Question about Casio FX-115ES Scientific Calculator
How to use pol ? - Casio FX-115ES Scientific Calculator
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Casio Master
  • 102,366 Answers
The Pol function converts coordinates from rectangular to polar. Pol(x,y) converts the rectangular coordinates (x,y) to polar coordinates (r, theta).
For examples and instructions, see page E-37 of the manual and example #036 in the Appendix.
Posted on Dec 07, 2012
Problem with casio 991 es
In the COMP mode (press MODE 1 to get there), press
SHIFT [Pol] (-) . 1 7 SHIFT [,] (-) . 4 7 =
[Pol] is on the "+" key, [,] is on the ")" key.
Dec 04, 2012 | Casio FX991ES Scientific Calculator
I need to convert the rectngular form to polar form , so how can i do that ?
In Run screen, Press OPTN, Press F6> repeatedly until you see the ANGL TAB. Press F6> again (once or twice). You will see the TAB Pol( and Rec(
To convert from Rectangular coordinates to Polar press POL(, type in the x and y coordinates then EXE
Example: F1: Pol(1,1) gives (1.314213562, 45)
F2: Rec(square root (2), 45) gives (1,1)
Make sure the angle unit is set to the one you need (degree or radian).
Apr 19, 2012 | Casio Algebra FX 2.0 Calculator
Just purchased the home and the handle on the moen 4551 cp is loose. The handle actually falls off the fixture. There is a plastic grommet or washer that is broken. How do I replace this plastic grommet...
You can find the parts diagram here: http://www.moen.com/monticello/chrome-two-handle-low-arc-bathroom-faucet/_/R-CONSUMER%3A4551 . The washer kit is part number 97274. The lever and the hub and elbow that the handle connects to depend on the finish and whether you need the hot or cold side replaced. Levers: 97557 Chrome 97558 Pol. Brass, hub and elbow: Cold 100552 Chrome, 100552P Pol. Brass; Hot 100553 Chrome, 100553P Pol. Brass.
You may be able to find the washer at a local hardware store (like Ace or Tru-Value). Alternatively, call Moen or visit the Moen site. 1-800-BUY-MOEN or http://www.moen.com/replacement-parts/product?product=IMGLIB:CA84437BN to order replacement parts.
You'll have to pay for the washer kit. However, if the hub and elbow or the lever are damaged, call Moen and see if they will replace it under warranty.
I hope this helps.
Mar 08, 2011 | Moen 4551___ Monticello Popular Two Handle...
Pol xlt running lean on pto side. I changed all
I would jet the lean side up one jet size if the sled is running extremely lean. You can also adjust the needle up if you can without having to increase jet sizes.
Feb 05, 2010 | Polaris New Genuine Polaris Snowmobile...
How do you use the pol and rec
To avoid errors make sure that the angle unit is THE ONE required by your problem. To verify or to change the angle unit press [SIFT][MODE] and select [3: Deg] for degrees, [4:Rad] for radians, or [5:Grad] for grads.
Convert from rectangular to polar
[SHIFT][+] (Pol) . Screen displays Pol(
You enter the X-coordinate, and the Y coordinate separated by a comma, then you close the parenthesis and press [=].
Exemple: Polar coordinate of the point (1,1)
Pol( 1, 1) gives
r=1.414213562 (square root of 2)
θ=45
Here is how you enter it
Press [SHIFT][MODE][2:LineIO]
[SHIFT][POL] 1 [SHIF] [,] 1 [)] [=]
The screen displays
Pol(1,1)
r= 1.414213562
θ= 45
Convert from polar to rectangular coordinates
Rec ( radius, angle) =
Exemple: Recatngular coordinates of (r=3, θ=60°)
[SHIFT][Rec] 3 [SHIFT][,] 60 [ ) ] [=]
The screen displays
Rec(3,60)
X= 1.5
Y= 2.598076211
Jan 19, 2010 | Casio FX-115ES Scientific Calculator
Can you show how to convert pola to rectangular o
Pol( 1, 1) gives
θ=45
The screen displays
Pol(1,1)
r= 1.414213562
θ= 45
The screen displays
Rec(3,60)
X= 1.5
Y= 2.598076211
Hope it helps.
Nov 14, 2009 | Casio FX-115ES Scientific Calculator
How to convert polar to rectangular form
Press [MODE] and select [1:COMP]
Press [SHIFT][MODE] and select [3:Deg]. You can also use rad if the angle you are given is in radians.
To start the conversion
Press [SHIFT][-] (Rec) screen displays Rec(
Key in the radius r , ex: 3 screen displays Rec(3
Press [SHIFT][)] (,) to enter comma separator Rec(3,
Key in the angle in degrees, ex: 57.3; screen displays Rec(3,57.3
Press ) to close parentheses; screen displays Rec(3, 57.3)
Press [=]
Screen displays
Rec(3, 57.3)
X=1.620720961
Y=2.524532346
X and Y are the values of the coordinates.
If angle is in radians, [SHIFT] [MODE][4:Rad] the command
Rec(3, Pi) gives X=-3, Y=0
Hope it helps
Oct 18, 2009 | Casio FX-115ES Scientific Calculator
Can't get a flame
Unscrew the fitting off the tank and make sure there isn't an extra washer in there. Sometimes when you get a tank there will be a washer inside it that has slid of the last guys POL(screw in hickey) With this extra washer, the POL isn't going in far enough to open the tank valve.
Sep 08, 2009 | Weber Summit E-620 Gas Grill
BC72XLT
You can't add to the preprogrammed search functions, but you can program frequencies from these bands into any locations you wish within the 100 programmable channels, where it will jump bands while scanning.
Sep 29, 2008 | Uniden BC72XLT Handheld Scanner
Casio FX-115ES Scientific Calculator Logo
199 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
