Question about Nike Mettle WC0038 Press Wrist Watch for Men
What battery does a Nike WC0038 watch use?
Want to make sure the battery in the watch is the correct one.
What brand of battery comes in an old school Nike Cuff ladies Watch?
Of course you can as long as they are the correct number .
Feb 04, 2016 | Nike Watches
I need to change the time on my nike wk0006 watch, but nike doesn,t sell it anymore...WHAT DO I DO!!!!????
TRY!
Make sure the watch is facing the correct way. Put the watch on your wrist as you normally would, or pick it up by the strap with your left hand. You should see that the Nike swoosh is right side up. You should be able to read the time.
Find the left side of the watch. This will be your left when the watch is facing you correctly the same way that you would look at it to read the time. You will see at least two buttons. One will be labeled "mode" and the other will be labeled "set."
Press the "mode" button. Press the "mode" button. Continue to press the "mode" button until you have scrolled through the options and are on the correct setting. The correct setting should be "time."
Hold down the "set" button. You should see the currently set time on your watch and the hour should be flashing. You should see a plus sign (+) and a minus sign (-). If your current time says three (for example) and you want to read five, press the button that corresponds with the plus sign. If you want to go backwards, press the button that corresponds to the minus sign. When you are finished hit next.
Change the minutes. Now the minutes should be flashing. Repeat step four: press the button that corresponds with the plus sign to increase the minutes. Press the button that corresponds to the minus sign to decrease the minutes. Hit "next" when you are finished.
Hit "done." Congratulations, you have now successfully set the time on your Nike watch. Now your watch should read the correct time. If you want to get really crazy, you can repeat the steps above to change the date on your Nike watch.
Sep 28, 2014 | Nike Triax WK0006-001 Watch
I need bracelet for nike model wc0038, where can i buy?
www.shopzilla.com/watches/nike...wc0038/.../products - United States click this link
Sep 17, 2011 | Watches
I have a Triax Speed 50 Nike watch and the local jewelry store would not change the battery because the possibilty of damaging the wrist band that needs to be removed. Any instructions on how I can change...
You can't change it yourself without doing damage. You will need to send into Nike or more accurately an authorized nike watch repair center that is close to you hopefully.
Nike customer service or a google search for authorized nike watch repair in XXX-city will get one close to you.
Dec 27, 2010 | Nike Timing Triax V10 Watch
Battery is gone (I think) and regular watch repair places don't fix it (need a special tool to open it)
does it have a slot on the back ? usually Nike watches are made to easily replace the battery usually with a nickle slot on the back or screws on the corners. The batteries they have are usually common 2806 or similar coin sized batteries. It will say on the back of the battery .
Most jewelry or watch repair shops can easily replace these batteries. if you bought the watch within a year , have receipt and something is broken. You can send it back to nike to be repair for free. It is done by parsec located here http://www.nikewatchrepair.com/.
Oct 14, 2010 | Nike WC0021 001 Mettle Hammer watch
How do you change the battery?
Thank you for contacting FIxYa.
I would read the NIKE support site before deciding to do any battery changes on your own. As a retail jeweler/watch service tech I would HIGHLY recommend you doing what they suggest:
http://www.nike.com/timing/
Best regards. Jewel
Sep 02, 2010 | Nike WC0021 001 Mettle Hammer watch
What kind of battery
Can you take the battery out? Do you have access to opening? Your best bet with this kind of watch is to take to a qualified watch service. Usually under $15 for the battery and installation and they have the correct tools to do it.
Aug 09, 2010 | Nike Oregon WA0023-013 Wrist Watch
Need help replacing battery in my nike Imara Womens watch? Which way does battery go in with plastic cradle?
1. Use a coin turn the battery hatch one-quarter turn counter-clockwise
2. Remove old battery from compartment. Keep plastic cradle and replate with 395/SW927R battery. Replace the new battery positive side facing up in the plastic cradle into the metal compartment in the watch. Ensure all three little tabs line up and twist cradle to lock into place. Make sure the O-ring is in proper placement on the cover and replace the battery hatch ensuring it is sealed completely!
Jan 28, 2010 | Nike Imara Run WR0075-014 Wrist Watch
Light turned off, can't get it to turn back on
There are more tha one version of your watch, so you need to go to the Nike web site to be sure that you have the correct instructions.
From what I can make out, the backlight comes on when the upper left hand button is pressed. The light will turn off after a short while, to preserve the battery
To get a copy of the instructions, go to the web site "Niketiming.com. "
Select you language and region.
On the left of the screen there is a box with a drop down menu for manuals. Choose yours and download.
Jan 17, 2010 | Nike Anvil Comold Super Deep Burgundy/Team...
NO ALT,WEATHER DISPLAY
Dreco,
I was changing my battery and ran into a small problem, too. I know where one spring goes, but I have another similar spring that may have fallen out of the watch (I was working on another different watch before, so I'm not sure if the 2nd spring belongs in the watch). One spring contacts the small speaker on the metal cover and will not affect the LCD display.
How many springs do you see in yours, if any?
Dec 07, 2007 | Nike ACG Ascent WA0008 wristwatch
Nike Mettle WC0038 Press Wrist Watch for Men Logo
91 people viewed this question
Top Nike Watches Experts
Ansel Alberto
Ansel Alberto
TIME TRACK SERVICES
TIME TRACK SERVICES
Are you a Nike Watch Expert? Answer questions, earn points and help others
