Question about Emerson EWL20D6 Television
No color color went out. piture still good. the channel color number & input color channel works.
Mine just went out.
Posted on Aug 04, 2009
Menu pops on and off for about a minute when i first turn the tv on
the self diadnostic program in the tv is going bad.. may be time to replace the tv or dont shut it off completely
Jan 21, 2014 | Samsung LNT4665F 46inch 1080p LCD HDTV
No picture on channel 7mate
The problem could be only in the input device.
Jul 25, 2012 | Grundig Televison & Video
I can't switch channels
Consult the owner manual (you can GOOGLE to find one with the model number if you do not have it) to see if the set has a feature to lock out channel being changed---this feature is on some sets so if using a box children etc cannot change the channel.
You can also try to route your signal to a rear audio/video input and change input to that input and change channels with the box if you use one.
Mar 30, 2012 | Hitachi 32HDL52 32 in. LCD Television
I do not get a piture or sound
Check to make sure that your TV is tuned to proper channel (I.E., Aux 1, S-video, component 1, so on.) best to try with dvd in the player and just select the source input on your tv one at a time until you get the right one. If you are connected with HDMI cable, it should be one of those, if it is the standard yellow, white, red cable then it would probably be one of the "component" selections on tv input section....you may have to refer to your TV model and user guide to see which one is the correct one in correspondance to what you have hooked up....good luck.
Sep 14, 2010 | Coby DVD-937 5.1 Channel DVD...
Rca big sreen went black and white menue is still in color
Try using one of the other video input options, like AV inputs. If still have black and white picture, then the color processor is having issues. If now in color, then your tuner has issues detecting the chroma / luminance signal.
If you are using an external digital box, this may be the source of the problem as well. If you still have a VCR, connect the coax from VCR to the coax input on the TV, and play a tape. Tune the tv to channel 3 or 4. If in color, then your set top digital box is faulty.
Jun 25, 2010 | RCA Televison & Video
How to get the effects to work on the mixer
This is in general for Behringer mixers since you did NOT tell us a model number...
To use the effects you adjust the FX knob for EACH channel for the amount of the mic or input you want to send to effects from that channel. This is the "send" mix.
You dial in one of the effects based on the list near the effects selection window with the selector knob and the number will change and start flashing. You press down on the selection knob which will enter the new effects number and the number will be solid and not flashing.
Then there is a knob to select how much of the OUTPUT of the effects you want to go to the main and sometimes one for the amount to the monitors.
That is all there is to it. The effects can be gated by a foot switch input if you desire.
It is a good idea to include a model number as your thing is posted as if it is a PMP3000 mixer.
May 11, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
I have a samsung 42 inch flat screen wich has piture in pitur buti carnt get it to work the model number is ps42q7hdx/xeu
To get the pip to work you will need another video source from a vcr/dvd/blue ray hooked up to a video or comp. input in order to get the pip to work.
Mar 19, 2010 | Televison & Video
Color Resolution
Sounds like a piture tube or internal video driver in your monitor. You probably lost the green channel. If the monitor is dated I would replace it.
Aug 31, 2008 | X2Gen MG19MY 19" LCD Monitor
Emerson EWL20D6 Television Logo
57 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
