Question about Jack Lalanne Power Juicer 250 Watts
How to clean juicer
I just received a jack lalanne power juicer without the owners manual, how do I clean the juicer!!!! Help
  • 24 more comments
  • TB1963 Nov 09, 2007
    Hi I have the same problem I just bought it and i do have a manual which isnt much help. I cant even figure out how to take the top part the filter and the blade off the base so that I can clean it before i use it
  • Anonymous Feb 07, 2008
    How do you remove the screen so that you can clean it?
  • Dianne Noeline Sharp Feb 12, 2008
    CANT DISMANTLE BASE FROM UPPER SECTION WHERE BLADES ARE
  • geverest Feb 14, 2008
    same problem here
  • Anonymous Feb 17, 2008
    I receiver the Jack Lalanne Power Juicer and the instruction manual was not included. How to I dismantle the juicer in order to clean it?
  • MARILLI Mar 17, 2008
    CAN'T TAKE THE JUICER APART TO CLEAN IT.
  • Anonymous Mar 21, 2008
    How do I take my power juicer apart tp cleanit.
  • chefv Apr 18, 2008
    howw do you clean juicer
  • ttammster Apr 26, 2008
    how do you take it apart to clean it
  • wildcfh May 04, 2008
    dont know how to take the screen out or off the juicer to clean it. jack lalanne power juicer. i dont have the owner guide. please help
  • Anonymous May 06, 2008
    I have the answer. I just used my Jack Juicer for the 1st time. There was no manual, but included was an orange handled tool. You insert the tool into the 2 holes opposite each other located at the bottom of the wire mesh. Turn the basket counterclockwise while holding the tool. Shirl
  • Anonymous May 26, 2008
    I use my jack lalanne power juicer an i need clean up please
  • Anonymous Jun 15, 2008
    don't know how to clean it
  • Anonymous Jun 17, 2008
    You can download the manual (pdf) from http://www.powerjuicer.com/pdf/classic.p...
    Cheers
    Eddy
  • duppy Jul 09, 2008
    how do you take it apart to clean it?
  • pamdebease Jul 12, 2008
    I don't have the "tool" that is mentioned to take apart the juicer. CAn it be done without it? I used a screwdriver to take off the blade, but I can't disassemble the rest. Help!
  • Anonymous Jul 14, 2008
    how do you take the juicer apart for cleaning
  • Anonymous Aug 10, 2008
    Cant get the rest taken apart to clean.
    dont know how to clean
  • nancyfesta86 Aug 14, 2008
    i do not have the tool or the guide...how can i take the screen out for cleaning?
  • chebasanae Aug 21, 2008
    i dont know how to clean power jucer
  • Anonymous Aug 31, 2008
    I purchased a jack lalanne juicer from a garage sale I don"t know how to really clean it
  • Anonymous Sep 01, 2008
    The top part how do i take off to clean?
  • bumblebuzz Sep 10, 2008
    I do not know how to take it apart to clean it. I unscrwed the grinder but can't get the top off.
  • Anonymous Feb 05, 2009
    how do i clean a juicer
  • Anonymous Mar 23, 2014
    How do I register my Black and Decker Juicer?
I had the same problem and figured out an easy way to open it without the tool. DO NOT take out the screws. I simply used chop sticks. I put one in each small hole and held the chop sticks in an X and turned the top counterclockwise!
Posted on Jul 01, 2008
  • 4 Answers
You can donwnload a manual (pdf) from http://www.powerjuicer.com/pdf/classic.pdf
Or you can view a video - Power Juicer Assembly, by following this link http://www.powerjuicer.com/customer-manuals-video1.html
Eddy
PS - the video is shown for the Deluxe model but same procedures apply to the Classic
Posted on Jun 17, 2008
My juicer did not come with a manual but it did come w/ two tools. One is a brush to clean the blade and filter and the other is a tool to remove the blade from the base. The tool to remove the blade is a small half-moon shaped handle w/ two pegs that fit into the two holes in the blade. If you insert the tool into the holes, hold the outer rim of the filter in place and turn the blade counter clockwise, it will come right out. I don't use the brush because I just put all of these things in the dishwasher.
Posted on Nov 07, 2007
Ok, same situaition here. What we are asking is, how do you clean the portion under the metal grater, where all the juice goes? Does this get cleaned? Do you have to take the 3 little screws out? If someone would be kind enough to scan and post the user manual somewhere that would be fantastic! Post the location on this forum.
Thanks!
Paul
Posted on Oct 24, 2007
  • wilcotech Oct 24, 2007
    Ok, figured it out. I went ahead and took the 3 little screws out and noticed that you can unscrew the entire blade assembly without taking those screws out. But you need the right tool. Notice the 2 little holes in the blade, you need to stick something in them (I just stuck my screwdriver in one of them) and turn the blade counterclockwise while holding the rim of the metal mesh deal. It should losen up and you can take it all the way apart from there to clean the insides, which definately need cleaning. Good luck.
    Paul
We can Fix your problem.
There is a Piece that came with your power juicer. It looks like an "ORANGE-Slice"
with two small-metal pieces sticking out from each end. These two metal pieces
fit perfectly in the two holes seen on the face of the grinder.
Hold the edges and twist left the grinder, lifts up, the orange rimmed strainer lifts up
as does the white nossel-piece. WALA.... wash...... dry ......replace pieces. Enjoy!
from,
The -Figure it out- Fairy
Posted on May 14, 2009
You pull the metal thigy away from the spout until it swings away, then you can disassemble it.
Posted on Sep 30, 2007
  • 1 more comment
  • KosteonLink Sep 30, 2007
    The metal "thigy"=The metal bar that curves over the whole thing.
