Question about Dryers
Dryer will not turn on and stay on.
My whirlpool dryer starting yesterday evening has this problem. I can push the start button and the motor starts, however as soon as I release the button the dryer stops. I have checked the door and made sure it is clear. the dryer will tumble as long as the button is held down but stops as soon as the button is released. I have held the button down for a while and noticed that it is not getting hot. Is this a problem with the switch or the element?
  • 242 Answers
Hello , bad news here , when you press the start button it sends power to the motor and then a clutch sets in and closes a set of points that then sends power to your element -if the clutch does not engage the motor will not continue to run or send power to the element and that is what is happening to your dryer.
not an easy fix at all , the clutch is bad and its located inside the motor and the entire motor would need replaced to repair this problem. they range from 80-100 dollars and would take about 1-2 hours to change.
let me know if you have any other questions.
Phil
Posted on Jan 12, 2009
My dryer wont stay on if I push the start button it turns on and heats up but once I let go of the button it sits of rite away.
what's the brand name and model number,if it's a kenmore or whirlpool and says even heat with the lint filter inside most likely a bad even heat computer board or the motor relay both are up in the top console,if it's a g.e. you have a broken belt switch,there's a switch down next to the motor and belt pulley,it's just a cherry switch,it has a button that sticks out of the switch that hits the belt pulley,if the belt breaks then the dryer will only run when the start button is pushed in but the switch can break causing the same problem,also on the newer whirlpool it also can be a broken belt,good luck with your dryer
http://fixitnow.com/wp/2009/03/17/easy-fixes-for-two-common-problems-with-the-whirlpool-even-heat-dryers/
Nov 10, 2013 | Dryers
When i push and hold the start button the timer light flashes but it doesn't start. the interior light stays on even when the door is closed. door switch maybe???
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 09, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool Super Capacity Dryer Front Loader 7kg : Drum does not want to tumble after push-button start. I opened the door and held the door switch in position as if door was closed. Then turn the drum into...
The motor is going bad...
heatman101
Aug 24, 2010 | Whirlpool Dryers
Whirlpool ultimate care ii dryer will not stay on when start is pressed
if you push the start button an as soon as you let go of the start button your dry stop you need a new motor
Apr 24, 2010 | Whirlpool LER4634J Electric Dryer
My kenmore gas dryer will not stay on when I push the start button. It starts but as soon as I release the button it stops
That my friend is a bad motor, (motor start relay i should say but you have to change the whole thing). The start relay is gone. any more questions call me on your Whirlpool Dryer Parts. visit the site and grab a motor i can help you on the repair best i can no cost!
Apr 15, 2009 | Whirlpool LEQ8000JQ Electric Dryer
Dryer drum wont start spinning after pushing the start button
the problem is with the start winding on your dryer motor.it is centrifical switch,so if a lint build up gets in that motor switch area it stays on the run winding.pop the top .remove the frount.pull drum.vacume motor out if then starts on own great.other wise you need new motor.parts about 100$God bless,tom
Jan 02, 2009 | Whirlpool ET8CHEXSQ Dryer
Whirlpool dryer will not stay on, no heat, and timer acts weird
sounds like the motor or the even heat board is out i would say the even heat board is more likely
Dec 09, 2008 | Kenmore 62602 Electric Dryer
Dryer won't start
The start windings in your motor have gone out. To fix this you must replace the motor.
Justin Duby
T and N appliance Repair
Dec 08, 2008 | Kenmore 63942 Dryer
Dryers Logo
223 people viewed this question
Top Dryers Experts
