Question about Electrolux E30EW75ESS Electric Single Oven
Electrolux oven (E30EW75ESS3)
I am having some performance issues with the oven as it takes an incredibly long time to pre-heat (30 min+).
2 Suggested Answers
SOURCE: Electrolux Icon Mystery issue
Check to be sure your racks are all slid in to the back. Are you getting a error code?
Posted on Dec 25, 2007
Hi my parents have a 10 year old Electrolux oven eob63100k it works for about 50 mins then turns itself off and after approx 15 mins comes back on again all by itself any ideas?
Thermostat issue when it reaches heat its set to it should turn off and then come back on when it drops below that temp
check if thermostat is clean
Sep 26, 2017 | Electrolux Ovens
My Electrolux oven isn't working right, when I turn it to the light bulb symbol the fan cuts out and it doesn't heat up. However on fan it seems to be heating up, I've never cooked on fan before, will it...
I appreciate your post, friend!
I understand that you are having issues with your Electrolux oven not operating properly. From what you have described it sounds like you could have a short within your control panel, keypad, or wiring harness. In order to properly locate the problem and repair it you would need to have the appropriate tools and understanding on how to disassemble your range. This is not a simple DIY job. I would recommend having a professional technician out to perform a proper diagnosis and repair. This will help you avoid any future issues and personal injuries. I hope this information is helpful to you. -Matt
Mar 13, 2015 | Electrolux Ovens
Top part of oven not heating up
Thank you for your post, friend!
Based off what you have described your Electrolux double wall oven is not heating up inside the top portion. It could be a miscommunication within your oven and you can usually perform a reset to clear that out. In order to reset your oven you would need to flip the household circuit breaker off for roughly ten minutes. If you restore power and continue you having an issue with your oven I would suggest you could have a possible fault with the control panel, thermostat, element, or connectors. Typically, this is not a simple DIY job. You may need to look for assistance with replacing any electrical components and I would highly suggest having a professional technician help with that. Hope this is helpful. -Matt
Feb 23, 2015 | Electrolux 30" Built-In Double Electric...
Why my ew30ew55gs5 have no heat and all the light and function work.
Electrolux Customer Phone Number Shortest Wait Best Support
  • Talk to a Human Press 2 then 1. For kitchen and laundry appliances
  • Call Time
    Average Wait: 37 mins - Monday-Saturday, 8AM-9PM (EST)
Electrolux Calls You Instead Electrolux Calls You Instead
I would contact them first before you waste any money.
Jan 21, 2015 | Electrolux 30" Built-In Single Electric...
No heat from my Electrolux oven fan is running but oven light not working the oven is only six months old
Thank you for your inquiry, friend!
Based off the information you have provided your Electrolux oven is not heating properly. I would recommend performing a reset on your range which you can do by disconnecting power from it for ten minutes. If that does not help to correct your issue it could be a faulty element or control panel. I understand your range is only six months old typically the warranty for a range is one year. I would contact the manufacturer for proper resolution regarding a warranty. I hope this is helpful. -Matt
Oct 17, 2014 | Electrolux Ovens
BOSCH HBL3450UC Single Oven weak/slow pre-heat
I have a Kitchen Aid convection wall oven. It takes 6 - 7 minutes to preheat to 325 degrees. You probably have a bad element. There are 2 elements.
Dec 19, 2012 | Bosch HBL3450UC Single Oven
Oven is taking to long to heat
look for the temperature sensor inside the oven cavity in the upper left or top center of the upper oven cavity,its will be a silver or copper colored rod about 1/4" by 2" to 6" long this rod senses the oven temp and cycles the heat to the oven
Jun 03, 2012 | Kenmore 30464 / 30465 / 30469 Gas Single...
Have a viking professional oven and it takes too
A weak oven ignitor will cause this problem. even though it eventually lights the temp has dropped considerably so you don't get consistent temp. turn the oven on and listen for the burner to light. should light within about 2 minutes. if not replace oven ignitor(s)
May 20, 2010 | Viking 27" Professional Select Built-in...
Ovens Logo
133 people viewed this question
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
