Question about KitchenAid 5-speed Blender With Glass Blender Jar Ksb565er
Leaks from the bottom of the glass jar. Bought a new gasket and it is worse than ever.
    Genius:
  • 1,739 Answers
Are you sure you are installing the gasket correctly?
Leaks are usually the result of a misaligned or cross-threaded blender jar base or from the gasket being installed incorrectly. Make sure the gasket is installed between the blade assembly and the screw on base.
If this does not help, please reply or repost.
Posted on Dec 09, 2012
  • Sandy Dec 09, 2012
    Thank you for your response. After checking out your suggestion I realize it is not the gasket that is leaking. It is the gear at the center that turns the motor that is loose and I can not figure out how to tighten it
Blender glass jar is leaking at base
It will either be the rubber gasket (it goes between the glass jar and the blade assy) or it could be a worn bearing/bush around the chopping blade shaft. Replace either the gasket or the blade assy.
Apr 02, 2014 | KitchenAid 5-speed Blender With Glass...
Starbucks Glass jar replacement for blender
I bought an Oster 6 cup glass and it works perfectly on the Starbucks Barista blender. It has to be the 6 cup NOT the 5 cup or the blade mechanism won't fit. the 6 cup screws right on your old blade base and it was $10 new on Ebay including free shipping.
Feb 20, 2014 | Braun MX2050 Blender Powermax Replacement...
Leaks at the bottom of the glass holder
I'm no expert but in my experience if it leaking at the bottom then either the jar /carafe has a few chips or cracks around the hole in the bottom that the blade fits through and in that case you need to replace the jar and your blade assembly may still be good and can be moved to a new jar/carafe. Or the blade assembly has come loose a little and need to be tightened or some the washers (usually the rubber ones) have worn out and need to be replaced. There's plenty of explanation here at amazon and else where on how to replace the assembly blade, move it to a new jar and tighten it down, etc. Hope this helps!
Sep 26, 2013 | Waring Blenders
My glass jar leaks from the bottom
remove the screw on blade holder, and make sure the gasket is in place ,, check the seal on it,, if its defective replace it,, check along the threads to make sure that the canister isn't cracked
Aug 28, 2011 | Black & Decker BL1900 5-Speed Blender
New gasket installed but jar still leaks...Does gasket go between jar and cutter or between cutter and screw base?
The gasket goes between the plate to which the cutter is mounted and the base of the jar. i.e., atop the cutter and contacting the base of the jar.
Charlie
Jan 12, 2011 | Waring Blenders
RUBBER GASKET ON BOTTOM OF GLASS JAR NEEDS TO BE REPLACED
It looks like their parts are handled by Fox International. here is the contact info:
For parts and accessories for your household appliance, please visit our partner, Fox International, or use the following.
Phone Number: 800-738-0245
(Monday-Friday, 8:30 AM to 8:00 PM, E.T.)
Email: customerservice@georgeforemancooking.com
Mar 29, 2009 | George Foreman Blenders
Blade doesn't spin freely
Here's the parts order form from Waring:
http://www.waringproducts.com/ret/parts/
Once you receive the parts, unscrew the collar from the bottom of the jar, and the old gasket and blade assembly will pop out - sometimes you have to peel the gasket apart from blender jar, but not always.
-Tha Mp3 Doctor
Mar 26, 2009 | Waring MX1000R Blender
Leaking blender
Mine also leaked from day 1. I just read in the manual to first place the bottom and blade assembly on the counter, then seat the gasket around the blade assembly, making sure it is just under the lip of the blade piece (careful, you have to maneuver around the blades). Then place the jar on the assembly and screw in tightly. This worked and I have no more leaks.
This is different than other blenders where you place the gasket on the jar and then attach the bottom. It is a poor design, but after what I paid for it, I am glad to be able to use it and not just trash it.
Jan 27, 2009 | Blenders
Waring blender - new blade
I just figured it out. The key is you need to think in terms of keeping the blades and the large washers separate. Here's what you do.
Thread the blade through the glass and use the white rubber gaskets against the glass and the stainless gaskets against the hardware. Then tighten the whole enchilada to the blender with the main nut (that goes on the bottom outside of the blender). Then once that's nice and tight tighten the flange that catches the blender teeth to the remaining portion of the protruding threads. Make sure you use the copper colored gasket first then the stainless washer then the stainless flange. Tighten that real good and you should be good to go.
To check if you've done it right spin the flange. If the blades spin independent of everything else you're good to blend away!
Feb 23, 2008 | Blenders
KitchenAid 5-speed Blender With Glass Blender Jar Ksb565er Logo
1,418 people viewed this question
Top KitchenAid Blenders Experts
Appliance engineer
eyecam
Are you a KitchenAid Blender Expert? Answer questions, earn points and help others
