Question about Polaroid Z340 Instant Digital Camera with ZINK Zero Ink Printing Technology
Z340 Battery Charging
My Polaroid z340 instant digital camera won't stay charged! I fully charge it and it dies about 5 minutes later! It's brand new please help!
If is it brand new you should have some kind of warranty on the camera. Have you contacted the manufacturer? How about where you bought it? Did you pay with a credit card? If yes, ask them if you have any protection for a faulty product. Sounds to me like you just got a "lemon."
Dec 20, 2014 | Cameras
I have a polaroid Z340 and it keeps prining two copies of everything I have set it to print straight away but how do I stop it from printing two?
You can go into the printer settings on your computer. There the default is probably set to printing two copies. You can simply adjust the setting down to one copy of every print. If that doesn't work you may need to call a printing service.
Elisa Jed ' http://www.huntingtonbeachfastprint.com/printing-services.html
Aug 22, 2014 | Office Equipment & Supplies
I can't open pictures taken with my smartphone on my Polaroid Z340. Only my photos taken with my digital camera shows up but they are on the same SDcard as the once taken with my phone. I anybody eles...
Be aware, jpg is an universal format, for pictures. It is not so all pictures have the same format and information. Your Polaroid can cope with a certain format of pictures. That is with the correct amount of pixels and he correct RGB settings, as your Polaroid camera produces.
It is not a computer. When you connect a printer to a computer, with the print program, the program can transform any picture size to any print size and also can work with RGB and sRGB, or even more challenges. I'm not even sure the Polaroid will accept pictures in the same format, if to a certain code is in the jpg.
Jul 03, 2014 | Polaroid Z340 3 X 4 inch Instant Digital...
Pixma mx452 paper jam
Follow the steps in the manual if you have a manual and if you don't have one I recommend that you get one.
May 09, 2014 | Polaroid Z340 3 X 4 inch Instant Digital...
Why does my Polaroid z340 can t print?
On page 52 of the manual it says, press print to enter the print menu or when you want to print the last picture you took, press the print button twice.
May 02, 2014 | Polaroid Z340 3 X 4 inch Instant Digital...
I cannot close the battery compartment
Are you sure you did put in the battery correct and not the wrong way around? could be a mechanical block, to avoid damage to the camera, by wrongly placed battery.
Mar 20, 2014 | Polaroid Z340 3 X 4 inch Instant Digital...
Frezes every time i try and print
Did you try to charge the battery. For printing the battery, needs enough power. If the camera senses there is not enough power to print one complete picture, it will shut down. Sometimes you could shoot 10 or 20 pictures, but you can't print one picture, for the lack of power.
Feb 13, 2014 | Polaroid Z340 3 X 4 inch Instant Digital...
Phone won't charge
Hi, The Li-ion battery cahrging circuitary is some what complex. For most chargers, the charging procedure is divided into three main phases: ? Pre-charging phase ? Constant-current-charging phase ? Constant-voltage-charging phase In the Pre-charging phase, it utilizes low charging current to protect the battery. However,in most recharging situations, the charged batteries still have some voltage remaining, so the charger does not need to apply this action, and just passes it on to the next charging phase. The constant current and voltage charging phases are the main charging phase for recharging the batteries, where most of the charging energy is transformed into the battery. The maximum charging current for a battery depends on the battery?s rated capacity. For example, one battery rated 700 mAh usually can be charged at 350 mAh to 400mA, for faster charging effort. When the charged battery is Li-Ion, in the last charging procedure, the microcontroller normally maintains regular charging voltage while monitoring charging current to determine when the charging procedure should be completed. When the battery is fully charged, most of the electrical energy is converted to thermal energy, which can result in high battery temperature. In this case, the temperature monitoring function will be added for the solution. But since most Li-Ion batteries on the market also have an over-charging protection function, the temperature detect function is rarely used. So it is better to get your phone charging circuitary checked at a local store rather than to make a charger,coz both may cost you almost same. all the best my friend. regards sreejith
Jul 15, 2007 | Sony Ericsson K610i Cellular Phone
Polaroid Z340 Instant Digital Camera with ZINK Zero Ink Printing Technology Logo
82 people viewed this question
Top Polaroid Photography Experts
Myrddin R Emrys
Myrddin R Emrys
NOEL
NOEL
David Payne
David Payne
Are you a Polaroid Photography Expert? Answer questions, earn points and help others
