Question about Kenwood KNA-G510 GPS Receiver
TENGO UN KNA G510, Y NO PUEDO HACER QUE LEA LOS POI PERSONALES
GABE EN LA SD UNA CARPETA GARMIN PARA LOS MAPAS, DENTRO DE LA CARPETA GARMIN ABRI UNA CARPETA POI(EN MINUSCULA) Y DENTRO DE POI GRABE LOS ARCHIVOS GDI. Y EL G510 NO LOS LEE
4 Suggested Answers
Dave Z
SOURCE: KNA G510 update software and add POI file
They either installed it under a seat (easy) or behind the dash (hard). It's probably behind the dash, which means it's gotta be all taken apart. When they were installing the head unit they prolly just stuck it right behind it. So it's basically a pain in the ***. You'd be able to find it by following the wires from behind the unit. I have the same problem, I might just take it to the guy who installed it and have him do it. Call around to different stereo installers, they may charge you like 30-60 bucks to have it done... it's probably worth it considering the pain it is getting the whole dash apart and back together again.
Posted on Aug 19, 2008
SOURCE: codigo de seguridad para ingreso y su funcion
puedo desbloquear una radio kdc-mp522 sin el control remoto
Posted on May 02, 2009
  • 1139 Answers
SOURCE: military and moving to europe
If you were to buy and use this system in the US there would be no problem, but you encounter difficulties when trying to use in europe or Australia. The unit would have to be modified in order to use navigation, dvd playback and radio functions. Only specialized audio outlets would be able to carry out this modification at a cost to you. Usually the cost would be around $40 for the service but as I am from the UK I am not sure who would be able to do this for you, possibly the supplier if it is not direct from Kenwood.
I hope this helps
Posted on Jan 16, 2011
Yo he tenido correo del hotmail por algunos anosa no puedo y ahora no puedo abrirlo. Que necesito hacer?
Espanol no es mi lengua materna, y este sitio web no permite tildes y otros caracteres especiales en sus respuestas. Lea con cuidado.
Cada vez que se pierde una contrasena para un servicio de correo electronico gratuito, la unica esperanza que tiene que conseguir que reiniciar es ir a traves de la pregunta secreta automatizado que ha configurado. Si usted no puede pasar eso, entonces o bien se le ha olvidado la respuesta (o la forma en que fue escrito, o incluso tapones hacer una diferencia) o alguien puede haber accedido a su cuenta y lo cambio, por lo que la pregunta secreta y la respuesta ya no puede ser valida.
He tratado con esto unas cuantas veces para los amigos con los servicios de correo electronico gratuito como Yahoo o Gmail. Es una solucion de compromiso para no tener que pagar por el email ... menos la atencion al cliente.
Si usted tiene una cuenta de correo electronico que no es libre (como los proporcionados a usted por su proveedor de Internet), entonces seria mucho mas probable que ayude a restablecer la contrasena y la informacion de la cuenta, ya que probablemente son capaces de verificar otra informacion de la cuenta, tales como informacion o direccion o algo para restablecerla pago. Se que parece que las cuentas de correo electronico son "libres" tambien, pero en realidad el ISP probablemente incluye la capacidad de utilizar sus direcciones de correo electronico con el precio que ya se paga por el servicio. Yo prefiero las cuentas de correo electronico gratuito (Gmail, Yahoo Mail, etc) personalmente, ya que se pueden utilizar desde cualquier lugar, y aunque cambie de proveedor de Internet o pasar a ir a la quiebra y tener mi internet desconectado, aun asi, tener acceso al correo electronico.
Aug 30, 2013 | Computers & Internet
No puedo instalar el office profesional 2010 trial gratis me sale error 1321 que busque un archivo en la carpeta 1033/PROTTPLN.PPT que no lo tengo y por eso no me deja instalarlo
Para resolverse este problema, instala la serie de la Oficina o el programa en una carpeta que no tiene el Cifra contenido para asegurar los datos que ponen permitido. Para confirmar que el Cifra contenido para asegurar los datos que ponen no son permitidos, siguen estos pasos:
1. Haga clic con el bot?n secundario la carpeta en la que quiere instalar la serie de la Oficina o el programa. 2. Haga clic en Propiedades. 3. En la etiqueta General, el clic Avanz?. 4. En el cuadro de di?logo Avanzado de Atributos, as?gurese de que el Cifra contenido para asegurar los datos verifican caja bajo Compresa o Cifran Atributos son vaciados.
To resolve this problem, install the Office suite or program in a folder that does not have the Encrypt contents to secure data setting enabled. To confirm that the Encrypt contents to secure data setting is not enabled, follow these steps:
  1. Right-click the folder in which you want to install the Office suite or program.
  2. Click Properties.
  3. On the General tab, click Advanced.
  4. In the Advanced Attributes dialog box, make sure that the Encrypt contents to secure data check box under Compress or Encrypt Attributes is cleared.
Dejeme saber si esto le pudo resolver el problema, suerte!
Sep 09, 2011 | Computers & Internet
Tengo un GPS ExploSound EX-5042BT que funciona con IGO, Como puedo hacer para cargarle el programa de garmin porque si bien posee las rutas de la argentina, No tiene los mapas de las ciudades.
tengo un gps marca explosound GX_05S si me podes hacer el fabor de informarme como puedo colocar los mapas de la argentina porque trae algunas rutas gracia MI correo es mimi_dho@hotmail .com espero tu respuesta
Jul 23, 2011 | Garmin nuvi 200W GPS Receiver
Como puedo programar un control de remplaso para tv2?
