Question about Car Audio & Video
I have a new DEH 4500bt and no output to speakers. checked wiring 3 times all good. spekers operate with a 9v pulse but no output from unit. what am I missing?
ampman
  • 98 Answers
SOURCE: Reconnecting Deh - P3000
HI. search pioneer no sound on this board. i have already walked another guy through this... if everythng works but no sound is outputted.. 99 times out of 100 the audio output ic "chip" is bad. Its a common failure for pioneer cd players as well as others. The part is about $20 if you know where to look... if you decide to repair this yourself you will need to be very skilled with solder and desoldering braid... let me know
Posted on Sep 08, 2007
james klgr
  • 362 Answers
SOURCE: Pioneer DEH-P2600
blue and white wire on a pioneer is usually the power antenna wire, most people use it as the lead for power to turn on the amp that is installed, the amp should be hooked up to the RCA jacks on the back of the player to the input RCA jacks on the amp. then the outputs vary, some amps are bridgable which means that you can hook up one speaker to both output speakers this will almost double the watts to the speakers. you must know which side would be positive and which side negative to set it up like this. also important is it a two or four channel amp. this all matters. if you can provide more info I can assure you the best hookup possible for premium sound.
Posted on Dec 12, 2007
SOURCE: Pioneer deh-p520 super tuner 3
Black, red, gray and white (for the front speakers only).
Black: Ground
Red: VCC
Gray: Speaker
White: Speaker.
Remember to isolate any unused cable like the blue (remote), green and purple (rear speaker).
Posted on Feb 15, 2008
SOURCE: Wiring 6 X 9 Speakers
hi,
i m Ritesh Upadhyay , there is no sound driver in my computer.
so i want to download it.
Posted on Feb 18, 2008
blueextc3221
  • 15935 Answers
SOURCE: pioneer dehp3100ub.stock speakers wont work with unit?
If the vehicle has a premium sound package - you need to use the remote wire to turn on the factiry amplifier.
If you want to use the power from the radio for the speakers, you must buy and install a factory amplifier bypass harness.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Posted on Jul 19, 2009
Why can't I hear the called party when using blue tooth
there is a second volume for calls on the pioneer unit, i had the same issue with mine. when someone calls turn up the volume it should be on the call volume not the radio. hope this helps.
Apr 26, 2014 | Car Audio & Video
Car Audio
Swap wires between speakers and to make sure it is not the amp, the head unit or wiring. If the right speaker still doesn't work touch a 9v battery to the speaker terminals for a second to verify if the speaker is good or bad (a pop the speaker is working nothing the speaker is bad)replace. Otherwise check the wiring between the amp and the head unit. If all the wiring is good you may have a bad channel in your amp(bad internal connection or bad component(s)) or last there could be a bad channel output on your head unit. If that is your only right speaker and you don't have one in the door and you use an ipod as a source check the cord!
Jul 04, 2013 | Car Audio & Video
Pioneer DEH-P4550 wont produce sound
If you can, the first thing you need to do is check all of your speakers and speaker wires for shorts and/or grounds. You will need a multimeter/ohmmeter to do this. If the speakers and speaker wires check out good, you may have a bad output ic inside of the deck.
Mar 30, 2013 | Car Audio & Video
I have a pioneer deh-p3700mp DC reiciever. It was working fine. I turned it on and no sound. I did find one speaker wire came loose. I reconneted it. No sound comes out of any speaker. It appears to...
if the loose speaker wire touched ground it may have blown the output ic. also make sure you have no other loose or shorted wires as this will cause the output not to work.
Oct 25, 2010 | Pioneer DEH-P3700MP CD Player
Having trouble wiring the new head unit to the stock wires. I have a wiring kit.
ON HEAD UNIT
YELLOW IS THE MEMORY FROM IGNITION
RED CONSTENT LIVE FOR SWITCHED/POWER
BLACK GROUND/EARTH
BLUE AUX POWER OUT
SPEAKERS PAIRED BY COLOUR.
USE TEST LAMP TO FIND OUT WHICH IS IN CAR TO MATCH HEAD
9V BATTERY TO FIND WHICH SPEAKER TO LOCATE SPEAKER BUZZS ON CONTACT WITH BATTERY
Dec 06, 2009 | Pioneer Premier DEH-P510UB Car CD/ MP3...
Pioneer DEH-P2900MP head unit
There is no power from the rca jacks. Option 1; connect the speaker wires directly. Any aftermarket auto manual (Hayes, Clymer) with wiring schematics will let you know what wire is what in the dash. Option 2; RCA jacks output to an amplifier. There is no power coming from the RCA jacks. They have to be used with the amp. If you chose to use the normal speaker wires, be aware that these radios do not like stock speakers or wire. If you take the time and money to replace all of it, the head unit will last much longer. If you choose to use an amplifier, it will burn out fast unless you replace the speakers and wires immediately.
Mar 04, 2008 | Pioneer DEH-P2900MP CD Receiver...
Wiring problem for DEH 1430R
I have to ask if you are willing to spend a little time with the 30 wire bundle? First of all you have to have a 12volt dc tester and a 9v dc battery. Take the tester and check each wire of the 30 wire bundle until you find one with 12 volt. Mark it and set aside. If you get more than one with voltage that is OK just mark them w/tape and make sure they get capped or taped as not to short anywhere. Now that you know which wires are HOT, lets move onto the others.If possible find out how many speakers are in the vehicle. Take the 9v battery and find small gauge wires in the bundle of 30 remove insullation on the wires about 1/2 inch touch one wire to one post on the battery and another to the other post (Just a tap, do not hold on too long) you will hear a speaker pop. Find out which it is front left, back right etc. and mark the pairs that make it pop. If possible to pull the speaker you can identify the wire colors from the speaker to see if they are in fact in the 30 wire bundle. After you locate your power and speakers the 15 wire harness should be easy to attach to the proper connections. Hope this gets you going.
Jan 15, 2008 | Pioneer DEH-1430R CD Player
Pioneer DEH-P2600
Dec 11, 2007 | Pioneer DEH-P6900UB CD Player
No output from the left front speaker
using your flashlight bulb in one hand, hold the speaker wires to the bulb and then gradually increase the volume. If the bulb lights, the Pioneer is good.
Jun 08, 2007 | Pioneer DEH-P3500 CD Player
Car Audio & Video Logo
109 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
