start
if no
3) check for voltage at the + side of coil
If yes, coil is bad
if no
4) check wire connector from engine to frame wiring harness
if yes; engine should start
if no
5) check wiring on the back of ignition switch
if no
6) check that ignition switch RED or BATTERY supply wire has voltage
if yes; switch is bad
if no
7) check supply wire and circuit breaker connected to the battery side of the solenoid
if no; circuit breaker could be at fault or wire connector at battery supply
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Nov 08, 2009
wireguy212
  • 1627 Answers
SOURCE: i need a wiring diagram for a john deere 4500
What are you trying to repair?What on the tractor is not working?Copy right laws prevent me from posting the diagrams but i can help you with your problem,i have access to the diagrams you need so let me know what you need.
Posted on Jan 21, 2010
JOHN DEERE COMPACT TRACTOR 4710 RECEIVS NO POWER TO FUEL SHUTOFF SELENOID OR INJECTION PUMP BUT WORKS IF JUMPED FROM STARTER DIRCTLY
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Sep 09, 2016 | John Deere Garden
Does a john deere 4710 tractor with a ehydro transmission have a neutral switch and if it does where is it loacted
Best Manuals
Jul 19, 2016 | John Deere Garden
Err 68 what it means and how too fix no fule too motor
Err 68 means
Err 68 Hold-in Relay ON. Output from the Display is short circuit. No fuel to the engine. Contact your John Deere dealer
Aug 24, 2014 | Cover My Tractor Tractor Cab-Enclosure for...
Fuse box diagram/ turn signal does not work
Go to johndeere.com, they will have the diagram you are looking for.
Mar 03, 2014 | John Deere Seat 4210 4310 4410 4510 4610...
Where are the transmission drain plugs on a john deere 2020 tractor
It is located on the bottom of the transmission reservoir, and that is 1 foot to the right from the battery.
Oct 21, 2013 | John Deere Seat 4210 4310 4410 4510 4610...
Does john deere 4710 have a fuse for fuel pump?
Not sure most dont there operated off vacumn or some have a plunger rod .If it has a wire going to it it is . Just not sure on that model pull the fuel line off the side going to the carb and see if any fuel is going thru it when you turn the engine over.
Dec 07, 2012 | John Deere Garden
John Deere indicator code
Call your JD dealer they should help you it could be as simple as a light bulb out.
Oct 22, 2011 | John Deere Seat 4210 4310 4410 4510 4610...
Where is the drain plug for the transmission on the john deere 4210 tractor
There should be a pipe type plug in the bottom of the transmission housing near the draw bar inline with the rear axle housings. Whether you have a hydrostatic drive or gear drive, the plug is in the same place. Reference # six in drawing.
Feb 16, 2011 | John Deere Seat 4210 4310 4410 4510 4610...
John Deere Seat 4210 4310 4410 4510 4610 4710 Tractor Logo
816 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
