GE washer fills up with water and drains but nothing else
My washer will fill up with water and drains but it will not agitate or spin out. Does not seem to be leaking anything and tried the suggested unplug for 2 minutes plug back in and open/close lid 7 times to try and reset the electric motor. I have not checked the belt yet but are there any other things to look for? It is getting power as all the LED lights come on.
  • 1 more comment
  • Tyler McMackin Dec 09, 2012
    So after a little further digging I have done the following. First, I took off the hose for the water level device. I put a wire down in the device on the left side of the tub, I blew in the hose and it was making the click sound up on the control panel area. I ran the spin cycle and after that I tried running a normal cycle on it. Same thing was going on, it will continously drain while the maching is attempting to fill. Second, I tested the lid close switch, I was seeing -15.14m ohms closed and -2.989m ohms when it was open. Figure that must be working correctly so I checked the water level switch. I was getting .8 ohm when normal, I then blew in the hose (to trip the switch) and I was getting 30.2 ohms. I also tested it with the lid open and I was getting .7 ohms normal then when I blew in the hose I was getting 39.9 ohms, again this was with the lid open. I figured that was working correctly. Third, I tested the synchronous drain pump. I was getting correct voltage from the wires, when it was off I had a reading of 53.2 volts going to the drain pump, when I turned the spin cycle on I was able to read 121.7 volts. While I had the drain pump off I turned on the washer with the pump plugged in and during spin cycle the drain pump would work and when it was set to fill the pump would shut off. This indicates to me that the drain pump is working correctly. However, nocited that when I took the drain hose off and looked at the drain pump housing (that holds the two hoses on the pump) I noticed that there was nothing to really block/close the water from draining. Should the drain pump extend to close off the flow? I am currently researching the Hanning Elektro-Werke website and not fining much information as to if the pump will extend in that housing to close off the flow. All it does is spin the little fan pump to expel the water through the housing, but again it does not extend to trap the water in the tub. Maybe this is normal and I am not looking in the correct place. Is there some type of valve or servo that will trap the water so it does not drain continously? I am coming up empty handed on this. Any suggestions anyone can give me would be great. I appreciate everyone that is trying to help out.....
    I should ad that I put it into field service mode and when the knob was roughly between 270-300(degrees) (perhaps knob position 8) the number 6 LED was on. With the field service mode ledgend it tells me it would be 'spin' as the error. I treid to reset/delete the error but was unable to do so. An automated solution below indicates possiable pressure switch, I am going to try to find this and test it and go from there.
    Well problem fixed. I do indeed get the award. After hours of testing all of the components for continuity and ohm resistance I was still stumped about the fact that there was no valve/stop to stop water from going by the drain pump. I finally realized it was due to the fact I had the drain tube running on the floor to the floor drain. I did not have it brought up to my drain tub or to a different drain. Since it was not elevated it just kept draining. Thank you everyone for viewing and trying to figure it out. I hope if someone else has this same issue they will run across my dumb experience before spending hours trying to figure out what is the issue....
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the complete model number of the unit?
Posted on Dec 07, 2012
  • 2 more comments
  • Tyler McMackin Dec 08, 2012
    It is a GE WCRE6270D and on another sticker it shows 'WCRE6270DCC'. I am about to look into what may be going on with it. All of the information I have up to this point came from my wife. I guess she was saying that the washing machine would just fill with water and continue to drain, the tub would not really fill up. I am not sure if a valve or servo is stuck open or if the electronic board is not working correctly and not telling the drain valve/servo to close. I am just about to dig into it now and see if I can dig up any more information that may be helpful or maybe I can find the solution. I by no means am a appliance repair person but I am very mechanical and can figure out most things, however, appliances are not thing. Any help would be great and appreciated. Thank you in advance for your time and knowledge.
    Quick update. Checked the continuity in the pressure switch. My multimeter beeps when I have the probes on the spade terminals, when I blow in the hose to "trip" the switch it no longer beeps. Is this my issue? Do I just need to replace it and I will be good? I am still confused as to why it continues to drain even when the drain pump is not running.
