Question about Panasonic TC-P46G10 Plasma TV
Tc-p46g10 Panasonic blinks red three times then pauses for about 5 seconds then blinks 3 times again and hasn't stopped. What does this mean?
  • Anonymous Mar 19, 2014
    Panasonic TV flashes red 5 times does not turn on
    Top Expert:
  • Panasonic Master
  • 14,553 Answers
Google the model number with 3 blinks or error codes and you should find it.
Posted on Dec 08, 2012
SOURCE: my panasonic plasma tv has some error! the red led
Panasonic sent a repairman out with the correct part after telling them about the seven blinks. The unit was out of warranty. They rock. Call 800-211-7262 or 800-524-1448 1
Posted on Oct 06, 2009
  • 20 Answers
SOURCE: my panasonic th-50pz800u won't power
A red light blinking 10 times means that a video board has gone bad. Contact Panasonic to see if they will help you out.
Posted on Jan 04, 2009
  • 418 Answers
SOURCE: panasonic 42
Loss of power from power supply. Usually bad power supply.
Posted on May 02, 2010
  • 8457 Answers
SOURCE: panasonic th-50pc77u red light blinks 8 times in cycle
Ur power board it dead,need it replaced.
Posted on Nov 23, 2009
  • 8457 Answers
SOURCE: My Panasonic TH-42PZ700U 42in. TV doesn't turn on
Power supply board have dead capacitors.U know how to solders?Buy these capacitors to replaced them to have power back.Or u can buy a whole power supply board for the replacement at these websites Shopjimmy.com,Ebay.com for refurbish power suppply board.
Posted on Mar 04, 2010
What is Code 33 on Onan Generator Model12.5 HDKCB11506B?
You may be reading the code wrong, Code 33 shows up as blink 3 pause blink 3. This means it has a lower level code fault. To access the real code. Press the stop button 3 times fast within 5 seconds and re-post what the code is please. It may blink pause then blink again, that is the lower fault code that will help diagnose the problem.
Feb 10, 2015 | Onan Generator, 4000W, Gasoline
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
We have a Panasonic HDTV VIVA 1080i that was working fine when we went to bed and the next morning when we turned it on, it came on then shut off with the red light blinking 3 times, pause, blinking 3...
NO, three blinks on most of the sets means short protection.
If model is similar to one listed here it means short in convergence circuit. What happens is one of the two convergence output chips goes bad and takes out a resistor or two around it; set senses no voltage to chips and shuts down with 3 blink error code.
This can be a do it your self repair if you are handy and soldering is involved, typical parts cost at a site I use is well under 25 dollars.
SD TECH---let me know if you have questions.
Oct 26, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Error codes for 1991 dodge spirit
Turn the key to run then off, back to run, then off, then to run and leave it on. The check engine light will be on and will then go off and then on again according to the codes the engine controler happens to have in it. If the check engine light was on when you stopped the car, then there is at least one code in the controler. The light will blink the codes like this.
Cycle the key three times and leave on on the third time. light on for about 3-4 seconds then goes out for about 2 seconds and then blinks one time and goes out for 3 seconds this is for the no.1. Then the light blinks 3 times and goes out for about 3-4 seconds. You have the code 13. You could have a whole string of codes in the controler memory. It could be something like this. key cycled 3 times, light on for 3-4 seconds, then blinks 1 time, pause, 3 times, longer pause, 2 times ,pause 4 times, longer pause, then 5 times, pause 5 times the goes out.
This is code ; 13,24, 55. code 55 isn't really a code. It just tells you it's the end of any codes the controller has.
If you disconnect the battery and hook it back, you will have code 13 which simply mean 'battery disconnect'. It will errace it's self after several starts if it's not disconnected again. If you cycle the key and you get 55, this means there are no codes recorded at this time.
You will allways get 55 when checking for codes wheather there are fault codes or not. The light on for a few second before the codes start flashing is only a bulb check. Some codes like 13 will not turn the check engine on, but but will leave a code for diagnostic purposes only. If you have the check engine light on and accellerate and the light begains to blink, then the controller is telling you that you have an engine miss and are running the chance of burning out you're catalatic converter if you continue driving. Sometimes its advised to disconnect the battery after you have recorded the codes.
This will erase all codes that are present but were generated by conditions that aren't pertanent to the present condition. and then the codes that come back are the real ones to address.
This link: http://minimopar.knizefamily.net/fault/index.html
Contains the entire list of Chrysler Engine Error Codes.
Mar 03, 2011 | 1991 Dodge Spirit
Tv will not turn on. red light on front of tv next to on/off button blinks
COUNT THE BLINKS.
3 BLINKS AND A PAUSE AND 3 BLINKS IS MOST COMMON.
5 BLINKS AND A PAUSE AND 5 BLINKS IS ALSO COMMON.
let me know the error code (blinks) and I will tell you what it means.
SD TECH
Jun 10, 2010 | Panasonic PT-53WX42 53" Rear Projection...
TV will not come on andthe red power light starts blinking in a short series of 6 blinks and a pause of approximately 2 or 3 seconds.
its haveing a power problom. it had a power serge thats why it dose that. i work on them everyday it has a bad power chip. if u want to get rid of it email me at moonlight1874@aol.com
Sep 27, 2008 | Panasonic TC-32LX60 32 in. LCD Television
Panasonic PT-53TW53G
If the front power light is blinking three times then your TV has a problem with the convergence. You can get the correct replacement parts and full step by step photo instructions from www.TvRepairKits.com
Aug 17, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic TC-P46G10 Plasma TV Logo
667 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
