Question about LG Studioworks 45 14" CRT Monitor
CRT monitor becomes yellowish..
My LG 500G CRT monitor is permanently become yellowish, initially it becomes temporarily..
i have concluded that BLUE pigmentation generator is not working because by manipulating RGB colors from monitor setting, no effect is shown when blue color extent is changed,and also yellow is combination of Red & Green,which is complementary color of blue..
please suggest me..what can i do and do i concluded right???
thnx
  • chsrinivas Feb 05, 2009
    LG 500g monitor becomes yellowish
    Problem Solver:
  • 10 Answers
When any dust goes inside your monitor .......you will get these things.......... remove it , it will work fine
Posted on Feb 12, 2009
  • 3 Answers
Try to resolve the AGP cable in the motherboard
Posted on Feb 28, 2010
My LG 500G CRT 14inch monitor become rotate from height and width and can't solve from menu item please help me and give me the solution.
Hi there monitor rotated or the Menu/ program file are going on top side? Please let me know that, also tell me which operating system you use.
Feb 01, 2011 | LG Studioworks 775N 17" CRT Monitor
MY LG 500G CRT 14" monitor is become faded and very white color graphics(nothing seen with out white color) after 1 or 2 sec. when i re start the monitor i can see some very brigh graphics then again...
open the monitor there is a movable preset attached to EHT rotate that preset by screwdriver in active on condition of monitor reduce the brightness to satisfactory level
Mar 29, 2010 | LG Studioworks 775N 17" CRT Monitor
LG CRT TV, picture becomes yellowish
yes it is due to dry solder in vedeo driver section(a board fixed to the pict-tube.).
Jan 22, 2010 | Televison & Video
Hi my monitors screen becomes yellowish.all colour effected y dis
Do you have a CRT monitor?
Have you tried to adjust the color on the monitor?
How is it connected to your computer?
It sound like one of the guns on you monitor died. But there is some testing you should do first.
If it is a CRT monitor and it is connect your computer properly. First thing to do would be to replace the cable and or try a different monitor that you know works.
To confirm try adjusting the color. If that does not work, if it more purplish it is the green gun, if it is orangish it is the Blue gun. That would be cause by a failed gun or driver.
If the gun is gone it is best to get a new one. It will save you money in the long run.
Thank you...
Jan 27, 2009 | Samsung 793S 17" CRT Monitor
My studioworks 500G monitor LED blinking with twise colour(Green and Amber)and no display.
1. LOT problem.
2. Horizontal transistor bad.
3. Dry points in neck board, horizontal section.
4. transformer output capacitors problem.
5. IRF 630 ( lot supply fet )
Nov 03, 2008 | LG Studioworks 45 14" CRT Monitor
Lg 500g crt monitor problem
Try checking B+ coil , may be the coil have shorted .
Happy trying
Apr 01, 2008 | LG Studioworks 45 14" CRT Monitor
My screen becomes yellowish..
Have you checked you monitor settings on the monitor? You may try setting you monitor the factory default and then re-adjust from there. Have you tried upgrading your vidoecard drivers? I would 1) Check actual setting on the monitor. 2) Make sure you are using the proper monitor drivers. 3) update your video card settings. Let me know what happens. Good Luck, Tim
Feb 24, 2007 | LG Studioworks E700S 17" CRT Monitor
Screen Gone "Yellowish" Colour, Appears that Blue colour is not working
your problem is in blue color cathode circuit. as you say that it becomes ok tha5t means 1 cable wire is loose from computer to monitor. 2 crt base loose. 3 loose contact in blue video ckt. 4 signal processor cable to crt board connector loose.(blue wire)
Oct 14, 2006 | LG Flatron F700B 17" CRT Monitor
LG Studioworks 45 14" CRT Monitor Logo
590 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
