Question about HP DeskJet 340 InkJet Printer
Ink not printimng dark enough
340 pixma printer ink changed not printing dark enough
checkitright
  • 1362 Answers
SOURCE: Jet ink on printed invoices
Clean inside for toner spills
check fuser may be worn
check drum ( green Cylinder of toner cartridge) --Rotate--
Posted on Jul 15, 2008
rtrahan
  • 741 Answers
SOURCE: my hp 1200 printer is not printing dark enough.
If you have installed the toner cartridge correctly then it is a hardware problem called the Fuser and is the most common problem with printers...the fuser is a part of the printer which actually melts the toner onto the paper. The fuser has to get up to a high enough temperature to be able to melt the toner, if it is malfunctioning then it cannot give you a dark print. You may search google for Fuser information: Recommendation is change out fuser to repair problem. Pls rate this solution.
Posted on Apr 20, 2009
  • 69 Answers
SOURCE: not printing black ink dark enough. Comming out
It could be Black Cartridge runs empty, try to change or refill the black cartridge.
Posted on Sep 17, 2009
pineworks
  • 4041 Answers
SOURCE: the black print is not dark enough
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on May 08, 2010
  • 244 Answers
SOURCE: i have hp photosmart printer,i
Bre carefull when using other than original ink in your printer.
The material used, is not the best (that's why the price difference), and end up clogging the small printheads.
I wish I had better news for you.
Don't forget to rate this answer if it helps
Posted on Oct 16, 2010
HOW DO I CHANGE THE INK CARTRIGE IN MY CANON 340 PRINTER?
Carefully take out the ink cartridge from the printer. Make sure that you unplugged the printer. Do not touch any electrical wiring. Attach the new ink cartridge. A distinct click will confirm that you reinstalled it properly. Do not expose the cartridge to heat or light for more than 10 minutes to prevent damage. And run a test print.
Dec 12, 2012 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA MP510 : When I print something in colour, I get alternating dark and light 3mm lines printed horizontally down the page. I've tried cleaning, deep cleaning and realigning the print...
Hello
what you need is to clean, you need to clean the prnt head and ink cell, you open the top part let the ink carrier move to the center then UNPLUG the power cord ,now you can easily clean ink cell.
Jun 29, 2011 | Canon PIXMA MP510 All-In-One InkJet...
Canon Pixma MP780. Recently my color ink
Have you checked to see if the jet area on the bottom of the ink cartridge has a blackish sludge on them? It might be that the area that the print cartridges are purged/cleaned to one side of the printer (sometimes called a service station, or spitoon) has built up excess ink that has gotten thick and high enough that as the carriage goes over that area the bottom of the cartridge gets polluted with the blackish sludge. It will work slightly into the jets where the ink comes out and cause discoloration, even after you change the color cartridge. Open the unit to look inside with a flashlight for build ups and clean it (if you find some) with disposable things like cotton swabs, coffee stirrers, whatever you have that wont damage anything inside. Another cause could be mixing of the cyan and magenta and yellow somehow inside making a dark color representing black - but replacing the cartridge would cure it immediately.
Jun 19, 2010 | Canon PIXMA MP780 All-In-One InkJet...
When printing on my Canon Pixma MP500, there is a dark black line down the middle of the page. As the pages print, it gets lighter and lighter, but is very dark on the first one. Any thoughts?
Ink tends to overflow at the bottom guide rollers and the roller gets coverd in ink and causes the black line!The best will be to take it to a dealer and have it cleaned!Good Luck!
Apr 16, 2010 | Canon Pixma MP500 All-In-One InkJet...
Blue (CYAN) not printing despite changing ink tank
enough ink b ut not printing at all - blank paper on every time despite noise as if printing
Aug 17, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
I am getting a quarter inch black streak that runs the entire length on the back of each printed page. Sometimes light and sometimes quite dark. I have tried changing ink cartridges but still get the...
You'll have to open up the printer and clean everything off. You probably have a feed roller with ink on it. If you refill, use ONLY inks made for your brand of printer.
Jul 21, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Hp officejet, pro k5400 printer,when printing i get lines top to bottom on print,about 1 inch apart,tryed print head cleaning,changed the cartridges .need help ,top to bottom,only on...
That is ink or dirt on the rollers, you need to clean them by lifting the lid, as if you were putting new ink in, and wipeing the rollers that the paper runs through.
Jun 09, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Printer not printing dark enough
go to the print settings select the dark scale
u can get print darker than the previous
May 27, 2009 | Samsung CLX 3160fn All-In-One Printer
Problem with printed documents
your printer needs calibration. Read in the manual how to calibrate ink cartridges and it should fix the problem up. Cheers
Aug 03, 2008 | Canon PIXMA iP1600 Printer
HP DeskJet 340 InkJet Printer Logo
22 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