    ___|_|____
    | ] / } <- pulp container
    |_]___|<--}--- top section
    spout< ]<--|---}--- Metal bar thing
    | L | }
    |_^___|___}
    pull this TOWARDS, Sorry about previous post, the spout.
    Final Comment
I justh had the same problem and watched the video at the link given and it was very helpful. i did not have the manual or the tool to take off the blade so i grabbed to writing pens and gently turned the blade counterclockwise and wow! it worked! good luck and thanks for the help everyone!
Posted on Apr 22, 2009
  • 3 Answers
Http://www.powerjuicer.com/pdf/classic.pdf
Posted on Dec 12, 2008
Very easy and simple to remove the blade. You just need to insert something into the two holes on the blade to be able to turn it - anything strong that will fit into those two holes, so you can turn the blade. I use two metal kebab skewers, and one time used the handle of my son's plastic paint brushes! Insert into two holes on top of blade, turn counterclockwise to loosen, then remove blade. Remove filter basket, then the receptacle. There is a demonstration on YouTube how to clean Power Juicer: http://www.youtube.com/watch?v=fDJkOPt5SPk
Posted on Nov 03, 2010
I just take it apart and run it under water and scrub the parts clean. I think you can put them in the dishwasher but I don't, I just clean and put it away as soon as I am finished with it.
Posted on Jun 11, 2007
  • susan wagner Jun 12, 2007
    You can also look the manual up online and print it out.
Hi, I was having the same trouble, on how to take the basket filter thing out, I tried to unscrew them but it didn't work, so don't unscrew it and put in something that will fit in one hole, in my case I used a thin scissors I had.... Hold the basket so it won't spin, and turn it clockwise... It wasn't working at first because it was so tight, so if ur doing the same and won't turn then it's because it's really tight and you just have to use force... To loosen it up, and then u can take all the pieces out and wash them, except the bottom part ( the motor) just wipe clean....;) Good luck...
Posted on Oct 19, 2012
When i turn my unit on I get no power
Posted on May 23, 2009
Posted on Apr 13, 2009
Okay, Suewags23, your answer to the problem was not helpful in any way. I think Nappy1 was asking HOW TO TAKE IT APART TO CLEAN. I am having the same problem. Love the way the product after using for the first time, but mine did not come with a manual either. Oh, and again, Suewags23, your second little tip did not help either. I've been googling "manuals" for the product for half an hour now, and this post is the best it can come up with. I am assuming that nobody in their right mind would build a machine for conveinience and then make you use a screw driver to take apart and clean. There has to be a way to take the top portion off of the base, but I cannot figure out how. Is there a part you have to click? Turn it a certain way?? I've tried pulling and twisting at the same time, etc... it won't come off. Anybody know how to take the top portion off?
Posted on Aug 30, 2007
I have a Jack La Lanne juicer and cannot take it apart
There is a step-by-step video on Youtube - this should help ...
This link should get you there, or just Google Jack LaLanne Juicer and you should see a couple of youtube links.
Jack LaLanne Power Juicer Elite Cleaning
Jun 14, 2015 | Jack Lalanne Power Juicer 250 Watts
Hi, I don't have the manual and I'm having a hard
Jack Lalanne Juicer Manual
http://www.myeasypics.com/is.php?i=665112&img=1.jpg
http://www.myeasypics.com/is.php?i=665113&img=2.jpg
http://www.myeasypics.com/is.php?i=665114&img=3.jpg
http://www.myeasypics.com/is.php?i=665115&img=4.jpg
I hope this helps.
Dec 04, 2009 | Jack Lalanne Power Juicer (Stainless...
Need owners manual...can't figure out how to take apart for cleaning...a used gift from kids..help
I hope this helps.
Nov 23, 2009 | Jack Lalanne Power Juicer 250 Watts
Jack LaLanne power juicer
I hope this helps.
Nov 12, 2009 | Juicers
Need to take apart to clean ,cant find manual
If yours is the "express" you can download it off a website. Google search, "Jack LaLanne's Power Juicer OWNER'S MANUAL."
My model was different and needed this stupid little "crescent wrench." Not a normal crescent wrench, but a crescent moon shaped handle with two little knob things sticking out that fit into the two holes in the top of the blade. It screwed counter-clockwise until parts all came out for cleaning.
(hint: I never toss my owner's manual, but I couldn't find it anywhere until I saw on the box that it said it came with a recipe book. I went to my recipe book cabinet, and there was the owner's manual - in the recipe book.)
Good luck.
Nov 01, 2009 | Jack Lalanne Power Juicer 250 Watts
Need an instruction manual for Jack Lalanne Power Juicer?
This picture looks like the Jack LaLanne's Power Juicer "Express." You can google search "owner's manual" for it and download it.
Good luck.
Oct 30, 2009 | Jack Lalanne Power Juicer 250 Watts
Open to clean juicer maching
http://www.powerjuicer.com/customer-manuals.html
This is the site to download Jack Lalanne's Power Juicer Manuals of all models which include troubleshooting guide, user instructions, cleaning and opening machine.
Jul 13, 2009 | Jack Lalanne Power Juicer (Stainless...
I don't know how to take it apart to clean it.
This is the site to download Manuals for all models of Jack Lalanne's Power Juicers. This includes trouble shooting guide, Instructions on cleaning ect...
Apr 08, 2009 | Jack Lalanne Power Juicer (Stainless...
Jack Lalanne Power Juicer 250 Watts Logo
14,806 people viewed this question
Top Jack Lalanne Juicers Experts
Greg Cann
Greg Cann
Starnley Johnwells
Starnley Johnwells
Are you a Jack Lalanne Juicer Expert? Answer questions, earn points and help others
