SOURCE: Cisco 1841 router
You can ID the cards by seeing if the card has "V2" on the metal plate. I believe an 1800 chasis requires a V2 card.
SOURCE: I am trying to connect
If you are using the cd that comes with the router, that is the problem. You do not have to use the cd. Go to the control panel and un-install the program that the cd installed. then: If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year! Thanks, Joe
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider. If you have DSL, the router needs to be configured with PPOe.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: I have tried connecting Cisco linksys router but
Use an Ethernet cable to connect from the network-port on your computer to one of the LAN ports on the router.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
You should see output like:
IP Address. . . . . . . . . . . . : 192.168.1.100
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
if the router has self-configured, and is ready for "wired" usage.
Then, start Internet Explorer.
Type http://192.168.1.1
Press Enter
Login to the web-server "inside" the router
Click to run the "Wireless Networking Setup Wizard" to configure it for "wireless" usage.
SOURCE: My Cisco Valet M10 loses connection to the
try to update the Firmware of the router. You can do this by opening the Cisco Connect Software under all programs. It should ask for an update when it initializes, if not then power cycle your network.
SOURCE: i need my security code
Welcome to Fixya. If you need you Security Key or Password (Network Key) on your router you need to access the Wireless Settings Page. To access the router page you need a working computer that is connected to the router. To access the router page just open a browser then type 192.168.1.1, the Default username is admin and the password is admin. Go to the Wireless Settings and you'll find the Network Key or Passphrase (Security Code). You can alsoThen Personalize you Network Key or Passphrase so that you can easily remember it.
Thanks for using Fixya.
