Question about Sharp CD-BA200 CD Shelf System
Cd-ba200 error 0306
When I press CD OPEN on the sreen is error 0306. What should I do?
  • Cameraman46 Dec 15, 2007
    I have the same problem
  • Novaa Oct 18, 2008
    same problem / error on Sharp CD-BP1350
  • 82 Answers
Check the CD belt. Part number 92LBE231616.
Posted on Mar 24, 2008
Sharp mini component system
MY GAMES ARE NOT RUNNING PLEASE GIVE ME SOLUTION
May 12, 2013 | Computers & Internet
Sharp CD-BA2100, when I turn it on it starts making a clicking sound and if set to tape one or tape two, it shows "error". When set to "cd" it comes up with error 0306 and the cd tray...
the rubber rope which conect the motor to a small gears to open the cd was cut due to long using ... this sound of clicking coz the small motor is running and its not attached to anything ... its a small rounded rubber rope ..the bad news is you have to break some plastic stuff to reach the motor in the repair depot they change the whole upper part so it costs alot ... but if you can reach it it will work perfect as its new.
Sep 08, 2011 | Sharp CD-BA200 CD Shelf System
I am getting an error Message 0306 or 0203 when trying to open the cd tray on my Sharp CD-BA150 Stereo System what can I do to fix this problem
For the error 0306, simply remove the lid of your system and clear the dust out/off of the lense and surrounding areas. (i.e. soft cloth, canned air, ect...) Hope this helps!
Jan 18, 2011 | Sharp CD-BA150 Shelf System
CD-DP2500 error 0306.Disk changer error. What is cause ?? I got it going OK! after having a good look around checking laser head connections. It seems to have arrived with warmup. I cant find error codes...
how to open the code I wrote that has protection and ... I do not know how to open the electrically operated lights notwill to caress the Power but notwill.
Mar 13, 2010 | Sharp Audio Players & Recorders
Error 0306 same here
A few things you might want to check (if you're willing to take your unit apart):
One possibility is a faulty door open/close knob on the front panel (this is probably a soft touch micro switch). Check for electrical continuity when pressed. If it needs to be replaced, you can use one from a scrapped CD/DVD-ROM unit, just make sure it's of the same type, otherwise you can get it on ebay or from manufacturers like Switchcraft, Piher, etc.)
If the unit has a belt driven mechanism for opening the cd door (also called the cd tray unit), see if the rubber belt is broken or has lost tension - in such case the drive motor is not able to open the door. If this is, in fact, the case, you'll need to replace the drive belt.
You need to find out its diameter, standard sizes can be found on ebay, just use the nearest standard size that is slightly smaller than your old drive belt (an old belt gets slightly oversized and that's exactly what causes it to loose its drag power).
Some mechanisms have a plastic wheel with a rubber edge which is driven by torsion from a motor - see if the rubber is greasy, damaged or dusty (you can clean it with some alcohol), but a replacement for these may be difficult to obtain since it's probably a brand/model specific part.
Then there are also mechanisms that are driven exclusively by gears (check gears for any broken teeth, also, the motor could be the problem). These are, again, brand and model specific parts and may be hard to get.
Another thing to check are the door open/closed switches. These are a pair of metallic contacts somewhat alike to a relay contact. They are usually located somewhere underneath the tray, possibly near the front end. See if the metallic contact points are dark with oxydation, if so, clean them by smearing them gently with a piece of fine sandpaper (be careful not to damage them, they may have a clear plastic cap-arm that needs to be removed prior to cleaning). There are usually two sets of such contacts in each tray unit, one for door open signal and one for door closed signal, so check both of them.
You can test the door motor by disconnecting it and running it of a 3 to 4,5 volt battery. If the mechanism is ok, the tray should open on one polarity and close when you reverse the battery poles (don't force it though, just run it for a few moments so that you see if it works fine).
From here on the things to check are motor connectors (any broken wires or bad solder contacts?), drive IC's, electrolytic condensers associated to the door motor drive section on the main circuit board.
So, there's quite a bunch of things that might cause the problem, also, could be that the true cause is something else.
Anyhow, i hope you can find out what the trouble really is and fix it.
regards
3rq8 (Triarcuate)
Jul 25, 2009 | Sharp CD-BA200 CD Shelf System
Error 0306
hi there, I suggest you should open the top cover of the cd tray, have a look inside do a little cleaning also when you screw back in, make sure you screw in properly( you propaply find that someone had open it up before and screw it back in really tight so the cd trey jam inside, or another alternative something might of broken inside and tha can stop the cd trey from opening. it happen to me before and thats how i fix it. good luck hope it works.. cheers
Oct 06, 2008 | Sharp CD-BA200 CD Shelf System
Cd stuck err 0306 message
Since the cds are stuck inside, you need to open the unit and remove them. There are four screws on the top cover. Remove them (2 on each side) and lift the cover. You should see the cds, remove them, then plug on the unit.
Jun 09, 2008 | Sharp Multi-System Mini Component System...
Cd tray won't open
In the front side of the dvd drive you will see a small hole ...so to eject that cd put one niddle in that hole and .
Now press the button at just after that apply a force on niddle .suddenly you will notice that cd will come outside ,if not try more times and you will learn to eject the cd when you are unable to do it by pressing the eject button...
Low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not.
Thanks
Dilip Bagdi
Technical Associate
Mar 01, 2008 | Sharp CD-PC3500 CD Shelf System
Cd shelf will not open
There is a belt in the CD mechanism that may have to be replace. The part number of the belt is 92LBE231616.
Sep 16, 2007 | Sharp CD-BA200 CD Shelf System
Sharp cd -bp 1350w
I think that depending on if it is old usally before it dies it starts not wanting to open disc drive add coment if it is old or new...
Aug 20, 2007 | Sharp CD-BA200 CD Shelf System
Sharp CD-BA200 CD Shelf System Logo
1,667 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve Allison
Steve Allison
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
