Question about GE WSXH208A Front Load Washer
Ge adora washing machine beeps when pushing start with door closed
I have put a load in and push power on, my cycle set and i push start. I watch the start button flash green as normal before you start washer and after pushing start it continues to flas green and beep two short beeps. Thats it - thats all it does.
    Top Expert:
  • GE Master
  • 9,472 Answers
Hit the power button until there is NO display . Unplug and wait a minimum of 30 seconds , plug back in and within 30 seconds hit SIGNAL button then DELAY START button then SIGNAL button again then DELAY START button again. door should lock and display t01 It is now in test mode . There are 14 different test it can run through in this mode , but all we are trying to do is check for error codes now and maybe get you back to normal, So turn the knob one click clockwise and hit the START/PAUSE button and see if any error codes come up. To exit the diagnostic mode - hit signal button then delay start button then signal button then delay start button and you are out of service test mode and back to normal. Post any error codes.
Posted on Dec 07, 2012
SOURCE: GE WCVH6260 Front Load Washer
I removed the three screws, and lower cover cleaned the few pennies, screws and nasty gunk build up from the filter. The wash machine seems to function as it did prior to the clogged issue. Thank you everyone !!!
Posted on May 31, 2009
  • 5 Answers
SOURCE: GE Energy Star WCVH6260F Front Load Washer: door locking problem
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Had the same problem, this fixed it!
Posted on Oct 31, 2008
SOURCE: GE Front load washer WCHVH 6260F
I had the same problem.....The start/pause button would flash during a cycle and the washer would not finish the cycle. After reading on this forum that there is a filter/strainer inline with the drain, I tried this solution.
Remove the (3) screws that hold the lower front panel (Just below the door)
Once the panel is removed, you should see a white plastic strainer hooked to the washer drain.
Please a large bowl under the opening and unscrew the knob/handle, pull the filter/strainer out and clean all of the lint/trash out of this area.
My filter/strainer was clogged with a baby sock, 2 doilies, a fewe pennies, 2 dimes and lot's of lint.
I believe all of this debris was causing musty odors in the machine as the lint would stink due to dampness.
Once I cleared out this filter/strainer the problem and my odors went away
I wish GE would add this "EASY" step into the owners manual for proper care and maintenace.
Thank you for letting me know about this filter/strainer as it did resolve my problem
Posted on Jan 26, 2009
SOURCE: Our GE front load washer pauses during the wash
Clean the filter. It is probably clogged.
Posted on Aug 12, 2009
SOURCE: ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
Posted on Sep 04, 2009
How do u reset GE front loader wASHING mACHINES Model #WBVH6240HWW
could be two things first lets do a reset push and hold any two buttons until you here a beep or for 20 seconds,or try pushing the on/off button for same.or try pushing the door closed again ,.the door switch if not closed propyl will not let the machine propyl,if this failscome back to me and I will speak to my top engineer,.Adrian...
Dec 28, 2014 | GE Washing Machines
GE Adora Front Load Washing Machine Problem
Have you tried a full hard reset? This is simply unplugging the unit from the mains for a couple of hours.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 10, 2008 | GE WSXH208A Front Load Washer
GE Adora GHWN5250D0WS beeps twice, wont start
Sounds like the lid switch is broken if you need more help please let me know
Mar 28, 2014 | GE Adora 3.9 cu. ft. Top Load Washer in...
My washer will not start. I press the start/pause button and it just beeps twice and does not lock door or start wash. ge adora model wcvh6260
clean the drain filter located behind the front lower panell, its prob. holding excess h2o and wont let the water fill cycle activate. this happened to mine.
Aug 11, 2009 | GE Energy Star WCVH6260F Front Load Washer
GE Adora QuietPower II Replacement Rack Wheels?
Model number is on a sticker on the left wall of the dishwasher, just behind the door, about mid tub level. Post your full model number and I'll list your part number(s) for you.
Sep 06, 2008 | GE Adora GHDA656LSS Stainless Steel...
GE Adora front load washer overloaded now won't start
Washers - Resetting Electronic Controls on a Washer
If there is a pause in the washer cycle, the controls will lock up. The pause can occur because of a power failure or it was put in the test mode at the factory.
Also, if the washer was stopped before the cycle was complete or the consumer has pushed the stop/pause button to temporarily stop the cycle and the cycle is not reset. Over a period of 24 hours, the washer will pump out and spin, but will stay in the final spin.
To correct the situation, shut off the circuit breaker for 30 seconds or unplug the washer, then turn the timer knob around and back to any position other than final spin. Verify the water is turned on and restore power. This should resolve the issue.
Apr 23, 2008 | GE WSXH208A Front Load Washer
Mar 12, 2008 | GE Energy Star WCVH6260F Front Load Washer
Kinmore 44092 Washer - can't get it to start any cycle
Try some WD40 on the machine door mechanism, not on the door; & open/close the door while the machine switch is off.
Retry the machine with clothes.
Nov 20, 2007 | Kenmore Energy Star 44092 Front Load...
Ge quiet power 3 dishwasher
According to the GE repairman who visited, the solution is to close the machine (with the lights flashing). The machine starts and goes through the cycles, which it does rapidly and then all the lights turn off and the machine becomes silent after 1-1/2 to 2 minutes. Then the machine has been reset to normal. During this reseting period nothing happens inside the machine, although you may hear a running sound.
Thus, the solution is to run the machine in this flashing light state for the 1-2 minutes it takes to go raipdly through each cycle and then reset.
I hope this helps.
Oct 09, 2007 | General Electric Adora GHDA670N Built-in...
GE WSXH208A Front Load Washer Logo
378 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
