Question about Toshiba e-STUDIO 165 All-In-One Laser Printer
Defaut de toner
My photocopier afiche the toner is low despite that it is new or not toner reconu
  • 3 Answers
You have to unable the control of the toner cartridge. Press 0 and 8 keys simultaneus and turn on the machine. Then enter 695 code and press the start key. Change the value from 1 to 0 and press enter.
Posted on Dec 18, 2012
I have a problem with my photocopier RICOH MP 5002 despite replacing new drum new cleaner blade and new developer my copier still copy very faint copies what could be the problem
when you replaced the developer, did you clean the "mag roll" of baked on toner? Very common problem on this model. Of course you initialized the SP mode 2-801, and 2-805 right? -Carl
Jul 29, 2016 | Ricoh Office Equipment & Supplies
I bought new toner since then my ar-5618 sharp photocopier is showing F2 and when i press start is showing 74. please what do i do to clear it?
The problem is with the toner....there is two way solution change toner or more economic way change the chip of your existing toner....the sharp copier tend to burn the toner chip.
Oct 31, 2014 | Office Equipment & Supplies
Dear sir, i have toshiba e studio 212 photocopier machine I change new toner but give the massage toner low
on out side tray the actual image is garbage left side 1 inch but in side tray select the image is actual printout
Aug 16, 2012 | Compatible Toshiba T1810 For E Studio 181,...
Sharp Al1655cs copier black smudge down center of page about as wide as a pencil
Hi
Sounds like a fusing error . If your able to wipe the toner off the page its a fuser unit problem (replace fuser unit).
Also clean the copier's paper rollers. Marks on copies will occasionally be the result of a dirty paper-rolling mechanism. Simply access these rollers (your photocopier will likely have a plaque or series of signs indicating the locations of these areas) and wipe them off.
Clean the copier bed's glass plate. One of the most common causes of blemishes in photocopies is a dirty glass plate. In some cases a permanent mark, such as a scratch, will be present on the plate, showing up in every copy as a dark line or spot. However, most problems attributed to the glass plate can be fixed by wiping the plate with a soft towel and common household glass cleaner.
Clear any excess toner that has spilled or overflowed in the toner cartridge chamber. Excess toner will almost always result in blemishes on your copies. The most effective means of cleanup is to remove the toner cartridge and set it aside, thoroughly cleaning up any spilled toner in the compartment before putting the cartridge back in place.
Check for low toner levels. Low toner levels can actually contribute to unsightly lines and blotches on a photocopy. Most photocopiers will automatically indicate the need to replace an empty or low toner cartridge; while the toner is low, these models will permit continued copying. Consult your photocopier's instruction manual or key to warning lights and indicators for how to tell if the toner is low or empty.
Aug 03, 2011 | Office Equipment & Supplies
I get dirty background copies despite having cleaned the photocopier a month ago. When the toner bottle is placed, there is toner everywhere within the compartment when the machine is used. Unable to fix...
looke my friend try to go in sp mode and make free run printer via 5802 and ok and press copy sp and back to copier process and print 100 shett don't worry it's not print paper already
Jan 15, 2011 | Ricoh Aficio 1035 Copier
Photocopies appear too light
what kind of service you done
try to clean the mirror and laser glass.
Apr 03, 2010 | Ricoh Aficio 1035 Copier
How should i resolve the code COF31 of Minolta Photocopier
Generally speaking, the COF31 code would popped up when the machine was run with no toner. This caused the toner to carrier ratio to drop so low that even when you decided to put a new bottle of toner in the machine still could not recover. If that's what happened, your looking at doing a developer change.
Jun 30, 2009 | Minolta Office Equipment & Supplies
Toshiba e-STUDIO  165 All-In-One Laser Printer Logo
75 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
