Question about Gateway FPD1960 19" Flat Panel LCD Monitor
Monitor screen will not turn on when I boot up
I connected my computer to the monitor after it was stored away for several months When I switched on the computer the monitor failed to turn on.
    An expert who has written 3 tips or uploaded 2 video tips.
  • 214 Answers
Try checking the power cable
Posted on Apr 11, 2009
My hp dv5215us laptop monitor broke several months ago. I've been using the computer with an external monitor plugged in to the vga port, but I turned it on today and the external monitor isn't...
Hardware failure of the motherboard - most likely something went wrong with the northbridge.
The repair will cost way more than it's worth, this laptop is effectively dead, time for a new one
Jul 20, 2011 | HP Pavilion dv5215us Notebook
After several hours of inactivity, the screen on my SyncMaster 192n goes black, and the only way to turn it back on is by hard re-booting my computer. Sometimes even ctrl-alt-del doesn't work, and I have...
My guess is your video card driver has been altered and is causing the problem. Try rolling back the driver before reinstalling the monitor. Here is a link to the manual for your monitor:
From the above manual: "The PowerSaver system operates with a VESA DPMS compliant video card installed in your computer. Use a software utility installed on your computer to set up this feature".
Mar 18, 2017 | Samsung Syncmaster 192N 19" LCD Monitor
Is it possible to bypass the built in screen monitor(compac 7770 DMT) and connect to another computer monitor. I bought my laptop at the local goodwill store and the monitor just looks like wet splatter....
1) connect your external monitor to the 7770DMT and switch it on
2) boot up the laptop
3) after it has successfully booted, you need to identify which function key toggles the external monitor on/off
4) you should be able to do this by holding down the Fn key and trying each of the F keys in turn, waiting a few seconds after pressing each one
5) begin by holding down "Fn" + "F3", "Fn" + "F4", "Fn" + "F5" etc.
Oct 18, 2010 | Compaq Armada 7770DMT Notebook
I have an Envision monitor. For a couple of
jbfrmga1, It's possible that you or a qualified electronics technician will need to open the monitor and inspect the printed circuit boards for the ONE and ONE only "bad and thermally intermittant" solder joint and resolder it. You may need large magnifying glass or low power 8x to 20x inspection microscope to locate the "thermally-fractured" solder joint of an active or passive electronic component that has become intermittant on the "switch-mode-power-supply/ccfl inverter board. To prove problem is inside lcd monitor, move (connect) "cold" monitor to an already fully booted pc with the WIN-desktop screen already displayed on a good monitor. 12fixlouie
May 18, 2010 | ViewSonic VX924 19" LCD Monitor
Monitor won't start when I boot up - without a lot of fiddling!
First try to do monitor self test.Disconnected the blue cable VGA or white colour connector from monitor to the computer. Turn on the monitor and check if you are able to see colours or line on the monitor.Indicating self test monitor is working fine. If you are using Video card on computer connect monitor directly to onboard video and check. Good Luck.
Aug 19, 2009 | Computers & Internet
I bought a belkin cable a couple of months ago in order to switch between two pc,s on one screen.Unfortunatly i forgot which buttons to press on my keyboard to switch screens can you help please
I may be behind the times but this is how I do it. Get a monitor data switch ($5-$10 used).On the back of the switch, connect each computer to input ports & the monitor to the output port. Set the knob on the front of the switch to each computer as you boot it. Turn switch to each computer as needed. You will have to turn a knob instead of pressing a key. If you can live with that it works great.
Dec 14, 2008 | Belkin Computers & Internet
Sylvania (proview) cl2072b flat panel monitor
Well the first and second paragraphs make me say the Inverter/power board must be replaced.
A white display typically means either your display cable (in your monitor) is loose or logic board is dead.
Either one of these things typically mean take it in for an estimate to repair, and if it's too much, buy a new one.
With your luck I think I might switch to big cheap CRT.
Mar 12, 2008 | Proview PL926WBi 19" LCD Monitor
Auto adjustment.
Try this one:
the is not the same problem. But the cause is exactly the same
Jan 28, 2008 | Neovo F-417 17" LCD Monitor
Screen not appearing straight away
It could be your LCD backlight giving you problems till it warms up. Turn you computer on and while the monitor is displaying black and the power LED is green shine a flashlight in the lower left hand corner of your screen. Look for the ?Start? button, if your backlight is not working you?ll see a faint ?start? button if you look closely. A 15" LCD monitor is probably not an economically repairable problem unless you have access to really cheap parts and have the skills and tools to do the repair yourself.
Jul 29, 2007 | AOpen F55PS (Black, Silver) 15 in. Flat...
Gateway FPD1960 19" Flat Panel LCD Monitor Logo
228 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