Hola mi nombre es Kimberly Ecobar con DISH Network. Tengo enetendido que necesita programar su control de remplaso con su T.V 2. Para programar el control tiene que hacerlo desde la T.V numero1, cuando usted se encuentre alli tiene que entrar a la pantalla System Info. Esto se puede hacer oprimiendo el boton de Menu 2 veces en el control #1 o tambien oprimiendo el boton System Info enfrente del recibidor, Una vez se encuentre dentro de la pantalla System Info hacia la parte de abajo tendra algo que dice Primary Remote Address y Secondary Remote Address a la par de esto una cajita blanca que contiene un numero adentro. El procedimeinto a programar el control es el siguiente: oprima el boton de SAT localisado en la parte de arriba hasta que los demas botones se iluminen en rojo una vez esto suceda ingrese un numero ente 1-15 (pero diferente al que se encuentra dentro de la caja blanca a la par de Secondary Remote address) y despues el signo de numero (#) seguido por el boton de record. El numero dentro de la caja blanca para secondary remote address debe de cambiar al numero que usted elijio si esto no secede asi intente de nuevo el procedimiento esta vez oprimiendo el boton de record 3 veces. En este link puede encontrar todo el procedimiento y mas informacion en como programar su control http://www.dishnetwork.com/SupportSection/remote-setup. Si tiene mas preguntas o necesita ayuda por favor contactenos directamente al 1800-333-DISH, gracias y espero esto le sirva de ayuda.
Feb 12, 2011 | DISH Network IR Remote Control
Drivers Sharp al 1642cs para vista 64bits
Ir a la ficha www.sharpusa.com de atención al cliente a continuación, descarga de productos. Categoría de producto elegir impresoras y multifuncionales. para el modelo seleccionado modelo no figuran a continuación, el tipo de modelo en AL1642CS. Para el tipo de descarga a continuación, elegir controlador presión de búsqueda en la parte inferior.
translated by goole
May 28, 2009 | Sharp AL-1642CS Copier
Notebook Sony Vaio VGN-FJ270
La única manera de hacer esto es hacer una recuperación de sistema en el disco, si se asume que esto fue fijada realmente y funcionamiento. ¿si no, usted tiene un respaldo para estos datos?
Oct 23, 2008 | Sony VAIO VGN-FJ270/B Notebook
Donde encontrar mapas ruteables de colombia gratis
amigos.. yo los tengo y se los regalo... los de colombia totalmente ruteables... jhor113@hotmail.com
Oct 08, 2008 | Garmin nuvi 200W GPS Receiver
Necesito todos los drivers asignados para el Acer TravelMate 3010 (3012WTMi)
https://www.acer.com/ac/en/US/content/support for drivers and support
Mar 07, 2017 | Acer Cameras
Can not unlock mapsource due to lost unlock certificate
Dear friend, excuse my mistakes in writting, since long ago I dont write.
Download this file:http://chilestreets2007.googlepages.com/archivos
todas las partes del Archivo Chilestreets 2007 working.rar
A.- Instalar Mapsource Chile Streets Setup.exe de la carpeta Mapsource + ChileStreets
B.- Usar el serial contenido en la carpeta Mapsource + ChileStreets\serial
C.- Conectar el dispositivo GPS
1.- Obtener el ID del dispositivo Garmin: es un un número de 10 dígitos.
- Iniciar Mapsource desde el PC
- Conectar el GPS
- Ir a Utilities, Get Unti ID.
2.- Abrir Keygen v1.3.exe
- Ingresar el número de 10 dígitos del ID de dipositivo en el primer espacio en blanco (Enter you Unit ID here:)
- En el cuadro Select Map Product:, selecciona de la lista <Custom Mapset>
- En la ventana emergente anota 724 para el MapID code.(ok) el código varía para otros mapas, este es para el Chile Streets.
- Haz click en el botón "Generate" de más abajo. Con esto se crea el código de desbloqueo que se ingresa en el Mapsource. (No cierres esta ventana)
3.- Abrir la utilidad de desbloqueo de mapas del Mapsource.(CTRL+U):
- Haz click en siguiente.
- Selecciona la opción "Si, tengo un código de desbloqueo de 25 caracteres" (Siguiente)
- Selecciona la opción "tengo un código de desbloqueo de 25 carcateres; lo escribiré" (siguiente)
- Introduce el código suministrado en el paso 2. Puedes anotar un comentario de recordatorio en el recuadro inferior pra saber que unidad es la que tiene el mapa desbloqueado. (siguiente)
- Selecciona la opción "No, me registraré mas adelante" (siguiente)
- Selecciona "Sí" en la ventana emergente.
- Selecciona No, he terminado si no quieres instalar más códigos. (siguiente)
4.- Transfiere los mapas al dispositivo o a la tarjeta SD, Mapsource transfiere los códigos en forma automática.
Please translate this procedure. The important matter for you is that you now have mapsource active and with de Keygen v1.3, you can unlock a lots of maps. Please don´t publish this solution, because a lots of people would not have access in the future to this program.
Nov 26, 2007 | Garmin Touch Screen GPS Receiver
Kenwood KNA-G510 GPS Receiver Logo
Top Kenwood GPS Experts
Michael Galve
Michael Galve
Mike
Are you a Kenwood GPS Expert? Answer questions, earn points and help others
