Question about Maytag Dryers
Dryer won't spin
I have a Maytag Performa Dryer. Model PYGT244AWW. It was working about 10hour go. I go to dry my clothes and it wont spin. It makes noise that it is working but It sounded a little funny so i opened the door and pressed the button to make it spin. Nothing. How a fix this?
    New Friend:
    Problem Solver:
  • 7 Answers
If you have kids and they over fill the dryer it strains all systems including the heater because it cannot get rid of excess heat. Solution*** Possibly needs a new belt
Posted on Dec 07, 2012
  • Randy Kluber Apr 15, 2014
    It sounds like your drive belt has broken or come off the motor pulley. Time to service the dryer and replace the belt, possibley rollers and felt slide also. A professional can do this for you or you can buy the kit at a local appliance parts store or online if your a mechanically competent to do so.
dididsaythat
  • 291 Answers
SOURCE: Kemore Dryer will not start
I would check the voltage and the dryer where cord attaches to dry to make sure you havt 220volts... check you door switch... also you have a thermofuse in back .. check for burn off wires or lose wires.. make sure dryer is unplugged... the thermal fuse with be white plastic oval in shape on the blower venting with 2 wires.. here is a pic if it uploads
Posted on Sep 05, 2007
dinomb
  • 16 Answers
SOURCE: Maytag Electric Dryer Stopped Working
Check spring tab behind door switch-if it's bent/out of adjustment, circuit will act like door is always open.
To confirm this, open door, set dryer to active setting, and hold in door switch; if it comes on, then it's either the spring tab, or the switch is malfunctioning
Posted on Mar 30, 2008
  • 4 Answers
SOURCE: maytag atlantis dryer model # mde6400ayw
sounds like the timer is not completing the cycle in this mode will the dryer shut off if you manuelly advance timer in that mode
Posted on Nov 01, 2008
  • 686 Answers
SOURCE: Maytag Neptune Dryer making vibrating noise while working
a bearing in the back for your drum sounds like what you describe. It needs to be taken apart and the bearing lubricated with high temp grease
Posted on Feb 23, 2009
  • 77 Answers
SOURCE: Dryer not heating as it should. Gets warm, but takes several cycles to dry clothes
Could be 2 things... either your heat source is out of repair or your vent is blocked. Since you say it only gets warm I'll assume the problem is with the gas coils inside the unit. These parts are replaceable
Posted on May 12, 2009
Maytag model #: med5770tq0 won't dry. Please help
Dear Emily.
Several problems.
First, did this dryer ever work properly hooked up as it is?
I mean hooked to the roof event?
If it used to work just fine, then I suspect the vent to the roof is clogged with lint and is not allowing the heat to escape.
If it never did work right,(for example: it is new to us) then I'd venture dryers are not supposed to vent their hot air that far away, they do not have a strong enough blower to push that air that distance.
Then, you might try to find another place to vent the hot air, with a total distance of only 10 feet from the dryer, even if you only vented it while you were actually drying clothers.
I doubt if the last item is for you, but I have sometimes seen where the washing machine did not spin all the water out of the clothes, and then the dryer needed all day to get the clothes dry.
Be blessed.
Apr 17, 2013 | Maytag Dryers
My Maytag Performa dryer makes a loud scratchy noise while drying. What is the noise and how do I fix it?
My Maytag Performa gas clothes dryer makes a scratching noise for the first few minutes when turned on, then it goes away.
Jun 01, 2010 | Maytag Performa PAV2200
Not getting hot to dry. My dryer is not drying the clothes
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 20, 2010 | Maytag Performa PAV2200
My Maytag Performa dryer is taking 2 and sometimes 3 cycles to dry clothes. Suggestions as to why?
Most of the time the dryer blower wheel part number 53-0106 gets loose and and cause this problem. I fixed one just the other day.
Feb 24, 2010 | Maytag Performa PAV2200
Machine works but does not dry cloth no hot air drum? maytag performa
Chek closely all the tube going from in to out of ur dryer clean all ur filter even the furnace oune! check ur wirring, if all faisl dry nothing in ur machingr for one cycle. they wil { i hpoe
Nov 19, 2009 | Maytag Performa PAV2200
Maytag electric dryer is drying inconsistently.
you may need to check the lint trap and clean it .. also try cleaning out the dryer vent... if this doesnt work , try changing the drine belt...
good luck
Oct 12, 2009 | Dryers
Maytag performa intellidry dryer model#PYE4500AYW
Check drive belts. If too loose or too worn it will not spin at proper speed.
Mar 27, 2009 | Dryers
Spinning fast and furious, just doesn't wring clothes dry
It sounds like you need a water pump!
See if it's pumping water next time you do load by looking at the discharge hose going to the drainage pipe and get back to me!
jack
Feb 21, 2009 | Maytag Performa PAV2200
Maytag dryer won't heat up
i am having the exact same problem with this model as well just happened 4 days ago.
Mar 18, 2008 | Maytag Performa PAV2200
Dryers Logo
160 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
