Question about Refrigerators
Why is my Amana french door fridge freezing everything in the fridge.
I turned the temp all the way down to 1 and it still is freezing the vegetables. Also during the summer my water dispensor would freeze. Someone said it is a damper switch and also could be a thermostat. Please help?
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the complete model number of the unit?
Posted on Dec 08, 2012
  • 9 Answers
SOURCE: No water at door
I have a 3 year old GE GSL25 refrigerator with the water/ice dispenser on the freezer door. Even when setting the freezer at 2 and turning the fridge's lower drawer to the warmer "cheese" setting, the water dispenser line would freeze every few weeks. If you have this problem, first verify that the water filter (back of the fridge) is not clogged and that water flows from the water line at the bottom left corner of the freezer door (disconnect and press water delivery dispenser-see owners manual).
I used the hair dryer recommendation to unfreeze the line by heating the flat area of the freezer door directly behind the water dispenser area (~10 min did it). The trick to keep it from freezing up again involved buying a cheap foam sleeping bag mattress (~1/3 inch or 1 cm thick) made of a polyurethane foam (pretty dense). I cut it to match the flat area of the freezer door behind the water dispenser and taped it to the door with packing tape. For the past 3 weeks (even with freezer at #4 setting), my water is flowing freely. Personally, I think this solves a product defect with insufficient insulation in the freezer door near the dispenser water line.
Posted on Jan 24, 2008
tborn6
  • 700 Answers
SOURCE: kitchenaid side by side too cold. Freezes everything.
the damper motor on the refrigerator portion is not working properly
Posted on Apr 04, 2009
projdoc
  • 2236 Answers
SOURCE: 2000 Amana BX21Vl fridge: ice maker and freezer not working.
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of. after the freezer freezes again, your ice maker will work again.
Posted on Aug 28, 2009
Sea Breeze
  • 4654 Answers
SOURCE: My refrigerator freezes everything
Not only the thermostat needs to be considered but the adaptive defrost board and the air damper between compartments. Something happened yesterday and my solution was changed to a clarification request. Sea Breeze
Posted on Nov 18, 2009
SOURCE: vegetables in fruit and vegetable bin is freezing.
I solved my problem by going someplace that wasn't going to charge me!
Posted on Jan 07, 2010
Why are vegetables freezing in crisper?
There is a control on refrigerator that controls the amount of cold air that is directed from freezer to refrigerator section. Locate that control and lower the amount of cold air going into refrig.
Oct 07, 2015 | Samsung RF265AA Bottom Freezer French Door...
Amana AFI2538AES The refrigerator portion keeps freezing the fruits and vegetables. The chiller control is on the warmest setting and the refrigerator temp is set at 43. I have been raising every once...
Our Amana afi2538aes is doing the same thing. Had a repairman out. He called tech support at Amana. They had him adjust the "thermistors" but it is colder than ever running at 28-30degrees in the fresh food compartment despite being set at 46 degrees. Tech support also recommended installing some sort of "ice bin seal kit to take care of the problem" according to our invoice from repairman. Repairman was told that the ice bin in the fresh food compartment puts cold air out (to keep the ice frozen) which freezes the food in the fresh food compartment. I called Amana and the rep I spoke to said he couldn't find record of this being a problem with the model but tech support told our repairman "we've had a lot of problems with this happening."
Mar 31, 2011 | Amana AFI2538AES Stainless Steel (256 cu...
Vegetables in fruit and vegetable bin is freezing.
Jan 07, 2010 | Amana AFD2535DES French Door Refrigerator
Refrigeration vegetable drawers freeze.
unload you fridge to much product in it would cause the air flow to to be redirected.. low charge causing excessive low temp...use a thermometer to measure temp you should be 35 to 40 degree F.
check stat adjustment
Nov 14, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Maytag fridge which freezes food in fridge compartment
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 21, 2009 | Maytag MFI2569VE Bottom Freezer French...
I have a GE side by side GS25LGM. The fridge side gets too cold that it freezes the vegetables. There is a humidity control on the vegetable bin. It didn't matter if I set it to high or low it still...
try turning down the thermostat for the freezer side some times the controls seem backward. However most fridges are desighned for thwe freezer side with some thought giving to pushing some air to the refrige side. in most cases it easier to start back at medium settingsfor two or three days.
Mar 12, 2009 | GE GSS25LGM Side by Side Refrigerator
Water despenser is apparently frozen
You may have two mutually exclusive probems... one being the water dispenser doesn't dispense water... As you stated, the obvious remedy would be to replace your filter to see if that is restricting water flow.. secondly, your vegetable crisper is freezing vegetables... chances are that the inlet between the freezer compartment and that vegetable darwer is near there and the damper needs to be closed a bit... See if you can locate the cold air inlet vent and partially close the damper ... Hope that helps...
Aug 14, 2008 | Amana AFD2535DES French Door Refrigerator
Things freese-up in the kenmore fridge
Try turning down the unit a half knotch, 1 full knotch at MAX, the cold air comes from the freezer to the refrig(fresh food) section, its rolls up the back of the wall to circulate it
A fridge that is to cold is usually shown when food nearest the back wall freezes( i get this call plenty times a day, this is the fix)
recommened freezer temp 0-5, fresh food(refrig) temp is 32-40
May 02, 2008 | Amana AFD2535DES French Door Refrigerator
Refrigerators Logo
101 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
