Question about Watches
The time is in 24 hour format not 12 - Watches
  • 47 Answers
1. Press and hold MODE for 2 seconds and then release. The watch will be in alarm mode.
2. Press mode again to enter time mode adjust.
3. Press the stop button to cycle through what you want to adjust. (In this case changing to 12H v. 24H)
4. Press the reset button to adjust the actual item.
5. Press MODE to exit time setting mode.
Posted on Dec 07, 2012
  • 29 Answers
SOURCE: How do I get my Timex WR50M watch out of the 24 hour (military) time and back to a 12 hour clock?
Hold down the adjust button bottom right then press the mode button top left you will notice the a or p that stands for am/pm will disappear & reappear. If you have an a or p on your display then you are out of military time.
Posted on Mar 12, 2008
SOURCE: Timex Indiglo WR 30M
NOTE: 12/24 HOUR TIME IS SELECTED BY PRESSING RESET/LIGHT ONLY WHEN THE HOURS MARKER IS
FLASHING. THE “A” OR “P” WILL DISAPPEAR WHEN THE
WATCH IS SET TO 24-HOUR TIME.
Posted on Mar 13, 2008
cmcduncand
  • 714 Answers
SOURCE: how to change from 24 hour to 12 hour on g shock
http://world.casio.com/wat/download/en/manual/
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Posted on Feb 19, 2010
SOURCE: How do I change my Casio twin sensor alti thermo
Press and hold the top left button for 2 seconds to go into the time adjustment mode.
While you are in this mode press the top right button to switch between 12 hour and 24 hour modes.
Press top left to return to normal.
Posted on Feb 21, 2010
SOURCE: cannot change from 24 hour to 12 hour
To change from 24 hour to 12 hour, you hold down the "Mode" button until it switches from 24 hour to 12 hour or vice versa. To change the time zone, you hold down the "Set" button until the time zone that you set it in flashes (like "LAX" on my watch). Then you press the "Receive/Start/Stop" button to choose the specified time zone you want. To set for daylight savings time ("DST" on the watch), after holding the "Set" button and having the time zone flash, you could press the "Mode" button. It will give you a few options for the daylight savings time (Auto, On, or Off). I chose the "On" option, which immediately changed for daylight savings time. If you manually want to change the time, you could hold down the "Set" button and keep pressing the "Mode" button until the time starts flashing on your watch, then pressing the "Receive/Start/Stop" button until you change it to the time that you want. You could also set the watch to beep or chime after pressing the set button if you wanted to know that piece. You hold down the "Set" button when you are done to get it to stop flashing. These instructions worked for my Timex T5G341 Universal Radio Control Watch. I hope this helps.
Posted on Mar 14, 2010
How do I change from 12 hour format to 24 hour format ?
In mobile u can go to setting>date and time> there is is boxx showing time format uncheck the box to 12 hour format
Thanks...
Jul 04, 2016 | Watches
How to go from military time to standard time for the armitron M721 watch?
just change your time format settings from 24-hour format to 12-hour format.
Jun 28, 2014 | Armitron Watches
Steel Leopard Shark watch manual
To set the hour format, press S1 button
to toggle between 12-hour and 24-hour
format. The P.M. indicator may be
displayed to indicate the time period
12:00 A.M. - 11:59 P.M. in 12-hour
format.
11.To set the calendar format, press S1
button to toggle between M-D (monthdate)
and D-M (date-month) format.
12.After finished making all the settings,
press S2 button to confirm...
Dec 25, 2013 | Watches
12 hours early
Try this:-
First set the watch to 24 hour format rather than 12 hour format.
Nov 05, 2013 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Timex 1440 sport indiglo 50m convert from 24 hour clock to 12 hour clock.
There are several models of your watch not all of which appear to have a 12/24 hour display format.
Try this extract from a manual; press the MODE button six times to enter the 12/24 adjusting setting and then use the START/STOP or SPLIT/RESET button to change the time.
Press the mode button to return to normal operation.
Dec 06, 2010 | Watches
How to adjust the time on a CASIO W-59 watch
Hi Harry,
Your Module number is 2271.
1. To set the time, press and hold button A (left top) until Seconds digits start to flash.
2. Press button D (lower left) to move flashing in the following sequence to change other setting:
Seconds >> Hour >> Minutes >> 12/24 Hour Format >> Year >> Month >> Day >> (Then back to Seconds)
3. While a setting is flashing, use E (+) (bottom right) and B (-) (top right) to change it.
Note: When in the 12/24 Hour Mode, use E and B to toggle between 12-Hour and 24-Hour Mode.
4. Press buton A to exit setting screen.
Your time should now be set.
You may also download a manual for watch/Module number:
http://pathfinder.casio.com/resource/manuals/module_2271.pdf
This should give you all the info you need to operate all the functions of your watch. Thanks.
Regards, Bill
Sep 27, 2010 | Watches
How do I change my Casio twin sensor alti thermo watch from 24 hour to 12 hour format?
Oct 09, 2009 | Casio Watches
How do I set watch as a 24 hour mode clock ?
With TIME displayed, press and hold ADJUST, then press MODE to switch between 12- and
24-hour format.
Nov 02, 2008 | Timex 1440 Nylon watch
Roxy 80' W056DR
Possibly, you could push the hour-setting button through either the military or standard time setting, i.e., there are actually 48 "hours" you can set your watch to and you need to cycle through enough of them to reach the standard or military hour you want.
Apr 11, 2008 | Timex 1440 Nylon watch
Mar 10, 2008 | Timex 27191 Wristwatch
Watches Logo
53 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
