Work has updated to new computers, i have one of them a phillips computer without the tower,where can i get one from please..
Im guessing it is an older model why work wants to upgrade
  • 7,627 Answers
The tower is the computer? You have a monitor? I'm confused? Try ebay.
Posted on Dec 09, 2012
Poormanspc
  • 24 Answers
SOURCE: Monitor connection problem....
Check your battery in your computer, it should read 3Volts, if it don't you need to replace it. If it is fine, then your monitor don't work.
Posted on Mar 16, 2008
SOURCE: philips iqon recovery cd
http://global.msi.com.tw/index.php?f...=170&cat3_no=2
Posted on May 11, 2008
  • 12 Answers
SOURCE: I NEED YOUR HELP
Pls go to Microsoft web site to update the media player
http://www.microsoft.com/windows/windowsmedia/player/10/default.aspx
Thank you
thewho1
Posted on Aug 03, 2008
Scott Ellin
  • 558 Answers
SOURCE: Computer Tower
Have you try to run PC in safe mode?
Please reboot your computer in Safe Mode by doing the following:
To go into Safe mode -- Press F8 key as soon as the PC restarts.
(You will have do again if PC starts in normal mode.)
On the black screen >>> Safe Mode With Networking(for internet Access).
On the login screen, please select Administrator as a USER to login.
Press 'YES' when you get the safe mode warning.
Posted on Nov 07, 2008
SOURCE: My computer HP DX2300 Mini
is it not booting up at all? Is there any indication such as blinking LED or Beep sound?
Posted on Jun 15, 2011
Im Kulie from the NHTL Ive been struggling to get an email where you send an application for the leasing of lands for cellphone towers in Rural areas
well thats good money for someone
Zimbabwe at a guess
try online search for the government department
in your part of the world traditional land owners
or lands or communication sections that handle tower placement
Apr 06, 2017 | The Computers & Internet
My computer will not start, the power button lights up the the lights on the front panel will not come on so I cannot get it started.
Well It sounds like the computer is getting power, so that's good news.however, the CPU is the brain of the computer and without it unfortunately it will not work, but I don't think your CPU is the problem. With the new windows update I had this happen to me also. You can try holding down alt+f4 when you power on your computer. A blue screen should appear and give you options to troubleshoot. You will need to retrieve your files from a previous update which will take a few minutes. If that does not work then you may need to take your PC into a repair shop.
Mar 17, 2015 | Acer Aspire Desktop Computer - Intel Core...
Work is updating desk top computers, i was fortunate to get one,its a phillips unfortunately it came without the hard drive, where can i get one from
You can purchase one from a computer shop or on the Internet.
Hard drives can be IDE/PATA or SATA, make sure you purchase the correct type for your Phillips desktop computer.
Dec 07, 2012 | Computers & Internet
How do I remove the harddrive from the HP Slimline S3100n?
Shut down the power to your HP Slimline computer.
Remove any memory cards or other devices from the desktop.
Disconnect the power cord and peripheral devices from the computer.
Lay the computer flat on your work surface.
Remove the three screws on the rear of the computer cover with a Phillips screwdriver.
Slide the cover toward the back of the computer then lift it off the tower.
Set the cover aside.
Raise the wire latch in front of the hard drive mounting area.
Pull the cables straight out of the connections to disconnect them from the hard drive. Unscrew the retaining screw in the side of the mounting tray with a Phillips screwdriver.
Grab the tab on the hard drive tray and slide it back out of the mounting area. Remove the screws that secure the hard drive to the tray with a Phillips screwdriver.
There are four screws, one on each corner.
Slide the hard drive out of the tray.
http://www.youtube.com/watch?v=hcChcrjCILo
Replacing an HP Slimline Hard Drive
hope this helps
Sep 30, 2012 | HP Hewlett Packard Pavilion Slimline...
I reset my surge protector and the computer wont power up. i think i need a new power supply. the power cord is working fine. Please let me know where i can find a power supply for the aspire...
The Acer Aspire L100 is a desktop computer powered by a special DC adapter and power cable. The computer's motherboard incorporates a fuse designed to prevent any power surges from damaging the computer. If the fuse burns out due to a power surge or for any other reason, the computer will no longer function. You can check the motherboard fuse for damage yourself, then take it to a trained technician for replacement if needed
Shut down the Acer Aspire L100 and turn the tower around.
Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
Unplug the power cord from the rear of the tower
Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack
Let me know if this helped..
  • 2 Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
  • 3 Unplug the power cord from the rear of the tower.
  • 4 Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
  • 5 Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack.
  • Read more: Fuse Location on Acer Aspire L100 ' eHow.co.uk http://www.ehow.co.uk/how_7815704_fuse-location-acer-aspire-l100.html#ixzz1XUVwmxuA
    Sep 09, 2011 | Acer Aspire L100 PC Desktop
    My speakers stopped working after they were unplugged etc
    Try the BLUE jack, then the GREEN jack. You won't hurt anything if you guess wrong. BTW, are the sub and speakers powered up? Pilot light showing they're on? Some speakers are powered by a USB port - any loose USB cables laying around?
    Apr 18, 2017 | Creative Labs Audio Players & Recorders
    Computer not recognizing video card maybe?
    If you have a onboard graphics on your mobo they may have been turned on somehow I would check there and disable them if they have been.
    Aug 15, 2009 | ASUS Extreme AX800XL Radeon X800XL, (256...
    Computers & Internet Logo
    19 people viewed this question
    David Payne
    David Payne
