Question about Breville 800CPXL Juicer
I need the repair manual for the Breville 800cpxl jucier. It will not run and I want to take it apart.
It will not run when I push the press arm down.
2 Suggested Answers
EwingElect
  • 276 Answers
SOURCE: BREVILLE JUICER JE90J manual
I have access to the Owners Manual for the JE90J if you email me at sales@ewingelectrical.com.au I'll email you a copy. It's a PDF of a photocopy so it's not brilliant.
Posted on Mar 30, 2009
Dash juicer wont turn on
Just fixed this problem!
Take bottom off juicer. The 4th screw is an "odd" one...I drilled the center out and used a flat head.
When you look up inside the juicer, you will see a silver lever arm. It touches the arm lock mechanism (so the juicer will only run when the arm is engaged).
The lever arm should be behind the black lever arm part on the side. When I opened mine up, the silver level arm was on top of the black post thingy. I took a screwdriver and pushed it off the black post thingy, so it the very bottom of the silver lever is behind it. (I can no longer see the entire silver lever easily when it is in the correct position.)
Totally fixed it.
I think it bounced out of the correct spot when I juiced some hard veggies or when I moved it, it hit the counter pretty hard.
Anyway, good luck....I am not a mechanic so sorry if the language is non-technical.
Oct 05, 2012 | Juicers
Hi- I wanted to use my juicer again after not having used it in at least 2 yrs. Last time (which I can't remember!) I used it, it worked. This time, all loaded up with veggies, when I turned it on it...
Just looked at mine because I thought there also might be an interlock switch
where the latch arms snap shut. There isn't one, at least on this one. Yours
might be a newer edition, so make sure the latch arms are fully seated and
snapped closed. You can also call Omega at 1 800 633 3401 and run it by
them. The reset switch should be in the pushed in position, it will pop out if
it's tripped.
Apr 29, 2011 | Omega 1000 Juice Extractor
My omega 1000 juicer won't turn on - I just bought it today.
Make sure it is assembled correctly and the latch arms snap shut completely
without any undue force. Also on the bottom of the juicer there should be a
reset button that might have tripped, just push it in. Other wise give Omega
a call.
Apr 23, 2011 | Omega 1000 Juice Extractor
Just received replacement Latch arm for Omega 1000. Old one is removed. Can not put the new one. Top part does not slide in. Also noted the old part and new part look different. Base is longer in the...
Believe it can be done. You might have to file or shave the new arm a little then seat it as best
as possible and tap it in place with a screw driver and hammer. If you do manage to attach
the new arm and the fit is a little too snug when you latch down the cover, file the upper tip
of the arm for a little more tolerance. Also, believe it or not, a worn blade will produce less
vibration. There is a set screw bottom center. With the juicer fully assembled, unlock it,
turn it clockwise until feed chute contacts the shredder blade and back it off a half turn.
You now have the proper gap between the chute and blade.
Jan 30, 2011 | Omega 1000 Juice Extractor
How do you get the latch arm back in. The bottom is easy but how do you snap the top????
Is this an older juicer and a new latch arm? Surprised you were able to snap it into the base.
If your problem is latching it down because it's a little too snug, file the upper tip a little to
increase the tolerance. Do it to a point where the latch arm will easily slip over the lip of the
cover and then latch it down.
Jan 11, 2011 | Omega 1000 Juice Extractor
I got the latch arms for my omega 1000 juicer but only the bottom goes in how do i get top part in
With some difficulty. Sometimes replacement latch arms are not an exact fit for
older models. You may have to file them down a bit so they will snap in place.
Also make sure the fit at the cover is not too snug or else the arm will break again.
Removing the 4 screws on the bottom and separating the base will give you a better
view on what has to be done.
Aug 18, 2010 | Omega 1000 Juice Extractor
HI, I have omega 1000 juicer, and the latch arm was broken. I ordered the replacement latch arm online. I received my order today and there is no intruction how to replace it. I looked in omega 1000 manual...
There are no instructions. Call Omega 1 800 633 33461
for advice. Also new arms on an older juicer may not
be an exact fit so you might have to do a little filing
down on the arm to get it to fit. You can remove the
4 screws on the bottom to separate the base and get
a clearer picture of what you have to do. Basically
you have to pry the base of the arm away and push
up to remove it. If you're not handy you may need
some help cause it gets tricky.
May 08, 2010 | Omega 1000 Juice Extractor
Right Arm of Omega Juicer Model 1000 broke off
CALL OMEGA 717 561 1105 THEY HAVE
THE LATCH ARMS. CHEAP. ASK THEM FOR
THERE ARE TO WAYS TO REPLACE THEM.
Jan 25, 2009 | Omega Juicers Juicer 1000 Brand: Omega
How to replace latch arm for omega 1000 juicer?
Getting the old one out is the hardest part if the arm was broken off like mine. First locate the rectangular part where the arm attaches to the case. If the old arm, or most of it, is still attached, grasp it and pull firmly away from the case until you hear a click. Then, still pulling it away from the case, push it up toward the top of the case until it slides out. If the arm is broken off you have to pry it from the top until you hear the click. I used a small paring knife. Once you get it this far, wedge something like a toothpick behind it to keep it pulled away from the case. Then you need to push this push this part up. It is pretty tight so you might want to use some type of tool, like the blade of a flat screwdriver. Once you get the old one out, putting the new on in is just the reverse of taking the old one out.
Dec 11, 2007 | Omega 1000 Juice Extractor
Omega 4000 won't start even after reset
LOOK UNDER WHERE YOU PUSH DOWN
ON THE LATCH ARMS TO SECURE THE
LID. ONE ONE SIDE THERE MAY BE A
SMALL INTERLOCKING SWITCH WHICH
WOULD PREVENT THE JUICER FROM
RUNNING WITHOUT THE COVER LOCKED
DOWN. USE A SMALL SCREW DRIVE TO
CORRECT IF MISALIGNED. THE JUICER
ALSO COMES WITH A 15 YEAR WARRANTY, SO OMEGA WILL FIX FOR
FREE.
Oct 31, 2007 | Omega 4000 Juicer
Breville 800CPXL Juicer Logo
74 people viewed this question
Top Breville Juicers Experts
Greg Cann
Greg Cann
Colin Stickland
Colin Stickland
eyecam
Are you a Breville Juicer Expert? Answer questions, earn points and help others
