Question about HP Pavilion A610n (PC106A#ABA) PC Desktop
Power Button sticks does not always work - HP Pavilion A610n (PC106A#ABA) PC Desktop
  • HP Master
  • 7,627 Answers
Open the case, You will see instructions to Remove the front panel, locate the plastic retainer on the rear of the button, sometimes it will break/stick, free the obstruction, clean area of dust, lightly apply some silicon spray. Here are some HP user guides that may assist you: http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lc=en&product=425994&
Posted on Dec 07, 2012
Why i cant find power button
There are always buttons on the bezel.they wont be on the back. Not likely on the bottom unless an area sticks out.they will be flush and same color as bezel so hard to see but easy to feel. Run your fingers along the sides and top,bottom if it sticks out anywhere. What model tv do you have?
May 13, 2014 | Sanyo 42 in. LCD TV
Tip
Sony Memory Stick Formatter Software If your Sony Memory Stick has stopped...
If your Sony Memory Stick has stopped working in your digital device,
Sony's Memory Stick Formatter Software may be able to format your Memory Stick in a more compatible way for your device.
Compatible operating systems include:
* Windows® 7 Starter / Home Basic / Home Premium / Professional / Enterprise / Ultimate
* Windows Vista® Home Basic / Home Premium / Business / Ultimate
* Windows® XP Home Edition / Professional
* Windows® 2000 Professional
Preparation
* Confirm that the write-protection switch of the Memory Stick is set to the "Write enable" position.
* Insert the Memory Stick into the Memory Stick slot of the device or computer.
* If you are using a file recorded on Memory Stick with another application, quit the application before beginning the formatting process.
The Format Process
Note: Formatting will erase all files in the Memory Stick. Always double-check the Memory Stick contents before formatting to prevent loss of important data.
* To start Memory Stick Formatter, click Start->Programs->Memory Stick Utility->Memory Stick Formatter.
* At the "Drive List" screen, click to highlight the drive letter that represents the Memory Stick device/slot.
* Click the Start Format button.
* At the "Warning..." screen, confirm that you wish to format the Memory Stick, and click OK. Note: To quit the process, click the Cancel button.
* Do not remove the Memory Stick from the Memory Stick slot during formatting, as this may cause corruption.
* At the "Format was successful" message, click OK.
* To quit the Memory Stick formatter utility, click the Exit button.
Download the Sony Memory Stick Formatter Here.
I hope that helps.
____________________________________
Click here for Sony's Memory Card File Rescue software.
on Apr 18, 2010 | Sony Cyber-shot DSC-H7 Digital Camera
Screen and display is always shaking
Check the home button maybe its stick with something making it on always, try to clean the button.. unless you don't know how to stop shaking the apps its with pressing on home button..
Mar 24, 2014 | Apple Iphone 4 - 16gb - Black factory...
My galaxy y lock button have a problem. Whenever i press it always restart. Please help me
if you are able to access the system, try resetting the device back to factory settings.
If this doesn't work it is possible you may having a sticking contact on the power button. The device will have to be disassembled in order to be cleaned.
Nov 01, 2013 | Cell Phones
Problems at powerup
Code 7: joystick problem. Be sure joystick is in center position when you power up. If rubber boot is worn out, replace it or repair it so that stick is in center position. Always check connections.
Mar 11, 2013 | Pride Mobility Products Jazzy 1170 XL Plus
The only button that works is the remote power button. None of the buttons on the side of the tv work. The volume bar is always visible. The picture works when I'm watching a dvd, but the volume bar is...
Hi check to see if the volume button on the side is pushed in or sticking as this will cause all the buttons to not work as the micro thinks you are trying to turn up the button and thinks this button is depressed.
Dec 23, 2010 | Vizio VW22L 22 in. LCD HDTV
MY Gateway GT4016 Will not start anymore, i first replaced the power Suply and nothing happened. the fan runs and a light blinks then it shuts down again, i used to start it by just pressing the button and...
