Question about PC Chips PCChips A13G+ v3.0 Motherboard - NVIDIA GeForce 6100, Socket AM2, MicroATX, Audio, Video, PCI Expres
Turn on AHCI mode
How do I turn on AHCI mode on a a13+ motherboard
  • jarich44
    jarich44 Feb 05, 2013
    DUH!! But where???
  • Jose Diaz
    Jose Diaz Feb 05, 2013
    Search based on the make and version of the BIOS. duh
  • 2,878 Answers
It should be in your BIOS if it is there to begin with? gl
Posted on Dec 08, 2012
Is Asrock 945GCM-S compatible with AHCI?
I think that you motherboard BIOS can supprot that,
Access your BIOS and look for SATA Mode option, and change it to AHCI
Jan 17, 2013 | Asrock 945GCM-S Motherboard
How to set up AHCI mode In RS482M bios.
Hello from here you can download a manual:
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=536&DetailName=Feature&MenuID=24&LanID=0
If the bios is set to IDE/sata mode it will not boot when you select the ahci mode.
Your windows has to be installed again when the settings are made in the bios in order to make the ahci mode working.
More about ahci here:
http://en.wikipedia.org/wiki/Advanced_Host_Controller_Interface
Good luck
Dec 22, 2012 | EliteGroup RS482-M (RS482M10A) Motherboard
IDE devices not detected
daer customer check ahci mode (pata )mode will be check & your problu is solve.
Mar 02, 2012 | MSI K7T266 Pro2 (MS 6380-060) Motherboard
Disk read error windows 7
Check on the BIOS option and try to boot in SATA Mode instead of the AHCI that comes by default some motherboard are not capable to run windows 7 on AHCI Mode. Hopes this helps you.
Best regards Luis!
Jan 13, 2012 | Intel Computers & Internet
Ello. I wanted to know if there is a BIOS update for the Aspire M1100 because my BIOS dated 23/02/2008 which references are Motherboard SMBios version 2.5 Acer F690GVM Bios: Phoenix Technologies,...
The AHCI can be enabled from using the correct driver but you should have enabled it PRIOR to the OS install
Acer did not always do this but often relied on compatibility mode
The speed increase is often not that much.
The BIOS on that board can be updated but you may find that AHCI still does not work as you expect.
Mar 15, 2011 | Acer Aspire M1100-U1402A Refurbished AMD...
I am using Acer Aspire 4530 notebook and has set in IDE when i installed windows 7. When I change it into AHCI mode, I got blue screen and can't start up.
You will need to perform a repair install to do that - and after that you will have to install the AHCI driver.
Feb 25, 2011 | Computers & Internet
Error while trying to install windows xp Stop: 0x0000007B on a dell Optiplex sx270
The most popular Blue Screen of Death error in Windows is the STOP 0x0000007B error, sometimes called the 0x7b error or the "INACCESSIBLE BOOT DEVICE" BSOD.
This BSOD (which is actually the common name for a STOP Error) could mean that there's a serious hardware problem with a hard drive controller, a driver issue, or even a boot sector virus.
In your case though, this is most likely one of 4 capacitors that are known to blow out on any SX270. Slide the bar at the back of your PC to the remove cover side and look inside for swollen caps. Remove the fans and cpu cover as well and check around there. Replace any bad ones you can find with old caps borrowed from an old motherboard if you have one, or new ones from any decent electronics parts warehouse. This fix has worked for me on every SX270 I have ever had.
Mar 10, 2010 | Dell OptiPlex SX270 PC Desktop
Epox Ep-af550g mobo
If AHCI is not enabled by the motherboard and chipset, SATA controllers typically operate in "IDE emulation" mode which does not allow features of devices to be accessed if the ATA/IDE standard does not support them. Windows device drivers that are labeled as SATA are usually running in IDE emulation mode unless they explicitly state that they are AHCI. While the drivers included with Windows XP do not support AHCI, AHCI has been implemented by proprietary device drivers.[1] Windows Vista[2] and Linux with kernel version 2.6.19 onward[3] have native support for AHCI.
Jan 15, 2009 | Computers & Internet
Windows XP boots endless if SATA is set to AHCI
this is'nt so easy here an example solution:
Enabling SATA mode to AHCI after XP Install (applicable to most laptops, or systems) If you want to enable SATA mode as AHCI after installing Windows XP, then read on. It's a bit of a long read because of step-by-step instructions, but worth it.
I did this on on Acer Aspire 5315-2153, it seems like the basic strategy should work on other laptops or systems.
For whatever reason, you may have installed Windows XP on your new laptops with SATA Native Mode disabled in the BIOS. Once XP is installed, enabling it in the BIOS will result in a BSOD upon loading Windows because XP doesn't have the correct drivers.
I read that enabling SATA native mode will give you a slight performance inrease and slightly increased battery life, so it seems worthwhile to me smile.gif
Here's how I did it on a Acer Aspire 5315-2153 running Windows XP (32 Bit version):
- Download the Intel Matrix Storage Manager software from Intel (I think it's iata_enu.exe)or AHCI_Intel_v7.5.0.1017_XP.zip from Acer web site.
- Extract files from AHCI_Intel_v7.5.0.1017_XP.zip to e.g. C:\AHCI_Intel_v7_5_0_1017_XP files need: (you may delete the rest)
iaahci.cat
iaahci.inf
iastor.cat
iastor.inf
iastor.sys
TXTSSETUP.OEM
- Now go to Device Manager, under IDE ATA/ATAPI controllers you should
see: Intel 82801HEM/HBM SATA AHCI Storage Controller
- Right-Click on that and select Update Driver
- Say no to connecting to Windows Update to search, hit Next
- Select Install fro a list or specific location (Advanced), hit Next
- Select "Don't search. I will choose the driver to install", hit Next
- Select Have Disk
- Browse to C:\AHCI_Intel_v7_5_0_1017_XP and highlight the iastor.inf file, hit Open
- Select OK
- Now you should have a list of controllers, for the Acer 5315-2153 choose Intel 82801HEM/HBM SATA AHCI Storage Controller, hit Next
- You'll get warned that installing the device driver is not recommended, click Yes to continue installing
- Click Finish
- Click Yes to restart your computer
When your computer boots up, you need to hit F2 to enter the BIOS. Change SATA mode to AHCI, save changes and exit.
After you log into Windows, your computer will find the "new" hardware. Wait until you get the popup message to restart your computer, say Yes to restart one last time.
You may download also from Intel the RAID/AHCI Software - Intel® Matrix Storage Manager (iata70_enu.exe 5640KB) and install it in your system, it may fix in case you got the wrong Intel 82801 AHCI controller.
I give credit to Jamie Rybarczyk at HP Business Support Center forum for doing most of typing.
http://forum.notebookreview.com/showthread.php?t=186471
Jan 06, 2009 | Computers & Internet
PC Chips PCChips A13G+ v3.0 Motherboard - NVIDIA GeForce 6100, Socket AM2, MicroATX, Audio, Video, PCI Expres Logo
201 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
