Question about DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine
Delonghi Magnifica 3400 espresso maker leaks
While making coffee the machine leaks coffee into the drip tray and onto the counter
  • ak4mw Feb 02, 2009
    Coffee comes out from behind door and leaks into tray. I am losing a lot of coffee. I clean grinder after every use.
  • CPKIII Feb 25, 2009
    I have a model 3200 that leaks water/coffee into the tray and onto the counter when I am brewing. No leaks otherwise.
  • 123 Answers
SOURCE: instruction manual for delonghi combi espresso/filter coffee maker bc0255
http://www.delonghi.co.uk/pdf.php?key=Coffee%20Machines
Your manual is listed on this page and you will be able to download it.
Good Luck.
Posted on Apr 10, 2008
farmerbear
  • 490 Answers
SOURCE: where can I get the parts for delonghi magnifica
Howdy:) You can get parts and accessories for your Magnifica here: http://www.delonghiusa.com/index.php?texts&pid=15
Hope you are up and espressing asap:)
Posted on Aug 24, 2010
guru_fixya
  • 944 Answers
SOURCE: We understand that your problem
This valve will differ based on the DeLonghi models
If the machine is still under warranty you may void the warranty any time you take it apart.
When water heats it expands which creates more pressure in the boiler. This pressure may allow some water to sneak by.This valve is located behind the shower screen and keeps the water from being forced out of the boiler as it heats and the water expands. When you want to make coffee and turn the pump on the valve will stay closed until enough pressure is built up to push it open allowing the water to flow. When you turn the pump off, the pressure reduces and the spring on the valve pushes it closed. When the steam button is pushed the boiler heats up to a higher temperature and the pressure in the boiler increases putting more strain on the valve.So this valve may be loose or some time may be defective one.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 01, 2010
SOURCE: Drips onto counter when pouring from carafe
My carafe for my h/b stay or go coffee pot started leaking after owning it for a while. This appeared to be a perplexing problem until I discovered that the small gasket on the bottom of the lid had either flattened out over time, or rotated to a different position that would cause my pot to leak or dribble coffee all over my cup and counter top. To fix this I just rotated the gasket to a spot where it would create a good seal. Every so often I have to repeat this process, and I need to contact Hamilton Beach to see if they can send me a new replacement gasket, as a new gasket would solve the problem.
Posted on Oct 19, 2010
mnwarfield10
  • 452 Answers
SOURCE: Delonghi 3400, spend grounds going wrong place
we repair 07779933829
Posted on Jan 26, 2011
Internal water pipes leaking on my Delonghi magnifica. Where can I buy the pipes? Will I be able to replace the pipes myself?
DeLonghi Magnifica water leak problem - YouTube
? 2:37
https://www.youtube.com/watch?v=_mNGPs79ajY
Feb 5, 2011 - Uploaded by shellway2005
My DeLonghi Magnifica ESAM3300 is not making shots. Wateris instead coming out of the front bottom via a ...Missing: pipes
DeLonghi Magnifica leaking water pipe Questions ... - Fixya
www.fixya.com > ... > Coffee Makers & Espresso... > DeLonghi
DeLonghi Magnifica coffee makers & espresso machines leaking water pipe related questions and answers. ... Delonghi Magnifica My steam arm drips when I make coffee. ... Not sure if water is leaking from water tank or internal water line.
DeLonghi Magnifica leaking water Questions & Answers ...
Order DeLonghi Parts‎
www.ereplacementparts.com/DeLonghiadvertiser rating
Buy DeLonghi Parts.
Fastest Shipping - Low Prices.
Jan 07, 2016 | DeLonghi Coffee Makers & Espresso Machines
Espresso part is working, hot water/steam draining into drip tray.
I had the same problem on my Delonghi ESAM3300; you need to replace the "Tap" #7313216621 you can buy at eReplacementParts.com and search on how to install on Youtube. Its easy. No more leaking. Good luck
Oct 07, 2015 | DeLonghi ESAM3300 Magnifica...
Delongi eam3400 machine. the water flow is good on the back of the machine but drips into the drip tray instead of flowing through coffee grinds/cup?
http://dl.mypdfmanuals.com/new/external_light.php I found the user manual, look in the troubleshooting section Kolbrub
Sep 17, 2013 | DeLonghi Esclusivo Magnifica ESAM3300...
I initially replaced the o-rings in the pipe/valve assembly. It didn't work for long (not correct size o-rings probably). I then bought a new pipe-valve unit. To replace you need to pry off the stream handle (chromed plastic). It only fits one way on the axle (so take notice when replacing!). Then remove back and side covers (6 screws all at the back). Then remove top (2 screws each side at the front and a couple at the back). Then the front panel should be lose. (Instructions based on a slightly different model)
Mine made better coffee after I fixed the leak! A large portion (perhaps 25%) of the water intended for the coffee went via the steam wand straight into the drip tray, which is not good.
Oct 15, 2012 | DeLonghi Magnifica 3300 Espresso Machine
My Delonghi Magnifica (manual not digital) won't start the grinder, could this be the circuit board?
Delonghi Magnifica comes up with waste tray full light when there is nothing in the tray. It doesn't make coffee, the grinder is rotating and appears to be clear. Could there be a blockage below the grinder, if so how do I access it.
Aug 21, 2009 | DeLonghi EAM3500 Espresso Machine/Coffee...
DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine Logo
471 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
