Question about Polaroid Z340 Instant Digital Camera with ZINK Zero Ink Printing Technology
How to charge battery for Z340
I can't figure out how to charge battery for Z340
Why does my Polaroid z340 can t print?
On page 52 of the manual it says, press print to enter the print menu or when you want to print the last picture you took, press the print button twice.
May 02, 2014 | Polaroid Z340 3 X 4 inch Instant Digital...
I cannot close the battery compartment
Are you sure you did put in the battery correct and not the wrong way around? could be a mechanical block, to avoid damage to the camera, by wrongly placed battery.
Mar 20, 2014 | Polaroid Z340 3 X 4 inch Instant Digital...
Frezes every time i try and print
Did you try to charge the battery. For printing the battery, needs enough power. If the camera senses there is not enough power to print one complete picture, it will shut down. Sometimes you could shoot 10 or 20 pictures, but you can't print one picture, for the lack of power.
Feb 13, 2014 | Polaroid Z340 3 X 4 inch Instant Digital...
Hooked up battery backwards on my 1992 ford explorer. Got it running now the alternator isn't charging the battery. Has 12 volts power. Could it be the points on alternator where the wiring hooks into...
The battery needs 12.6 volts or more to be in service
When the engine is running you need 14 volts or more
out of the alternator to charge the battery
You can test the alt by testing across the battery term
or the alt output wire & ground to case or motor
Could be the diodes got fried & you need a new alt
Have it tested at parts store, if you can't figure it out
Check all fuses & fusible links first
Jul 26, 2013 | Cars & Trucks
Electrical short?
Not a short.
Either the circuit to the battery light is bad, or the fuseable link on the starter solenoid is toast. There is a 30 amp fuse in addition to the fuseable link, plus a 15 amp fuse on the circuit for the battery light.
All of these circuits need to be tested.
Aug 30, 2012 | 1993 Mercury Grand Marquis
How long do you charge battery after you've done initial charge
a good rule of thumb is one hour for every amp hour that the battery is, so if its a 12ah battery then charge it for 12 hours
Jul 14, 2012 | Fisher Price Fisher Power wheels Cadillac...
2010 Elantra Touring - car won't start - doesn't turn over (battery is fully charged), clock/radio & A/C units don't work, and EPS doesn't work. Dealership cannot figure it out.
sounds like a fuse. check them and get back to me. If the shop you took it too cannot figure it out they probably should not be a shop. i hope they didnt get you for a diag fee. Im going to locate a wire diagram to help you figure this out.....Also you said you put a new battery in the car, check that the battery terminals are clean and tight.
Oct 06, 2011 | Cars & Trucks
Hello.I've got an Asus K52JE.Today I looked at the
97% isn't that bad, it means that your battery is fully charged but not the whole way. That is bound to happen specially when youre using youre battery a lot. It will get a lot more lesser in the future the more you use youre battery.
The standard laptop battery starts losing the ability to hold a charge after 300 recharges or cycles. If you drain your battery almost completely at least once a month and then recharge it, it will last longer & hold a full charge longer.
Jul 09, 2011 | ASUS Computers & Internet
Given a hand me down Dexton Lil Driver Battery Golf Cart. Is there an online manual to find out what the charging cord looks like & where to plug it into the cart.
To charge... you need to remove the seat. Only 2 screws holding it in place. Underneath you will see the battery...you will notice wires from the battery connect to wires from the motor on the wheels...pull apart those 2 connectors and attach the charger...then plug it in to a wall socket and leave connected for a long period of time. I don't remember how long it takes for a full charge...but I'm thinking at least 12 hours. If the battery doesn't hold a charge you can typically get it at walmart or online. Best of luck.
Jan 30, 2011 | Toys
Polaroid Z340 Instant Digital Camera with ZINK Zero Ink Printing Technology Logo
577 people viewed this question
Top Polaroid Photography Experts
Joseph Coppeto
Joseph Coppeto
Duke Mcadams
Duke Mcadams
Level 1 Expert
Are you a Polaroid Photography Expert? Answer questions, earn points and help others
