Question about Dell Latitude E5500 Laptop
Dell e5500 Lights comes on for a few seconds then the laptop turns back off
    Problem Solver:
  • 13 Answers
I had this exact same issue on a Inspiron (don't remember the model, but was purchased around 2005 or 2006) and it turned out to be a bad mobo.....rather a power chip bad on the mobo that I wasn't going to take off and re-solder a new one on.
Dell website will have a schematic on the certain lights that light up when you power on and you can use that to help diagnose your problem.
Some of them are simple like RAM not recognized by motherboard. Try taking out your RAM stick and putting it back in, then boot and see if it boots.
Posted on Dec 07, 2012
rachelgeek23
  • 155 Answers
SOURCE: laptop will not turn on
Unplug the ac adapter from the back of the computer. Make sure it's plugged to an electric outlet. check if the ac adapter light is solid green. if not. then you have to replace it.
If it is solid green, reconnect it to the computer, if the light on the adapter goes out as soon as you plug it in to the system, you need to replace the motherboard. call dell to seek your options for replacement.
Posted on Mar 04, 2009
  • 8 Answers
SOURCE: my Dell latitiude e5500 has problem with the keyboard
send it back if its new.. for a swap out under guarentee...
Posted on Apr 07, 2009
  • 121 Answers
SOURCE: My Dell latitude E5500 laptop's bluetooth is not
try re pairing your bluetooth device
Posted on Mar 25, 2010
potek18
  • 528 Answers
SOURCE: Latitude - E5500 Laptop Computer ( 2.26GHz, MB, GB) (blcwdhp_3) PC Notebook: how do i restart to factoru condition my dell e550...
Pressing Ctrl + F11 should resolved the issue if the restore partition still exists in functioning condition on the hard drive. Seeing as most D600s are off-lease machines on their fourth or fifth year by now, I'd say the chances of the aforementioned partition existing, not to mention working, are slim. You will probably have to re-install XP on your own. If you already have an XP installation. Once you installed XP on your computer, all drivers are available at Dell's website.
Best of luck.
Posted on May 18, 2010
  • 1288 Answers
SOURCE: My laptop, dell inspiron 1800, cuts on but after a
A few things to check:
1.) Check the battery is charged and the charger is supplying the right voltage and the power jack is tight in the laptop DC port. Check that the charger (on charger) light is steady green, not flashing.
2.) Remove battery and try to boot on AC Power, if this works, either the battery is not charging (dead battery) or the charging circuit in the laptop is damaged.
3.) Remove Ram modules oner at a time, see if it boots with one module in, if it does, then issue is with the ram
4.) Examine the cooling vents, try blowing them to see if any dust is released, hoover them as best you can, if this cures the problem (and it will be a temporary fix), get the laptop stripped down and give it a proper clean around the processor and fan areas. (overheating issue)
If it does not help, then Its looking like your motherboard has developed a fault through maybe overheating
Posted on Jan 21, 2011
Fix my Dell latitude E5500? It comes on i type password, but then screen stays black
Sounds like the hard drive is freezing at that point run a drive check
Feb 06, 2015 | Dell Latitude E5500 Laptop
Put in new battery on Dell latitude E5500, worked great in the store, clerk told me to charge it to full when I get home, did that now when I turn on computer name flashes up n screen and computer cuts off
Hello, Either your charger isn't working or the battery you just got is bad, take it back and exchange, if that doesn't work then your charger isn't charging.
Apr 02, 2014 | Dell Latitude E5500 Laptop
Dell latitude e5500 no wifi
you can fix that by installing the right driver here is the link
http://www.dell.com/support/troubleshooting/us/en/19/Product/latitude-e5500
go to network then the top one
Jan 18, 2012 | Dell Latitude E5500 Laptop
When i switched on my dell laptop (latitude E5500) today, it just displayed a black screen . the tiny power lights on the keyboard are blue which means the laptop is working fine ,just the screen goes...
hold the Fn Key while powering on, this will enable the PSA diagnostics, if you get any video and or the diags function then that should give you an indication of the problem.
If you only get LED lock light indications, then check here:
http://support.dell.com/support/edocs/systems/late5400/en/sm/trouble.htm#wp1092170
Jun 13, 2011 | Dell Latitude E5500 Laptop
I just recently started having a problem with my Dell Latitude E5500 beeping. Sounds like its coming from the hard drive area. Any ideas?
This problem needs a step by step detailed help.
Please make the payment for faster resolution to your prolem.
Aug 26, 2010 | Dell Latitude E5500 Laptop
E5500 will not turn on after disconnected from docking station
I just want to know, removing battery and docking station, and just use the ac adapter alone still no power on the laptop? If yes please replace the motherboard.
Mar 31, 2010 | Dell Latitude E5500 Laptop
My Dell latitiude e5500 has problem with the keyboard
Apr 07, 2009 | Dell Latitude E5500 Laptop
Dell Latitude E5500 Laptop Logo
70 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
