Question about Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator
No water i have a hotpoint side by frig with the ice maker and water on the door. the water no longer comes out. can you tell me what might be the problem. thank you
  • Anonymous Mar 11, 2009
    We had the Sears repairman out. THere were no problems with the supply line. The entire door easily freeze. You can take a hairdryer to the door for about 5-7 minutes and get it to unclog, but it will re-freeze again. I hat this freezer!!
I HAD THE SAME PROBLEM. 1ST LOOK AT THE BACK OF YOUR FRIDGE. MAKE SURE THAT THE VENTS ARE CLEAR OF HAIR AND DEBRIS. YOU MAY NEED TO REMOVE THE BACK PLATE AND VACUME THE DUST FROM THE COMPRESSOR MOTOR. IF IT CAN NOT BREATHE PROPERLY IT WILL WORK HARDER AND HARDER CAUSING THE FREEZER TO BECOME TOO COLD AND WILL FREEZE THE WATER LINE THAT GOES TO THE DOOR. AFTER THE BACK IS CLEAN LOOK UNDER THE FRONT OF THE FRIDGE AND FIND THE WATER LINE TO THE FREEZER DOOR. TAKE THE CONNECTOR LOOSE ON THE SIDE CLOSE TO THE DOOR AND PRESS THE WATER BUTTON. IF WATER SQUIRTS OUT THEN THE LINE IS PROBABLY BLOCKED WITH ICE. RE-CONNECT THE WATER LINE AND UNPLUG YOUR FRIDGE. YOU WILL NEED TO LET IT DEFROST AND THE WATER SHOULD WORK AGAIN. YOU CAN SHINE A FLOOD LIGHT ON THE FREEZER DOOR TO WARM IT UP AND SPEED UP THE THAWING PROSCESS. IT ONLY TOOK ME ABOUT 20 MINUTES.
Posted on Feb 01, 2009
  • 65 Answers
TAKE THE KICKPLATE OFF THE BOTTOM OF THE REFRIGERATOR IN THE FRONT AND YOU WILL SEE THE WATER TUBING ON THE LEFT SIDE. DISCONNECT THE TUBE BY PUSHING IN ON THE WHITE PART OF THE CONNECTOR AND PULLING OUT ON THE TUBE AT THE SAME TIME. ONCE APART, TRY BLOWING THROUGH THE TUBE THAT GOES INTO THE DOOR. CHANCES ARE, THE TUBE IS FROZEN INSIDE OF THE DOOR. GE MAKES A HEATER KIT TO CURE THIS PROBLEM BUT I AM SORRY THAT I DONT HAVE THE NUMBER OFF HAND. POSSIBLY GE NUMBER WR49X10173?
Posted on Jan 27, 2009
Water no longer dispenses for drinking
Is the water still being supplied to ice maker? Could be 2 things water line froze in door or water valve side supplying the door is out.
Mar 02, 2010 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
My ice maker is pooring out water. How do you stop the water from pooring out?
unplug frig,if water still come's in than you have a bad inlet valve and nead to turn water off.if water doe's not come in than you nead to unplug ice maker and plug frig back in.if no water come's in than you have a bad ice maker.in most case's you are better off buying a new ice maker.
Nov 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water always leaking out from bottom of fridge
If you have a ice maker check to see if the leak is coming from where the water connects into the back of the frig. If you dont have a ice maker. Look under the frig and be sure that you have a drain pan in place.
Aug 15, 2009 | Hotpoint Refrigerators
GE older ice maker won't make ice
pull the cover of the front of the ice maker. there should be directions as to what way to turn the main gear (use a philips screw driver). advance the ice maker until it starts to run on its own. if water comes in at the end of the cycle then you need a new ice maker. if no water comes in check to make sure the fill tube is not frozen. if it is clear replace the water valve.
Good Luck,
Todd
Oct 24, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Hotpoint CSX22GR water dispenser not working
Sounds like to me your filter needs replaced...how long ago have you changed them?
Jul 18, 2008 | KitchenAid KSCS25FKSS Side by Side...
Icemaker and water dispenser
Mine did the same thing.  Other web sites said it was the motherboard.  I replaced it and now it works great.  The part number is: Hotpoint Refrigerator Main Control Board Assembly WR55X10552best deal was at http://midwestapplianceparts.com
Sep 10, 2007 | Hotpoint HSS25GFP Side by Side...
No ice making
First i would check the water valve in the back. One side is for water.. the other side is for the ice maker... If you have a ohms meter check selonid for continuity look for blisters of plastic on sides showing in would be bad... You can also make a test cord to energise the valve by passing the icemaker to tell if valve is good. ALSO This would put water into you ice maker telling you.. you have a clear path for water to icemaker You only need to plug in for few seconds .. to keep from over filling icemaker if vavle good and water comes thu
Aug 20, 2007 | Kenmore 21.7 cu. ft. Top Freezer...
Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator Logo
150 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
