Question about Makita HR2450F Rotary Hammer
How to remove wires from the switch from makita hr2450 hammer drill
    Champion:
  • 304 Answers
Use a fine jewellers screwdriver or thin stiff wire in the small holes next to the wire holes.
Posted on Feb 03, 2014
SOURCE: Makita HP1640 hammer drill dual mode - 2 hours
Exchanged Makita HP1640 hammer drill for a new one. The 2nd drill did the same thing in under an hour!! Will return for refund. Instructions say the Forward/Reverse switch must be in a full up or down position for the Hammer/Rotary switch to move; well, it is and the Hammer/Rotary switch still stops at a 1/2 way point between modes. Although I can still use the drill, instruction warnings say not to because it may potentially burn out the motor. I'll have to go with a different brand this 3rd time around. It seems to be a design flaw.
Posted on Oct 11, 2009
SOURCE: wanted free makita hr2450 manual
i want free maitenace manual
Posted on Sep 28, 2010
  • 885 Answers
SOURCE: I have a makita Hammer
Go to the below site for a manual. There isn't any reference to a glass window in the manual but the tool does need to be regreased as indicated in the manual, especially if it's used frequently. If you do it yourself, pay close attention to how much grease you put in the tool. Too much grease causes excessive drag and makes the motor work harder.
You can find an owner's manual and parts breakdown on Makita's website: http://www.makitatools.com/en-us/Modules/Tools/ToolDetails.aspx?ID=173.
Posted on Apr 26, 2011
  • 1383 Answers
SOURCE: how do you remove the
Removing the change lever:
Set change lever at neutral position (arrow pointing down) and insert a slotted screwdriver into the back of the lock button. Slightly hit the screwdriver with a plastic hammer to remove it. Good luck with your repair.
Posted on Sep 23, 2011
  • 304 Answers
SOURCE: MAKITA HR3000C HOW DO I REMOVE THE HAMMER/DRILL MODE CHANGE SWITCH
The big control levers off, but the small one only comes off once you have removed the screw and have it in the down position.
Posted on Nov 14, 2012
How do i lubricate my makita hr2450 hammer
193606-2 its the neccesary service kit for the tool with all the parts but be aware to control the locking sleeve and impact bolt replace it if its not air tight
Apr 26, 2014 | Makita Hammering
Hr2450
Clutch and or the drive dogs on the primary drive.
Jan 12, 2014 | Makita Drills
Sep 27, 2012 | Makita HR3000C Electric Rotary Hammer
Bhp452 makita cordless drill smoking. how can i troubleshoot?
the switch or motor is wired incorrectly. These parts are polarity sensitive. The smoking I would assume is from the old switch and now the rotation is reversed. Let me know if you need more assistance.
Dec 10, 2011 | Makita 18 Volt Cordless Hammer Drill Kit ...
I have a Makita HR2450 hammer drill with an SDS chuck. It no longer holds the bits tightly and I can now push them in and pull them out without needing to use the release mechanism. How do I remove the...
go to Makitatools.com and type in your model number for a breakdown. What I would do is first remove the dust shield and under that you will find a retaining ring, remove it without spreading it too much, then remove the collar and under that you will find a washer and another retaining washer, push down and remove the steel ball. clean the area, it could be full of dirt and not locking properly. Let me know if you need more assistance
Sep 12, 2010 | Makita Drills
Oct 10, 2009 | Makita Drills
Why doesn't my HP 1501 Makita hammer drill work
The problem was the cord at the base of the drill. The wires were broken, cause by constant bending. After souldering the wires, the drill works perfectly.
Thanks.
Jul 28, 2009 | Drills
Makita HR2450F Rotary Hammer Logo
207 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