  • Richard Roth
    Richard Roth Dec 09, 2012
    The pressure switch is good. Is the water being pumped out or is it siphoning out? The drain line should be higher then the tub.
  • Richard Roth
    I thought that was it. I'm glad you have it fixed and thanks for using FixYa!
3 Suggested Answers
  • 512 Answers
SOURCE: GE washer no main motor run so no agitate or spin
This is the electronic washer. Unplug for two minutes, plugin then open and close lid 7 times. This will reset motor. Also make sure belt is not broken.
Posted on Jun 12, 2009
mgprice
  • 744 Answers
SOURCE: GE washer GNSR2140A0WW wont spin/agitate but fills and drains
Hello, your problem is going to be with the lids switch, in this machine it is going to be a magnetic contact. You can confirm this my pulling the front panel off and accessing the wireing to the lids switch, If you have electrical knowledge bypass the lid switch using a wire nut and run the machine. If all is ok make sure you relpace the lid switch since it is there for a reason. If you have any other questions or concerns please feel free to comment again. Good Luck!!!
Posted on Jul 19, 2009
My GE washer G153 was making a loud noise when draining/spinning out. Next load filled up with water and done nothing else. Now machine turns on but will do nothing.
have an electrician check out the agitator control module. This unit controls the agitation action of the machine and gets power when the tub fills to the desired level and switches over.
Aug 17, 2013 | GE Washing Machines
Washer fills with water but doesn't begin to agitate to wash. It also drains but doesn't spin when we set the dial to that
Your agitator pindle. has come loose From the spline. Try to lift up on the agitator. If it lifts off the spindle easily then it has worn out the spline. That is what connects the agitator to the s
Feb 06, 2013 | GE Profile WPRE6100G Top Load Washer
GE WWSE5200B1WW Top Load washer will not fill or agitate
Hi Scoti
I would start with water level pressure switch. It regulates how much water goes into washer and also stops overfilling..It may be defective and thinks washer is already full( hence no water and automatic drain spin) P#WH12X10093
Second thing to try is unplugging the washer for 15 min and letting all the voltage leave the control board. At this time you will reset the washer to default factory settings in case there was a computer glitch..
Good Luck
Jul 04, 2017 | GE Washing Machines
GE washer model WJRE5550K2WW - will fill water and drain but does not agitate and spin.
It new to me I am working on a GE washer model wjre5550k2ww it fill but not washing I can put it into the spin and it release the water but do not spin
Jan 05, 2011 | Washing Machines
I have a GE washer model # WHDRR418GWW. It is about 19 months old. It stopped agitating and spinning. It will fill with water and the timer/knob will go thru the cycles. But when it reaches the washing...
You have what is called "agitating dogs" there are usually 4 of them at the bottom of the agitator. They have small grippers which lock onto the agitator and agitates. If the washer is ever overfilled or over time filled to heavy this will wear down the nylon teeth on the "dogs". The top of the agitator will spin off, you will see a bolt inside at the bottom, remove bolt and the agitator will pull out. Google "agitating dogs on washer. It will give you pictures for a better understanding. If the belt was broken the washer would not drain, because the belt turns the pump. These dogs are about $5 and honestly easy to install. Good Luck.
Dec 04, 2010 | GE WHDRR418GWW 35 cu. ft. Washer
Washer will not agitate but fills/drains/spins
Could be related to pressure switch which measures the amount of water in tub. Does it fill and then just sit there?
Nov 13, 2009 | GE 3.2 Cu. Ft. 6-Cycle Super Capacity...
GE Washer WJSR2080V3WW will fill, spin and drain but not agitate.
The problem is the agitator coupler (about $ 7.00) simply pull straight up on the agitator - Give it a good tug. take the one bolt holding the coupler off - pull straight off. Replace the coupler and bolt (they are sold together). Line the agitator lines up with the coupler lines - when they line up it should go all the way down and snap back into place. and your done.
Sep 01, 2009 | GE WJSR2080V
Washing Machines Logo
69 people viewed this question
Top Washing Machines Experts