Make sure all fans are running power supply one to hehe Maybe a bad power button? I had a gateway that did some thing very close to that because the cpu fan was not turning and a hp that did that because the power supply fan was not turning. Thats where I would start then make sure the mem is seated good and not bad you know the drill ;) if you replaced the power supply with a factory replacment it should be a voltage or wattage problem. Might also try a hard boot the power plug take the cmos bat out hold the power button down for 20 or 30 secs some people say to leave the cmos bat out and try to fire it up. I know that works on some laptops but I always had better luck putting it back in for desktops cant hurt to try it. If you have two ram sticks in it pull the # 2 one and try to fire it up if nothing changes swap the # 2 one with # 1 leaveing slot 2 open and try it that will tell ya if it is a bad ram stick I dunno just my two cents hope it helps
Oct 08, 2010 | Gateway GT4016 Desktop PC
My on/off switch quit working. was always on for
Yes, you can, here's how:
My vacuum had this exact same problem, but was out of warranty because it was remanufactured. Thankfully, it's a very quick, five-minute fix.
  1. UNPLUG The Vacuum!
  2. Remove the cannister.
  3. Extend the handle and remove it.
  4. Remove the two torx (T-15) screws behind the power button, where the handle normally stows.
  5. There are four tabs holding the front plate containing the power button on; use your screwdriver to release them.
  6. Gently pull the front plate off.
  7. The switch on the right is the power button. Remove it, try clicking it a few times; if it sticks, great! Replace it and reassemble, otherwise you'll need to replace it.
And finally, in case your switch assembly falls apart during dissassembly, here is how it should look reassembled:
Apr 09, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
I have the same problem with the key being stuck in the ignition
just repaired my girlfriend one, and like you said the button keeps sticking, cuz their is a small rod, that got loose, you need to remove all the panel around the stick, most are just clip-on, might need, to force them, and the last big peace, as 6 screws, and from their, look under the stick, on the passenger side you'll see the switch, , just push back the rod in place and voila!, I just did it,
Oct 06, 2009 | 2006 Pontiac G5
My dell optiplex gx270 froze now will not come back on
Here try my trouble shooting steps. Some I usually follow this when I can't get a power up. My no-boot flow chart has always worked for me (many years work for Gateway tech support has paid off).
So basically you cannot get the pc to POST. Meaning you have just a black screen when you power on the pc, right?
1. Full power down. Unplug the power cord from the Power supply. Then hold down the pc power button (this discharges any residual power in the capacitors).
2. Open the case and reseat the graphics card, hard drive, and RAM.
3. Take out one of the RAM sticks if there is 2 or more. Swap the RAM sticks in different RAM slots. Try one stick at a time to see if you can get the PC to boot. If this works, then the remaining ram sticks are damaged.
4. Set the Cmos jumper to clear. Power up the pc. Power down the PC. Set the Cmos jumper back to normal position, power up the PC.
5. Unplug and replug all the power supply cables.
6. Check the powersupply function. Either by a powersupply voltage checker (20-25 dollars at local PC shop), get the supply tested at a PC shop (usually a free service), put the powersupply in a different pc, or try a different powersupply in the problem computer.
If the Powersupply checks out ok, then you will have to do a process of elimination to find out what part or parts are the culprit of the No-Boot.
Start by pulling all the ram sticks if you have not already. This is the easiest components to check and usually a culprit.
If it is not the RAM, you have to continue removing items such as sound cards, un-plugging hard drives and optical drives, other PCI cards. Do this one at a time until you find the culprit. If a POST screen, meaning you can see Anything from the PC brand name to Motherboard brand name appearing on the screen.
Hope this works. I am thinking the ram is probably toast. We will see.
Brian
Jul 09, 2009 | Dell OptiPlex GX270 PC Desktop
HP Pavilion A610n (PC106A#ABA) PC Desktop Logo
48 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
