Question about Cherokee CBS-500 (40 Channels) 2-Way Radio
Sqeel in tramission when mike is keyed
Station recieving signal complaint ofsqeel in my transmission.
  • Cherokee Master
  • 1,654 Answers
Check your antenna connections. This type of feedback is many times caused by a bad connection or an antenna which is mismatched to the radio.
Best regards.
Posted on Dec 08, 2012
What kind of oil go's in Tramission stander 5
In the transmission dipstick are the required type, its ATF+4,
Mar 17, 2012 | 2000 Jeep Cherokee
Model: PGX2L5644-662MHz. Its causing a loud sound as if its lost or is loosing frequency even if I am standing with the mic close to the reciever. The ready light comes on and also the signal light when I...
Reset the channel/group on both the mike and the reciever. Shure reuses frequencies by groups so if the group is different, but the channel is the same then you aren't on the same actual frequency.
There should be an auto-set option on the recievers display as well as the mike. Turn them both on, and then just hold the mike up to the reciever so that the little IR window can see the reciever and the 2 with sync together.
If they are both on the same group and channel then turn the mike off, and adjust the squelch control until static is heard, then turn it back until it just goes away.
Feb 28, 2011 | Shure LX2 / Beta58 Microphone
How to fix fm japan radio to recieve GCC fm signals ?
You can get a converter like this one.
http://catronics.com.au/fmconverter.html
It's a simple solution and it works.
Jan 18, 2011 | 1998 BMW 5 Series
Trying to hook up converter box to Westinghouse flat screen the converter is magnavox sdtv. I get autoscan but no channels are found. I do not have an antennae. Do I need one? Help!
If ur tv a LCD tv it is a digital tv.U do not require a Digital converter box to get the new DTV free air signal broadcasting tv channels stations.But u do require a good digital antenna for it to recieve a long an strong signals to recieve a DTV free air broadcasting tv channels stations.
Dec 07, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Reciever powers up and recieves signal (station and song titles are displayed) but doesn't transmit to car radio either through the assigned fm station or the aux cord.
IF you have a cord plugged into the audio jack, if will TURN OFF your FM transmitter. You have to leave it unplugged for the FM transmitter to work. Go to MENU and make sure your FM station is set and that the FM OUTput signal is turned up. Write back if you need more help.
Thanks,
John
Aug 19, 2009 | Delphi Roady2 SA10085 XM Radio Receiver...
Is the 09 aveo5 manual tramission towable
no problem as long the transmission is in neutral ans the emergency brake off..hope this was very helpful..thanks
Aug 07, 2009 | 2008 Chevrolet Aveo5
Finding the tramission fluid dip stick on a 1995 mazda
CAR MAY HAVE SO-CALLED "LIFETIME"
TRANSMISSION FLUID.THEREFORE, THERE IS
NO DIPSTICK. TRY TO FIND SERVICE INFO ON
THE WEB OR GO TO A MECHANIC YOU CAN
TRUST. I HAVE THE SAME THING ON MY 2000
LAND ROVER, BUT WE CAN CHECK THE TRANNY FLUID FROM UNDERNEATH.
Jun 19, 2009 | Fluidmaster INC #B1F30 30" Faucet...
Superstar 3900 with no USB or LSB on receive.
most likely been fiddled with and out of alignment. If you have a freq counter and a volt meter you could possibly fix it yourself. look at cbtricks.com for the aligment procedure.
Jun 13, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Tramission automatic mazda 626 97
Not a solution, but definitely bad news.
Unfortunately, your symptoms are all too typical of 1997 626's with the automatic transmission, especially those with the V6 engines. Owners have been reporting OD lights flashing and hard shifting as early as 20,000 miles, and total transmission failure as early as 40,000-60,000.
There are also many reports of owners having the transmissions rebuilt only to have them fail again in 12,000 to 20,000 miles.
This transmission, actually a Ford CD4E, was installed in many mid to late 90's Mazda's. NHTSA has over two hundred complaints on the 1997 626 alone.
Conversely, Mazda used a 5 speed manual transmission of their own design in these same model year 626's, and it is not unusual for them to go well beyond 200,000 miles without so much as a hiccup.
There are many Mazda forums out there over the years where people have attempted to launch a class-action lawsuit against Mazda to force them to announce a recall for the automatic transmission.
Mazda North America Operations claims that there were never enough complaints lodged with them to justify a recall. It appears they managed to avoid recall by instructing their delears to tell customers these symptoms were "typical of Mazda transmissions" and to document these concerns as complaints.
Unfortunately, once you start experiencing the type of problems you have, you can only expect it to get worse. If it's any consolation, it's nothing that you have done to the car, or could have been prevented, its poor design and ECM programming. Don't let a dealer or transmission shop try to tell you differently.
Try Googling, "1997 Mazda Transmission Complaints", and you'll get sick over the number of hits you get.
Here's a link to an article that's sure to get your blood boiling:
http://www.associatedcontent.com/article/23810/before_you_buy_that_used_mazda_626.html?cat=27
Jan 11, 2009 | 1997 Mazda 626
Cherokee CBS-500 (40 Channels) 2-Way Radio Logo
Top Cherokee Radio Communications Experts
ka4iup
ka4iup
eradiostore
eradiostore
Caitlin Romagna
Caitlin Romagna
Level 1 Expert
Are you a Cherokee Radio Communication Expert? Answer questions, earn points and help others
