Question about Pioneer AVH-P6400CD Car DVD Player
Pioneer radio got wet, buttons don't work and no sound
Awhile ago, my system might have gotten a little wet. The dvd unit above it works fine, ive replaced all the fuses and stil the cd unit wont give out any sound and the buttons and lights won't work. It tries to open the screen when I shut off my car as well. Is there a fuse in this unit that I have to replace or something else thanks.
  • 3 Answers
SOURCE: Pioneer AVIC-D1 Touchscreen Wont Work
Pioneer has a repair service center in California. Look up warrenty and service repair on their site. With a problem that detailed it realy cant be narrowed down to one thing. The good thing is you have enough wrong that you actualy benifit from their flat rate fee's for repair.
Me on the other end ended up paying $200 for them to replace a fuse. :( So yeah look up the repair centers number, give them a call and they will tell you what you need to do. The unit is repairable.
Posted on Sep 17, 2008
KaeZoo
  • 156 Answers
SOURCE: how do you connect a pioneer d2 navigation system to a 2006 ford expedition entertainment system
You need to identify the four wires that carry the DVD audio in the factory plug, and re-wire them to RCA plugs that can be used with the Auxiliary input RCA jacks on your Pioneer unit. The four wires should be: Left (+) light green Left (-) white Right (+) red Right (-) black The easiest way is to purchase some inexpensive RCA cables (or better yet, speaker wire with RCA ends). Cut the cables and wire the center pin conductor wires to the (+) audio wires in the stock plugs, and connect the outer shield conductors to the (-) wires. Then connect the RCA plugs to your head unit's auxiliary input jacks.
Posted on Aug 08, 2007
pjstanley
  • 185 Answers
SOURCE: renault espace radio / pioneer cd multi changer
iwish i can help but i cant
Posted on Jun 02, 2008
SOURCE: Blank screen - but radio working
When park the car in the hot weather condition, the unit turn off by the thermostat to protect it from overheating. Once the unit is cool, restart the unit should resolve the problem. If not, disconnect the power from the unit and wait for 15 second before reconnect. Good luck.
Posted on Aug 24, 2008
Nzero
  • 78 Answers
SOURCE: Pioneer Avh P5700
might need laser cleaning. try a laser cleaning disc from most electronic shops
Posted on Sep 05, 2008
Can a key with a chip in it get wet
I have gotten mine wet before and the chip still works just fine. Ive washed them on accident also
Jul 29, 2014 | 2010 GMC Acadia
Pioneer vsx-454 not working propley.radio not even hissing,managed to get whisper sound via pc aux,i have cleaned inids?
It sounds like you're not in the right input source (mode) or you have a external source selected. I show your unit as a 1995 model and so check your Tape 1, Tape 2 selection buttons. These "Tape" selection button get dirty contacts that will kill the audio. To clean, with the volume low, press them on and off around 20 times each. This works the contacts back-n-forth and will help clean them.
Oct 31, 2012 | Pioneer VSX-454 Receiver
The unit worked fine for a long time. a few days ago i changed cds and when i put the cd in it sounds like it is spinning and then nothing and it ejects the cd..the radio still works on the unit. I just...
Some Panasonic stereo's don't like non shop bought, home burnt discs (they are recorded at a different level) so try new discs plus run a CD laser cleaner through your system.
Jul 12, 2011 | Panasonic CQ-C1101U CD Player
My Pioneer DEH-P3500 car stereo is having problems. The front panel buttons will not work at all... the radio was working, but the head unit would not let me change stations or make any adjustments. I...
if its under warranty just return that on the store or in the authorized service center.if not just bring that on your local repair shop. because there is no serviceable parts inside the unit. ty
Jun 21, 2011 | Pioneer DEH-P3500 CD Player
The DVD tray doesnt eject
either it is the ribbon wire, the motor that ejects the tray or the belt that connect the tray and motor is the problem. In case the above three are fine, replace the drive as the sparking might kill your moterboard.
Jul 08, 2009 | Compaq (CDD480172) CD-RW Burner
I have a Pioneer xv dv55 . My sub or speakers are not working!
I've had mine for nine (9) years and it fine, first make sure all coloured wire are connected to the sub correctly, press sys on your remote then press button 8 to test if the speakers are working then increase the volume to hear the spaekers. so to link TV audio/sound with DVD press sys then A-2 on the DVD remote, I hope these will solve ur problem?
Jun 06, 2009 | Audio Players & Recorders
DEH-1700 got a little wet
Check the back of the unit and see if there is a fuse there if so check and replace as needed same with the fuse in the vehicles fusebox find which runs your unit and replace if needed . If none of the above work and your handy with a small screwdriver pull the unit out and remove the top cover and hit the guts with a hair dryer to dry it out good-im not saying that it will fix it but i did it with my amps once when i got my explorer stuck -amps were bolted to the floor - i disconnected the fuse to them and they sat overnight submerged- took them apart and did the hairdryer trick and they worked fine after that-hope that helps
Jun 05, 2009 | Pioneer DEH-1700 CD Player
Cd & g drive quite working
I had the same problem. The fix is a bit unorthadox. I removed the 4 screws holding the circuit board that is mounted directly under the CD player. Now with the board hanging free the unit works fine.
Good luck.
May 19, 2009 | The Singing Machine DVD/CDG Karaoke System...
Pioneer AVH-P6400CD Car DVD Player Logo
182 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
