Question about Whirlpool Washing Machines
Whirlpool washer won't respond goes into to diagnostics all buttons and dials check out no f codes
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
What is the complete model number of the unit?
Posted on Dec 07, 2012
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool Duet Washer will not start
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
KevinWhite
  • 1902 Answers
SOURCE: washer won't start.....F70 code appeared It's
Hello & Welcome to FixYa
F70 is a communication error which is caused when no communication is detected from the user interface to the CCU (central control unit). Please check the wiring to user interface and the central control unit, if that is fine and you can see the drum rotating then replacing the user interface is recommended repair. If the drum won't turn then the CCU needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on Jun 26, 2011
Daniel S
  • 4323 Answers
SOURCE: Have a Kenmore Elite Sensor
Hi
First make sure that nothing is blocking the drain pump assembly located inside the lower front panel of the washer. If the issue returns after its cleaned then it means that the control board has gone bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Jul 07, 2011
Jahn27
  • 1554 Answers
SOURCE: Whirlpool imperial series washer will
The problem is obviously the lid switch which now have got broken totally The only viable solution then is replacing the lid switch. Unplug the machine or disconnect power then release the console from the top of the cabinet by removing the screws securing the rear of the console. Pull forward and up on the console and lay it back on the hinges.
Disconnect the lid switch harness connector by pressing on the tab located in the middle and pulling it up.
The cabinet is attached to the rear of the washer by two brass-colored retaining clips. Insert a flat blade screwdriver into the turned-up edge of the clip, located on both sides, and then pry back to release the clip from the slot in the cabinet.
Open and hold the lid while grabbing the cabinet front opening then tilt the top of the cabinet toward you by pulling the cabinet away from the base. This releases the front and back slots of the cabinet from the tabs in the front and back of the base.
Using the side of your leg and/or body as a support for the front of the cabinet, carefully lift up the cabinet and lay the front on a cushioned floor to access the lid switch.
Remove the lid switch ground and mounting screws then release the wire harness from the metal retainers. Pull the lid switch connector out and install the new lid switch in reverse order of the removal steps.
Bring the cabinet to the front of the washer then slide the front bottom rail of the cabinet under the rail at the base of the machine then lay down the cabinet into position. Make sure the slots in the cabinet sit into the tabs at the base of machine. Reconnect the lid switch harness then push the retaining clips back down into position to secure the cabinet to the rear of the machine. Reinstall and secure the console to complete the repair.
Please accept the solution should you find it helpful and/or informative. Accepting the solution will not stop you from posting comments or additional information. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Posted on Aug 04, 2011
  • 1417 Answers
SOURCE: My Whirlpool Calypso Washer, model#GVW9959KQ2,
Hello.
The Whirlpool Super Capacity Plus washing machine offers alarge capacity drum, temperature control monitoring, two-speed motor, fivewash-and-spin combinations, 10 total wash cycles, three wash temperatures, anda quiet-wash feature. The washer should function well if standard care andmaintenance is followed, but issues may occasionally occur. One such problem isif the washing machine is noisy and does not spin during use. While this mayrequire professional repair, individuals can attempt troubleshooting beforecontacting Whirlpool repair technicians for help.
Steps to follow.
1Stop the washing machine and open the lid. Take items out if the load isvery large, or move items around the washer if things have become tangled orbunched together.
2 Look for objects that mayhave gotten caught between the inner and outer tub. Turn off the washingmachine and use a pair of pliers to pull the object free.
3 Push the basket into themiddle of the unit if it seems to be off balance. This can occur duringoperation or while loading items into the drum.
4 Examine the feet on thewashing machine. All four feet should touch the floor; adjust the feet if theyare uneven.
5 Close the lid on the washingmachine and verify that it latches shut; the washer may malfunction or not spinif the washer lid is open.
6 If troubleshooting does notwork, contact a Whirlpool repair technician for assistance, as the lid switch,motor, pump belt or pulley may be broken and require professional repair.
Thanks.
Posted on Sep 22, 2011
Whirlpool duet fw95hedco washer won't spin at max speed & leaves all clothes wet. No error codes during tech diagnostic visit. Washer only 18 months old.
Possible Defective washer transmission. Do you overload the washer with heavy items like towels or blue jeans very often? That can cause early failure.
Feb 16, 2017 | Whirlpool Washing Machines
Cabrio washer won't fill normally but diagnostic shows valves are fine
when doing the diagnostic testing machine fill up almost full and stop display an ol mode
Apr 17, 2013 | Whirlpool WTW6400SW Cabrio Washer
Whirlpool WFC7500VW1 won't start
My Whirlpool washer model WFC7500VW1 will not start--the green Start button keeps blinking and the red Door Locked button keeps blinking. I do not get any error codes.
Feb 23, 2013 | Whirlpool duet Washing Machines
My 6 year old Whirlpool Sport Duet washer will rarely stay running for a whole cycle. The power switches on and off on its own...it adds extra rinse cycles and won't allow you to turn them off, it...
I Agree, I don't think it is any other board, I believe the CCU (central control unit) has gone bad as it keeps on stopping mid cycle. If it was the Motor Control Board (MCU) then the washer motor should have been causing problems (which isn't the case) so replacement of CCU will be a great option. Please get back to me if you have any other questions.
Kevin
Sep 23, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't start.....F70 code appeared It's a Whirlpool Duet
Kevin
Jun 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool cabrio is giving a code which is f1,
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 05, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Control locked light is on and washer won't turn on. Can press "Control On" and Cancel/Pause buttons at the same time to get the power on but won't start.
Looking at the manual of my Whirlpool front loader gives me the following advice...
CONTROL WON’T ACCEPT SELECTIONS
1. Press PAUSE/CANCEL button on the touch-pad twice.
2. Drain the unit, then check that the drain hose and drain
pump filter are clear of foreign objects.
3. Check the touch-pad/LED assembly by selecting different
cycles and changing the modifiers and options available to
confirm the touch-pad/LED is responding.
4. Unplug washer or disconnect power.
5. Check harness connections.
6. Plug in washer or reconnect power.
7. Verify CCU operation by running a Diagnostic test or any
cycle
BTW: The full manual is at http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208182208.pdf
Mar 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F1 Error Code On Whirlpool Cabrio
Jun 03, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool dishwasher won't start
I have had the same problem with my dishwasher. I.e., the buttons don't respond (no LED) when you press them. Only the "Cancel/Drain" light works and the dishwasher reacts to cancel/drain. I found a diagnostic in the kick panel that has you press; "heated dry, normal, heated dry, normal" within 6 seconds and the washer goes through a diagnostic. All of the tests perform as they should and at the end the washer works again. I don't know why unless doing this resets the circuit board. Does anyone know?
Jan 04, 2009 | Whirlpool 24 in. DU1100XTPS Built-in...
Washing Machines Logo
32 people viewed this question
Dan Webster
Dan Webster
Sal De
