Question about Polk Audio I-Sonic System
How to disassemble polk I-sonic
A customer of mine wants me to try and fix what seems like a power supply problem. I've gotten the DVD drive out and removed all the other screws. I don't want to cause any cosmetic damage, what's the secret to getting to the power supply?
4 Suggested Answers
joshter32
  • 82 Answers
SOURCE: if the power light on this 1200.1 polk amp turns
i had an amp that did the same thing your amp should not be doing that i dont know how old it is but mine had internal overload switch in it which kicked on if the amp was getting to hot and in my case i would say it was because of i had the amp bridged to a set of of some 100rms 4ohm speakers very nice speakers but by bridging the amp i was over loading the ohm load to the speakers and that was cause of my amp light staying the color that its was it was an old alpine amp with duo B circuitry but i hope you get your situation with this amp straited out check your contecions and if its bridege make sure the amp itself is not over heating cause that can be a problem you dont want mess with that.
Posted on Oct 30, 2009
TheMobilian
  • 8220 Answers
SOURCE: how do you remove the bottom 2 screws on the power
LG dryer
Posted on Mar 12, 2011
TechAll
  • 99 Answers
SOURCE: I have an HP Pavilion
if it requires 9volts then it should be good. no problem with your windows vista. its just that your speaker wont power on. maybe you got to have the wrong polarity. try to recorrect the polarity. i mean put the negative to possitive and positive to negative. if the wire has a color put the black to red and red to black.
Posted on Jul 11, 2011
What could be the issue with my sub woofer power?
Many of these SUB amps ended up with Capacitor failures in the Power supply section . Find someone who works on amps or TVs to have a look see.
May 26, 2014 | Polk Audio Polk DSW PRO 550WI Subwoofer
Denon dvm-1815 changer drawer won't open. Stuck.
Hello
There is a belt that drives the chager tray. It is engaged with its loading motor pully and gear set that drives the tray mechnism. To replace the belt, you have to disassemble the mechanism. Actually it is a skilled work, and without knowing its disassembly method, it is almost impossible to repalce the belt by yourself. I've the dissasambly and reassembly method, described wiht help of pictures and all other details. If you have an interest to get it, you have to buy one amoung my audio services, advertised in Fixya site. Unlike previous Fixya site, this new site is different. With old site, I've the facility to send you pictures and PDF files, but with the new, I can't send any of such documents to you.
The document I've with me is an original published by Denon, Japan.
If you want to do this work by yourself, and want to get this document, do the needy. OK.
Nov 23, 2011 | Denon DVM-1815 Multi-disc DVD Player
Wont play xbox game disc
Make sure the disc is clean, if its clean, and works in another 360. Disassemble the 360, open the dvd drive up, shoot some canned air in there but NOT on the laser, clean the laser with some rubbing alchol of at least 91% and a q-tip then put it back together if this doesn't work you will need to buy a replacement laser off of ebay. And here is a link on how to disassemble the 360: http://www.rrodfix.com/how-to-take-apart-the-microsoft-xbox-360-game-console.html Just make sure to stop when you've gotten to the part about the DVD drive, then disconnect the DVD drive, and take it apart. Best of luck.
Oct 23, 2011 | Microsoft Xbox 360 Console
Bose 321 II dvd drawer won't open, fixes here & elsewhere not working. I put in a recorded dvd. It tried to read it, & never gave me the not supported msg as I started trying to eject it...
Hi Donna,
Please do be frustated.
Your lovely Bose has problem with its mechanism that cause load / unload totally out of order. If you hear some noise while you turn on the bose or when you hit some buttons, it is telling us the motor still work. Now we need to check the broken gears ( or other mechanism linkage).
If you able assemble this Bose, go ahead to find and fix it mehanism ( you may need some parts replacement.
Note : Be carefully with its laser lens while power on ( avoid direct contact to your eyes).
Best luck,
Jay
Sep 26, 2011 | Bose 3 2 1 GS Series II DVD Home...
I have an HP Pavilion M50 monitor with polk audio speakers. I don't have the original power supply for the speakers. I have tried several 9v power adapters and none of them seem to work. What power...
Jul 11, 2011 | Polk Audio AMR50 Computer Speakers
Service manual for polk i-sonic
U CAN CAN PRODUCT CATALOG BUT NOT SERVICE MANUAL
BELOW IS SITE FOR PRODUCT MANUAL
http://www.polkaudio.com/downloads/catalogs/2008/I-Sonic%20ES2_Series.pdf
Dec 15, 2010 | Polk Audio I-Sonic System
My polk psw404 has no power, I check the fuse at power source
Could be the power supply but the transformer may
have opened up due to a "surge". Might have to contact Polk to see whats up and/or dealer as the
amp may need sent in for repair!
May 24, 2010 | Polk Audio PSW404 Subwoofer
If the power light on this 1200.1 polk amp turns
Oct 27, 2009 | Polk Audio PA1200.1 Car Audio Amplifier
Problem with starting
read on a forum that changing out c316 1000uF will fix the problem, mine will not turn on now, seems to have gotten worse over time. I will change the capacitor from 1000uF 10v to 1000uF 16v.  Look at your capacitor, mine looks like its ready to blow.  Most other capacitors on the board are rated at 16 volts.  I will be changing out the cap. to see if it works.
Oct 05, 2007 | Philips DVP642 DVD Player
Polk Audio I-Sonic System Logo
81 people viewed this question
Top Polk Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
ed_dantes
Level 1 Expert
Are you a Polk Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
