Question about Cosmi Championship Mah Jongg for Windows
Can I instal lMahJongg on windows 7? - Cosmi Championship Mah Jongg for Windows
How to Fix Error Code 0xc0000005 while Installation of Windows 7 Installation
Just put this into google or windows and follow the instructions.
Oct 26, 2017 | Computers & Internet
How do I uninstall XP Professional and install Windows 7
If you have a Windows 7 installation disk, just put the disk in your drive and follow the instructions......it will remove your XP and install a fresh Windows 7
Oct 21, 2014 | Computers & Internet
Is adobe photoshop elements 3 compatible with windows 7
I want to mention that Photoshop Elements 3 is not tested with the Windows 7.
If you have a windows 7 64 bit operating System then it may not even install in it. If you have a 32 bit Operating System then you can try to install it. However it may still not work even on a Windows 7 32 bit Operation System as it was not made and tested for this Operating System.
There is a probability that if you install the Windows XP mode on you Windows 7 operating system then it may work.
Check more about installing Windows XP mode here:
http://windows.microsoft.com/en-IN/windows7/install-and-use-windows-xp-mode-in-windows-7 Install and use Windows XP Mode in Windows 7
Regards
Anand
Aug 30, 2014 | Computers & Internet
Aspire4736zg
The Windows 7 product installation code is supplied when you purchase the Windows 7 OS software.
If Windows 7 is already installed on your computer, the product installation code is on the Windows label that is attached to your computer.
If you cannot activate the Windows 7 operating system and you get a message that this is NOT a Genuine Windows installation and you have the Windows 7 label then you need to contact Microsoft to as for help to activate your Windows 7 license.
Apr 30, 2013 | Computers & Internet
I have want to setup Windows xp and windows 7 together .Meaning when start up computer have : Windows xp Windows 7 I try to setup two windows ,but i setup windows xp lost windows 7 and setup windows 7...
Not sure what you have done so far. You need to divide your hard drive into two sections. Install XP first on to one section. Then use a program to manage your computer start up, the one I use is called Easy BCD this is a free program and works great. Once you cut your hard drive and install XP make a copy of your start up partition. Install the Easy BCD program and make a back up again. Then Install Win 7. Then on the Win7 side install the Easy BDC program and set up the menu choices. I run a 3 way boot with XP and Ubuntu. Hope this helps Fix Ya up.
Jul 09, 2011 | Computers & Internet
Can i install windows-xp on my laptop which is currently working on windows-7 and use both of them.
Yes you can install windows xp in windows 7.
Windows XP Mode is a virtual PC image of Windows XP Service Pack 3 that could be run on Windows 7 Professional, Enterprise or Ultimate versions. Applications installed into Windows XP Mode could be run in Desktop Mode or Seamless Mode. In Seamless Mode, applications appear to run natively within Windows 7, but they are actually running inside the Windows XP virtual machine. Windows XP Mode might also provide additional integration that traditional Virtual PC images might not be giving. Applications installed on the Windows XP image could be exposed to the Windows 7 Start menu. Applications run in seamless mode is having automatic access to the Windows 7 known folders like Documents, Pictures, Desktop, Music, etc. Also the Cut-and-paste is enabled between native Windows 7 applications and those running in Windows XP Mode. Applications running in Windows XP Mode might also access your Windows 7 network connection and USB devices.
Nov 30, 2010 | Computers & Internet
Can i convert a 32 bit to a 64 bit
You can use the Upgrade option during Windows 7 installation, which preserves your files, settings, and programs, only if you're currently running a 32-bit version of Windows Vista and you want to upgrade to the 32-bit version of Windows 7. Similarly, if you are running a 64-bit version of Windows Vista, you can only perform an upgrade to a 64-bit version of Windows 7. For more information, go to Upgrading to Windows 7: frequently asked questions on the Windows website.
If you want to move from a 32-bit version of Windows to a 64-bit version of Windows 7 or vice versa, you'll need to back up your files and choose the Custom option during Windows 7 installation. Then, you'll need to restore your files and reinstall your programs. For more information about performing a custom installation, see Installing and reinstalling Windows 7‍.
gl_ico.png Notes
  • To install a 64-bit version of Windows 7 on a computer running a 32-bit version of Windows, you'll need to start, or boot, your computer using a 64-bit Windows 7 installation disc or files.
  • If you start your computer using a 64-bit Windows 7 installation disc or files, but your computer isn't capable of running a 64-bit version of Windows, you'll see a Windows Boot Manager error. You'll need to use a 32-bit Windows 7 installation disc or files instead.
  • Windows Easy Transfer can't transfer files from a 64-bit version of Windows to a 32-bit version of Windows. If you're running a 64-bit version of Windows Vista but you plan to install a 32-bit version of Windows 7, you can move your files to an external location manually or use Backup and Restore in Windows Vista. For more information, go to Back up your files and
Apr 08, 2010 | Dell Precision Workstation 490 - MT -...
Drivers
I will recommend that you download and run the free Windows 7 Upgrade Advisor. It helps find issues with your computer’s hardware, devices that might affect installing Windows 7. Go to the Windows 7 Compatibility Center find direct links to drivers, updates, and downloads.
Apr 04, 2010 | Toshiba Satellite A300-ST6511 Notebook
I would like to scratch-install the new WINDOWS 7 on the TOSHIBA P105-S6114. Is this okay? Are there any problems I may encounter?
ecommended Windows 7 Installation Method SelectionToshiba provides support for installing Windows 7 on laptops built since 2007. Depending on your model, Toshiba recommends using one of the following software tools as part of the Windows 7 installation process, to support ongoing use of Toshiba provided features and functionality:
  • Toshiba Upgrade Assistant for Windows 7, for upgrading from Windows Vista to Windows 7 on laptops made in 2009
  • Toshiba Software Installer for Windows 7, for performing a Custom Installation of Windows 7 ("clean install") on laptops made 2007-2009
Find your laptop's serial number on a sticker on the bottom of the laptop, note the second character in that serial number, then click on the matching link in the list below for instructions on Toshiba's recommended Windows 7 installation method for your model.
For all laptops made since January 1, 2007*
When upgrading from Windows Vista (not a Custom or "clean" Install)
  • if the second character of your laptop's serial number is 7 or 8, click here.
  • if the second character of your laptop's serial number is 9, click here.
When upgrading from Windows XP, or doing a Custom Install ("clean install") from any operating system
  • if the second character of your laptop's serial number is 7, 8, or 9, click here.
  • if the second character of your laptop's serial number is not 7, 8, or 9 then it was manufactured prior to 2007.*
* Installation of Windows 7 is not supported by Toshiba for laptops made prior to 2007.
Hope it helped.
Nov 21, 2009 | Toshiba Satellite p105-S6114 Notebook
Cosmi Championship Mah Jongg for Windows Logo
Top Cosmi Video Game Consoles & Games Experts
Michael Vincent Cruz
ray gallant
Carlos L. Burgos
Carlos L. Burgos
Are you a Cosmi Video Game Console and Game Expert? Answer questions, earn points and help others
