Question about Garden
Kubota m120 3point lift arms will not go down
3 point hitch arms will not go down
  • 78 Answers
SOURCE: how to install a 3 point hitch on a 140 farmall
I think a 140 is a IH Cub . I don't believe they had available a 3 point hitch. Please register at www.farmallcub.com and there are people there that have had a 140 apart and back together many times. IF there was a 3 point hitch available they will know about it.
GOOD LUCK
Mike
Posted on Oct 22, 2009
  • 8404 Answers
SOURCE: LIFT ARMS FOR 3 POINT HITCH WILL NOT MOVE
Standard tractors have a lever to the right of the driver, move toward the rear of the tractor to lower ... move toward the front to lift.
Posted on May 07, 2010
SOURCE: How do I get the rocker arms to move?
You need to put your hydraulic pump in gear and the lever that runs the hydraulic outlets will run your rockshaft it might not go down if there is no load on the 3-point.
Posted on May 08, 2010
  • 6468 Answers
SOURCE: hydraulic 3 point hitch is stuck in the up position
check the linkage on the valve
Posted on Aug 16, 2012
wadingriver
  • 2095 Answers
SOURCE: JOHN DEERE 4300 3 POINT HITCH PROBLEMS, WILL GO UP AND DOWN AFTER YOU START IT. AFTER USING 3 POINT HITCH UP AND DOWN, THE DOWN MOTION WILL SLOW DOWN DRAMATICALLY TO THE POINT WERE IT WONT GO DOWN AT
A reversable pump operates the Hitch. sounds like a bad valve in that direction. If Fluid level was low, it would be a problem in both directions.
Posted on Sep 12, 2012
I own a 1996 Kubota 7040 and my problem is when I'm at idle the bucket won't lift or the 3 point hitch I have to Rev engine to get a response.All oil and filters are new also the hydraulic pump
Try turning in 1 turn C/W on the pump relief valve adjustment. It should be an Allen stud with a jam nut on the right side of the transaxle just above the axel housing. Foamy or milky hydraulic oil is an indication of leakage or blockage in suction tube for the pump.
Mar 20, 2017 | Cars & Trucks
How to remove/replace Kubota b7100 three point hitch hydraulic control lever
Try you tube, type "How to remove/replace Kubota b7100 three point hitch hydraulic control lever." there are videos.
Aug 20, 2016 | Kubota Garden
3 point hitch won't go up wuz working. On a kubota tractor
is the pto lock on if not checkto see if hydraulic fluid is at normal operating level:) i had this problem a while ago!!!
Aug 17, 2015 | Kubota Garden
Rockshaft adjustment
You broke linkage inside on rockshaft when you pulled off the right lift arm. Sorry. Pull top hitch off and repair. There is a procedure to replace these seals safely without moving rockshaft side to side.
Oct 14, 2014 | Farmall IH Tractor 706, 756, 806, 856,...
Three point hitch wont lower, kubota l2550
Mine did the same thing. Below the front of the seat is a knob sticking toward the front of the tractor that is angled upward that controls the fall rate of the three point hitch. After searching the internet for a while I found what this knob is for and went out and turned it until the three point fell down. The knob is perfectly placed to bump with my foot as I get off the tractor (I have large feet and bump a lot of controls getting on and off) and I guess I had bumped it closed over time.
Dave
Jun 22, 2012 | Garden
How do I get the rocker arms to move? I want to but a 3 point hitch on my 60 but i do know how to get hte rocker arms to move. Are there valves that need to be adjusted?
Jan 14, 2010 | John Deere 3-point Hitch Kit A,b,g,50,60...
Kubota mini digger KX36-2: changing rubber tracks
Undo the nut the nipple fits onto ,thats the valve itself.
Then lift up the machine with the arm over the side that the tracks off  about 2 - 3 foot  so it helps the track to go in and on and start putting the track on at the sprocket end first.
When you get the track to the idler end it will push the grease out as it rolls on or you can lever it home with a big bar before tracking up .
Dec 31, 2009 | Garden
Three point hitch on 2020 Jogn Deere Tractor will not raise.
The three point hitch raises with hydraulic pressure. When the hitch will not raise the first thing to check is the hydraulic fluid level. If it is low add hydraulic fluid to the proper level as stated in the owner manual.
Jun 20, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
357 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
