Question about Sony Mobile 1261-4445 Xperia P Lt22i Smart 16mb Silver Ultra Bright Ex
I need to know the proper insertion of the Micro SIM for my Xperia P
I am very confused about what side of the SIM Card should be facing up. All of the diagrams are not very clear.
  • Sony Mobile Master
  • 32,281 Answers
The SIM card has gold plated contacts, place the SIM card with the contacts so the line up with the contacts on the cell phone.
Posted on Dec 07, 2012
I cut my sim card for another phone but now I want to put into my alcatel onetouch, not sure how to put it in. can you help me?
First, read the owner's manual and see which type of SIM card your phone accepts or is configured to make use of for it to operate
Sim cards come in 3 different shapes
1. Normal Sim card
2. Micro Sim card (mid way)
3. Nano Sim card (smallest)
There are SIm card adapters so you can use Micro Sim card in Normal Sim card only phones
There are Sim card adapters so you can use Nano Sim cards in either Micro Sim card or Normal Sim card phones.
**Photos are less than 500kb size so can't upload for you to sight please.
This device uses a Micro SIM card. Insert SIM CARD Turn the phone off. Remove the back cover using the notch located at the bottom edge of the phone. Lift the battery out. Slide the SIM card (flat-edge-first) into the slot, with the gold contacts facing down. Replace the battery while ensuring the gold contacts are aligned. Replace the back cover. Remove SIM CARD Turn the phone off. Remove the back cover using the notch located at the bottom edge of the phone. Lift the battery out. Slide the SIM card out of the slot.
Oct 08, 2017 | Alcatel Cell Phones
Sony xperia miro manual
Here's a link to the official user manual for Xperia Miro (http://blog.clove.co.uk/wp-content/uploads/2012/09/Sony_Xperia_Miro_Userguide_EN_ST23.pdf). On page 8 they described how to insert a microSD card into Xperia Miro.
Aug 21, 2014 | Sony Xperia miro ST23i Smartphone -...
Problem in my sony Xperia u
Hi, well this problem means usually a problem with your sim card, no network coverage, hardware issue of the phone or the phone is blacklisted.
Nov 27, 2013 | Sony Mobile Communications Sony Xperia U...
Micro sim will bounce off every time I insert the micro sim in my Sony Xpeia P phone
Hi,may be your unlock phone didnt unlock correctly before,i think 98% you have software crack issues,try re unlock it by certified shop,if you still have problem may be your ESD SIM CARD PROTECTOR IC (contain zener diodes inside to protect sim card from electro static charge) is gone,and must change, so go to a certified store to repair it
kind regards,
Apr 17, 2013 | Sony Ericsson Sony Xperia P Lt22i 16gb...
How to properly insert micro sim in sony xperia P?
Sounds like your'e not seating it properly. Try pushing it in softly with a flat screwdriver until you hear it click.
Apr 17, 2013 | Sony Mobile 1261-4445 Xperia P Lt22i Smart...
Where do u insert memory card in samsung impression a877
well on the back of the phone where the battery is, its right next to the sim card. to the left side of it and u see a small slot. Note: insert the micro sd card upside down. insert with the gold part up facing you
Dec 20, 2009 | Samsung SGH-A877 Impression Cell Phone
Instructions on how to insert sim card
hello. there is often a diagram which shows u how to insert the sim card. it will be a little diagram of a box shape with a **** on one side, as ur sim has a **** on one side too. try looking for it. the sim insertion can be under the battery, or more rrarely- thru the side of the phone. dont get confused with where the memory card fits, it is much smaller in size.
May 05, 2009 | Nokia 2680 Slide Cell Phone
Sim card
Sounds like phone is locked or firmware is bad
Mar 15, 2009 | Motorola Mobility RAZR V3
I dont know where to put this
Hi, First insert the micro SD into its adapter which resembles a SD card itself but has a small opening at the bottom to insert the micro SD. The adapter should not b locked while inserting or removin the micro SD. Now insert the adapter in the card readers slot which should be connected to a PC via a USB. If its a card reader then insert the adapter with microSD in the right side top corner of the card reader with the adapters copper pins facing down. OR if u already have slots in ur CPU to insert the SD card install it there, Now transfer files to ur card happily. NOTE: Rename ur device so that next time when u plug it in the adpter n connect it to PC, u wont get confused. Just right Click on the drive icon in ur PC n select rename n just giv any name as u lik. Rate he soln dude Bye..........!
Jan 25, 2009 | PNY 2GB microSD Memory Card
Where do you put the Micro SD card in a Motorola V3 Phone.
It depends on your carrier or phone model.
Verizon Wireless still uses the CDMA network. CDMA gets the phone user ID from a programmed chip hardwired to the phone instead of a SIM card.
Because of this, there is room underneath the battery cover, south of the battery on the right side of the compartment for a mini-SD card.
Other carriers such as T-Mobile, Cingular/AT&T DO use SIM cards to store user ID, so there is not room for a memory card.
I do know that the MotoRazr2 V9 from AT&T DOES accept Micro-SD cards.
But if you have a GSM carrier such as T-Mobile or AT&T, the Razr V3 does not have a card slot.
Mar 03, 2008 | Motorola Mobility RAZR V3
Sony Mobile 1261-4445 Xperia P Lt22i Smart 16mb Silver Ultra Bright Ex Logo
123 people viewed this question
Top Sony Mobile Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Sony Mobile Cell Phone Expert? Answer questions, earn points and help others
