Question about Lenovo G585 Laptop
Lenovo Easy Cam Shows Green Screen when using Skype
When I'm using the camera with all others apps everything is fine. When I made a video call in skype, my video is green. Also in skype video options I see the video green. The OS is Win8.
    Sergeant:
  • 206 Answers
Hi
you have to google the problem and see if anyone else has that issue and how they resolved it.
it sounds like there is a compatibility issue with the Skype software and your windows i would delete and reinstall Skype or try a different version of skype.
i know over the last 10 years a lot of laptops have had ssues with the earler skype software.
cheers
Posted on Dec 07, 2012
  • Luciano Cagnana Dec 10, 2012
    I've read also some support questions at the Skype support center. There are a lot of computers of various brands with the some problem. The Skype expert said that probably is a problem beetwen Windows8 and Skype. In the next days ( friday 7 december he said 5 days), will be released a new skype version with the green screen problem solved. I will keep informed
4 Suggested Answers
furlough5
  • 28 Answers
SOURCE: WEB CAM OF LENOVO Y510 IS nt working in skype
Try pressing the "Fn" and "esc" buttons on the keyboard both at the same time to turn the camera on or off. It may work or may not, but that is the way it is supposed to work. There have been a lot of problems with this web cam and yahoo messenger. The only other thing I can suggest is to contact Lenovo and see if they might have another driver that can resolve this.
Posted on Aug 22, 2009
LASITHA-VEGA
  • 428 Answers
SOURCE: when usinf my webcam with skype.it shows an upside
Go to Skype>Tools>Options>Video Settings>Webcam Settings
Select Flip Vertical
Please rate the answer if it helps you to solve the problem. Thanks for contacting Fixya!
Posted on May 29, 2010
afghandude01
  • 115 Answers
SOURCE: skype-lenovo easy capture not supported new drive
yeah a new drive is required you can get cheap ones from like office works and computer stores... goodluck
Posted on Jun 06, 2010
I just brought a he Sharper Image M18A" Tablet. Can anyone tell me if you can use Skype - as in see the other person. I know it's to do with the cameras on the tablet but when I brought this I wa
If you don't see the person you are chatting with on Skype, the issue is probably on their hardware. You do need to "Enable Video Call" from the Skype app's Menu after initiating a video call. If you aren't seen on the other party's side of the call, then it's your device settings that must be adjusted.
Does your tablet have a front-facing camera and Android version 2.3 or better? (The M18A is listed as having Android 4.0) If so, then you should be able to video chat with the Skype app. When you use the rear-facing camera, obviously there are issues with the other party seeing you.
If you have a front-facing camera, make sure that this is the default camera while the Skype app is closed. Open the default camera app and tap the icon to toggle the front camera interface (if needed). Then switch to video mode. Return to the home screen and open the Skype app. Login and start a video call. Then press Menu (in the app) and "Enable Video Call".
If this doesn't work, you may need the IP Webcam app. This is available at the Play Store. After setting the default camera, set the resolution and the frame capture rate, among other settings. Next, follow the directions for using Skype for a video call.
I hope this helps.
Nov 28, 2017 | Tablets & eReaders
I have a lenovo g460e.... yhe first time i use the loptop the built in camera was working..... but after 1 week i connot uuse my cam untill nw i hofe i can fine a solution of my problem of my lenovo. tenk...
Please try to use the camera using different applications like yahoo messenger, skype or Lenovo Youcam. If non of them works with the camera follow the instructions below.
Please try Fn+Esc. This function allows you to enable or disable the built-in camera for Lenovo Laptops. There should be a small camera symbol that would appear on the lower right corner of the screen. If the camera symbol has " \ " on it, it means the camera is disable but if not it means its enable.
Check if the camera is seen on the device manager and check it properties. Make sure the camera's status is "Device is working properly". If not download the driver from the link below.
http://consumersupport.lenovo.com/sg/en/DriversDownLoads/Drivers_Show_895.html
Follow up questions:
Whats is your OS?
Thank you!
Jul 11, 2011 | Lenovo 3000 Y410 Laptop
Hi Am not able to get my lenovo Y510 webcam connected to skype or yaho messenger or gmail or anythin of that sort.... The webcam works fine (lenovo easy capture). I've tried installing the driver...
Hi sonypony,
I see that you are having issue with using the camera on your Lenovo with other programs such as Skyp or Yahoo Messenger and so on...
On your Lenovo the camera works with easy capture, that is a good sign saying that your camera works but how to make it work on other applications you will need to get in the applications settings and select the Lenovo Camera as a default device for that specific application that you are using to utilize the camera.
all the applications you mentioned earlier has thier own settings page and this is where you can set each to make the Lenovo Camera the default deivce for it to work on your applications.
I hope that this will help you with your Camera concern.
Have a nice day,
mvincentc
Apr 25, 2011 | Lenovo IdeaPad Y510 Notebook
Hello. My name is Florina Pop and I am using a Lenovo Ideapad Y560 laptop with Cyberlink YouCam 3 installed.The web cam is incorporated on the laptop.I bought the laptop with all the basic software...
I don't think its your webcam that is at fault. I think it's already in skype. I have the same Lenovo model and there are times skype doesn't transmit video. So, I usually do is turn on and turn off the skype video call for the video to reappear. Can you do the following:
1) Make sure you have adequate lighting. Sometimes if you are in a dark room, skype will also transmit black videos to the other end.
2) Have you checked the video settings in skype? Go to Tools->Options. Click video settings. Click webcam settings and try to tweak your video from there.
Feb 09, 2011 | CyberLink YouCam
My web cam pleomax pwc 4200 don't work with skype
Dear friend, if other side does not have a cam or does not put the cam on mode
for you then your not able to view them. Some time other side camera window will
open in your Skype but you can't see the image. May be you seen black screen or
green. It will happens for the few reason.
1. Slow internet connection,
2. wireless net connection,
3. if the other side camera open for other messenger , for exam Yahoo/msn & at the
same time she/he sending you a cam viewing invitation in Skype , that time you will
see those screens.
4. After log in go in Privacy then Calls & then open video settings.
7d387c6.jpg Now you set the Automatically receive video from mode & try after that to use.
Thanks & waiting for your feedback.
_______________________
Mar 20, 2010 | Computers & Internet
I have Logitech notebook pro webcam, when on skype my picture shows abut nd the other person can hear me just fine but I cannot receive video from the other party but can hear them also.. Any...
Dear friend, if other side does not have a cam or does not put the cam on mode for you then your not able to view them. Some time other side camera window will open in your Skype but you can't see the image. May be you seen black screen or green. It will happens for the few reason. 1. Slow internet connection, 2. wireless net connection, 3. if the other side camera open for other messenger , for exam Yahoo/msn & at the same time she/he sending you a cam viewing invitation in Skype , that time you will see those screens. 4. After log in go in Privacy then Calls & then open video settings. Now you set the Automatically receive video from mode & try after that to use.
Feb 08, 2010 | Logitech Webcam
I have audio and video but my friend only has audio when we are using our web cam. Is the problem on my end or their end? This is the first time I've tried to use our webcam ( SKYPE) . It is a logitech...
logitech.com ... I've checked out their website before and had no luck with solving my webcam problems... BUT this time I found their website very helpful. I just had to follow a few of their very easy steps and my webcam problems were solved!
Jan 09, 2010 | Logitech Webcam
Lenovo G585 Laptop Logo
1,405 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
