Question about Castlewood ORB Internal ORB Drive
Hi : Question about a castlewood external 2.2 gig drive
I've got two castlewood drives, one working fine and the other, inoperable.
I use the drive to back up data from my vs880 EX ( Roland's 8 track hard disk based recorders that were pre- CD burner models ).
Is there a place that repairs the castlewod drives ? I'd rather try to repair than toss it.
thanks ! Jon
  • 298 Answers
Does it do anything? Beep, Flash, Click, Whirr? Might be Power, cable, connector, Drive control IC, Motor, disc, servodata
If I recall this was the Zip and Sygate Killer from back in the 90's
Posted on Jan 17, 2009
Have a simpletech portable drive300 gigs-worked fine with windows xp-new computer has windows 7-suddenly cannot access drive anymore-windows 7 sees the drive but says drive is inacessible
Hi ,
This is neo , When did the setup for win XP the file system would be FAT32 . FAT32 is not supported in windows7. You can format the external drive BUT note the files in the drive will be deleted.
Nov 01, 2010 | SimpleTech SimpleDrive 160 GB External USB...
Mecer wont load wi xp sp2 on 160gig hardrive
The BIOS is seeing the drive but your computer can only see about 120-130 GB of harddrive. If the drive has a pin option to limit it's size you may be able to limit it then install windows but if it doesn't you're back to looking for a smaller drive.
Hope this helps
Chris
Aug 17, 2009 | Computers & Internet
My external drive is no longer consistently recognizing 8.6 gb 2048 byte sector disks. it works sometimes after inserting and ejecting the disks multiple times. when the green light stops blinking i know...
Make sure you are buying the discs labeled DL
The DL stands for dual layer.
If you do not buy the DL you can not have the 8.6 gig write space.
I usually just buy R- DL(not the R+) since R- works on all the PC drives and all the old mac drives.
Jun 28, 2009 | Sony External SCSI-2 9.1 Gb Mo Drive...
Western Digital (wd5000co32) Not recognize by windows xp
is it ur western digital external or internal and you use a converter to connect it as external
Jun 09, 2009 | Computers & Internet
External hard drive disk space
Hi
Is it showing the 300gig in the properties? if yes then try to copy with command mode,If again its given problem then u need to backup your data and format the drive, then try copying.I think it will work.
T.Boopathy
Aug 17, 2008 | Western Digital My Book Essential Edition...
External hard disk
the Hatachi 80 gig looks the same as the 120 gig verbatum 47558
also had the same blue flashing light and no recognition by XP
I open the case and removed the drive from the pc board. cleaned the contacts and reconected the PC board , the fault was oxidisation
May 30, 2008 | Computers & Internet
Bootable drive
check in your bios for setting boot from external device
May 14, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Backup hard drive to an external hard drive
"what the error actually says is, you have either run out of space, or the backup file (.bkf) is too large for this disk. note: if the disk is formatted with FAT32, the maximum possible size for the backup file is limited to 4 gigs."
That error means that the FAT32 file system only allows 4GB files or smaller to be transfered. The chance that the backup file (.bkf) is larger than 4GB suggests that this file is causing your problems. You could try manually copying around that file (selecting all files from that folder except the large one) and see if that works.
Usually you will get many errors copying a drive directly as system files will be inaccessible and whatnot. Your best bet is to limit your copying to "C:\Program Files\" and "C:\Documents and Settings\", assuming you have Windows.
Dec 13, 2007 | IO Magic Corporation GigaBank (I250HD35)...
160 gig external storage
Plug In your external drive! if you have any data back it up!(you said it was new so i assume there little to none) Go to start->run type diskmgmt.msc In the bottom pane look for your external drive! If there is a partition, right click and delete! Now the drive should appear full black on disk management! If not delets any other partitionin the drive. (Make sure you are deleting the external drive partition(s)) Now you can create drives by right clicking on the drive and click create partition! It should bring up a wizard which gives you the option to format, set partition sizes and everything!! If you don't wanna go through all that check out a third party software called Partition Magic: http://www.partitionmagic.com/home_homeoffice/products/overview.jsp?pcid=sp&pvid=pm80 hope this was helpful, regards, babb
May 07, 2007 | SimpleTech SimpleDrive...
Castlewood ORB Internal ORB Drive Logo
101 people viewed this question
Top Castlewood Computers & Internet Experts
David Payne
David Payne
Are you a Castlewood Computer and Internet Expert? Answer questions, earn points and help others
