Question about Toshiba Satellite M35X-S114 Notebook
Toshiba satellite m35x-s114 powers on but takes 30 minutes to boot
My toshiba satellite powers on, but takes 30 minutes for windows to come on. What could it be.
  • Toshiba Master
  • 7,627 Answers
If you haven't already done it Download MALWAREBYTES and RUN A FULL SCAN, DELETE ALL RESULTS. Found: http://www.filehippo.com/download_malwarebytes_anti_malware/
In the install UNCHECK the TRIAL PRO, you want the freeware version. ALSO Download CCLEANER at: http://www.filehippo.com/download_ccleaner/ Run to Cleaner to remove the junk from your machine. In TOOLS, STARTUP Disable ALL Uncessary startup programs. This will increase the startup speed. You didn't give your OS? Have you updated WINDOWS? That's a start. Respond to post for further assistance.
Posted on Dec 07, 2012
    Sergeant:
  • 206 Answers
Hi
your files are fragmented and becoming corrupted you need to save the data you want and reinstall windows and the drivers.
it is a common problem with everyone's laptop.
cheers
rtrahan
  • 741 Answers
SOURCE: how do i connect my dvd ram drive on my toshiba m35x s114?
Is this an external drive? Here a tip: Anytime you use a peripheral with USB you must load the drivers first, then hook up the device. This is only with USB devices. So try uninstalling your DVD driver, unplug the DVD player, reload the driver for the DVD player, then hook the DVD player back up. That should take care of it.
Posted on Dec 22, 2008
benwabnick
  • 2404 Answers
SOURCE: How do I restore to factory setting Toshiba Satellite M35X S114
You need to have the restore disk that came with the machine or if you don't have it, then you will need to get a Windows XP cd and find the drivers for your hardware on Toshiba's Support website.
Posted on Feb 19, 2009
jaye_ellen
  • 591 Answers
SOURCE: how do i connect the dvd ram drive on my toshiba m35x s114 satellite notebook
DVD RAM drives plug in to any available USB port. Your computer should assign it a drive letter; using Computer, explore ther drive's contents looking for an Install application. Run this` application and you ought to be able to get to the drive.
Posted on Sep 23, 2009
joecoolvette
  • 5660 Answers
SOURCE: How do I upgrade the
How to upgrade the Ram Memory of a Toshiba Satellite M35X-S114 Notebook PC, and stating special precautions at the same time:
1) Work on a table. Do Not work on a bed, couch, or directly on a carpet floor.
These are high areas of Static electricity.
[ Static electricity can fry out (Short Circuit) the hardware components inside your computer. It can also fry out the new Ram Memory module/s before you install them ]
Do Not remove the new Ram Memory module/s from their protective Anti-Static cartons, or boxes, until you are ready to install them. (Old ram memory module/s removed)
If you do not have an ESD wrist strap available, and a good ground source to connect the alligator clip to, at least touch a metal door knob before sitting down to replace the Ram Memory.
If your table is sitting on a carpet floor, refrain from swinging your legs, and your feet on the carpet.
2) Remove ALL power to the laptop.
Remove the AC adapter (Charger) and Battery.
Press the Power On button, and hold it down for a count of 5 seconds. Let go. Do this procedure two more times. You are draining any residual power.
3) Laptop turned over the Memory Compartment Cover is the small square cover.
http://www.irisvista.com/tech/laptops/ToshibaM35X/satM35X_1.htm
Left-click on the photo in Step 1.
Now close this small window, and left-click on the photo in Step 2.
Step 1 photo shows you the Memory Compartment Cover, and the single Philips head screw to remove.
Step 2 photo shows the Memory Compartment Cover removed, and the Ram Memory modules locked into the ram memory slots.
The Ram Memory modules ('Sticks') are DIMM modules. Dual Inline Memory Module.
They are a variation also for a laptop. They are SO-DIMM.
Small Outline Dual Inline Memory Module.
There are 200 gold plated contact pins on the bottom of the ram memory module.
100 on EACH side.
http://en.wikipedia.org/wiki/File:1GB_DDR2_SO-DIMM.png
The photo above is to show a typical example of a SO-DIMM ram memory module.
I would like you to;
A) Observe the gold plated contact pins on the bottom.
