Question about Zebra LP 2824 Plus Thermal Label Printer
Zebra LP 2824 Plus Giving Endless Labels
I've been struggling with this issue for over 3 months! We have a Zebra LP 2824 Plus connected to a WYSE Thin Client via USB. The Thin Client connects to a server via Remote Desktop in order to use a program that allows the workers to create and send a "defect label" barcode to the Zebra printer to be printer (we're in a factory environment). Here's the issue, whenever they send a label to the printer to be printed, the printer prints one label, and then continues to spew out endless of blank labels until it errors out (red light). After I clear the error and press the button, it starts to do the same thing all over again. I restored the printer to factory defaults, re-installed it using the ZDDesigner driver and can print out a Windows test page without any issue, but when I send a label to it over remote desktop, the same thing occurs. To make matters worse, I tried a different (brand new) printer of the same model and I still get the same issue. Is this a driver issue? HELP!!!!
    New Friend:
  • 11 Answers
OK where is the print spooler on the remote client or the server. Have you check whether this is clearing and not an issue with your remote setup and not the printer does the printer work correctly attached directly to the server break the problem down in stages
Posted on Dec 07, 2012
SOURCE: ZEBRA 105SL : PRINTING PROBLEM
Thanks your the solution. This helped me a lot.
Greetings
Thomas
Posted on May 05, 2008
SOURCE: TLP 2844 skips 15-16 labels then prints intended label
It sounds like they may need to set their "Q" values for the labels they are using.   If that isn't it, we may need more info - are they using Zebra brand or custom labels?
To start with, I would ask them to try adding these "Q" value commands: q456 Q152,24
If that doesn't work, then maybe they can provide the other info mentioned above so we can understand the problem better.
Posted on Jan 05, 2009
  • 10 Answers
SOURCE: Zebra S600, Recieves data, but does not print
Go into the printer driver and select print a test page, does it print out?
If so then try printing from your label software, it should work, if not then it is your software that is at fault.
If the test page does not print out then check all the settings in the print driver, so they are the same as the physical label.
If non of this helps then go to www.lancerlabels.co.uk and do a live chat to Michael.
Posted on Feb 17, 2009
  • 32 Answers
SOURCE: Sent too many labels to printer - need to reset
As the previous expert has stated, with the printer paused, press the cancel key to cancel the job. One thing to note, is depending on how your software sends the print jobs, you may say print 1000 labels, but the software sends it one at a time, so basically you have 1000 print jobs in the printer. If you pause the printer, press and hold the cancel key. Hold it for about 2 mins. This should clear the buffer.
Posted on Oct 27, 2009
ozztech
  • 285 Answers
SOURCE: I have Zebra tlp 2844
So you have Zebra LP2844 or TLP 2844?
try diferent driver and print test page
www.seagullscientific.com
Posted on Nov 25, 2010
Lp 2824 plus won't print. Have windows 7 till switch off and on again
printer driver conflict or windows 7 driver incompatibility. contact zebra for proper driver installation.
Oct 21, 2014 | Zebra LP 2824 Plus Label Printer
Zebra eltron LP 2824 printing too light
This could simply be old direct thermal labels. Direct thermal labels have a shelf life of about 1 year from the date of manufacture. After that time has lapsed the thermal coating on the labels begins to dissipate and this will cause labels to print light or faded. You can trouble shoot with a roll known to be fresh. You can get one free here to test Labeldomain com .
If this does not solve your problem then please check this article on 5 common print quality issues and how to correct them Fix Zebra 2824 2844 3842 print quality
Jan 28, 2014 | Zebra Eltron LP 2824 Thermal Printer
My zebra tlp 2824 won't line up to the labels
Either your printer needs calibrated: Calibrate Zebra Desktop Printer
Or your label template size( in the software) does not match the label size. I recommend the calibration then looking at the software label templates.
Jan 20, 2014 | Zebra Eltron LP 2824 Thermal Printer
Zebra TLP 2824 Plus does not print barbell labels
You need to run win7 in XP mode. I am not sure the Zebra software will run in 64bit.
Feb 27, 2017 | Zebra Office Equipment & Supplies
I am trying to install a lp 2824 plus zebra label printer and i need to know whether to select epl or zpl?
You should probably select ZPL, but that depends on which program you will use together with the printer.
Jun 20, 2011 | Zebra LP 2824 Printer
Our LP 2824 Zebra printer stalls with red light when printing labels. Tried calibrating but it stalls with solid red light before printing out data
Try another roll of labels? If that doesn't help, it may have a problem with the sensor that checks the starting point of the label. These are old so it's easy and cheap to replace with a similar unit.
Oct 13, 2010 | Zebra Eltron LP 2824 Thermal Printer
Zebra 2824
if you see that it is like printing a card. check your thermal print head maybe its not working.
Jun 23, 2008 | Zebra Eltron LP 2824 Thermal Printer
Zebra LP 2824 Plus Thermal Label Printer Logo
341 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