B) Observe the Locating Notch in the bottom of the ram memory module.
C) Observe the Notch on each side of the ram memory module.
D) Observe the Black DRAM chips on the side of the ram memory module
When handling a Ram Memory module, refrain from touching the gold plated contact pins on the bottom.
Handle the Ram Memory module by the body of the module.
This area is where the black DRAM chips are.
The body is coated with a see-through protective plastic.
Note the Locating Notch in the bottom, and how it is not centered.
This Locating Notch MUST line up with a Locating Lug, in the bottom of the Ram Memory slot.
Observe the direction the old ram memory module comes out.
There are metal clips on each side of a ram memory slot, that hold the ram memory module in place.
These metal clips are Locks.
Thin spring steel clips with a protrusion, or 'Bump' on the end.
The protrusion, or 'Bump' snaps into the Notch on the side of the Ram Memory module.
One on either side.
To remove the Ram Memory modules, if there are more than one, you have to remove the top one first.
Take your fingernails, and gently spread the metal Lock clips, towards the outside of the Ram Memory module
Sometimes when you ease the metal clip out on one side, that side will pop up a little bit.
Sometimes it takes releasing both Lock clips at the Same Time.
When the 'Bumps' are free from the Notches on the side of the Ram Memory module, the Ram Memory module will spring up, or pop up, a little bit.
Hold onto the upper corners with your fingertips, and slide the Ram Memory module out.
NOTE*
DO NOT pick straight up on a Ram Memory module when removing!
You will bend the contact pins of the ram memory module, and ruin the contact pins down in the ram memory slot.
The Ram Memory module comes out at an angle.
To install:
Install the bottom Ram Memory module first. (Yeah I know. Duh!)
Line the Locating Notch up with the Locating Lug.
Slide the Ram Memory module into place until the spring Lock clips need to be spread.
Spread the clips, slide the Ram Memory module all the way into place.
Be SURE the metal Lock clip 'Bumps' are seated into the Notches on the sides of the Ram Memory module.
This way you can be assured that the Ram Memory module is seated correctly.
Reinstall the Memory Compartment Cover.
Turn the laptop over, reinstall the Battery FIRST.
Then plug the AC adapter in.
WAIT 20 seconds, turn the laptop on.
BIOS will automatically 'recognize' the new ram memory.
If you have questions please post in a Comment.
Regards,
joecoolvette
Posted on Nov 15, 2010
neoranjit
  • 310 Answers
SOURCE: my toshiba satellite m35x-s114 is running very
All you need to do is a PC tune up. There are tons of applications that can help you with this . Go to cnet.com and download utilities . Am sure that can help
Thanks
Ranjit
Posted on May 19, 2011
My toshiba satellite m35x-s114 is running very slow
Thanks
Ranjit
May 19, 2011 | Toshiba Satellite M35X-S114 Notebook
My hdd broke and I wanted to know if I can replace it with any brand. I have a Toshiba Satellite M35X-S114
Yes. Make sure to have the same technology. When extracted buy one with the same connections.
May 03, 2010 | Toshiba Satellite M35X-S114 Notebook
Toshiba satellite m35x-s114 boots to the toshiba screen then doesn't do anything else. Even with the f2 or f12 option nothing happens. I hear the fan (I think it is the fan) then no sound at all. I have to...
Try getting to the bios screen, if you can get to the bios screen then I would imagine the hard drive has failed. If it is hanging up at the toshiba splash screen and not allowing BIOS access, then I would lean toward a motherboard failure. Are you attempting a boot from the windows disc?, is that why you are trying F12? I have seen my share of these Toshiba M35's just give the Toshiba splash screen when there has been a motherboard issue. Changing out the main board will fix this particular problem. I had not found another solution for it.
Nov 27, 2009 | Toshiba Satellite M35X-S114 Notebook
Feb 19, 2009 | Toshiba Satellite M35X-S114 Notebook
How do i connect the dvd ram drive on my toshiba m35x s114 satellite notebook
Aug 14, 2008 | Toshiba Satellite M35X-S114 Notebook
Adding RAM
Yes that model can support up to 2gb's of ram. Any other questions just send them to me.
Jul 30, 2008 | Toshiba Satellite M35X-S114 Notebook
Toshiba Satellite M35X-S114 Notebook Logo
83 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
