Question about Amana Refrigerators
Why is my side by side amana fridge freezing everything in the fridge
    Top Expert:
  • Amana Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Dec 08, 2012
  • 2 more comments
  • simon Dec 08, 2012
    model # is afd2535deb, serial # is 13933957jr. Amana 25 cuft. french door freezer bottom. Everything keeps freezing right now I turned the fridge down to 1 and freezer down to 2. They recommend to keep at a 4. 7 is the coldest.
  • Richard Roth
    Richard Roth Dec 08, 2012
    You will need to replace the damper assembly. It is stuck open. Here is the part to order.http://bit.ly/QPOZii
    Ok thank you so much, Do you think I can replace it?
  • Richard Roth
    Yes, it is easy to replace. The link I gave you is a great supplier and has a 365 day, any reason, any return policy also.
ohms
  • 1879 Answers
SOURCE: My fridge side is freezing
Means only one thing, the thermostat control is broken.Have it replaced.
Posted on Aug 23, 2008
Techsim
  • 59 Answers
SOURCE: Amana SxS fridge not cooling or freezing
You have a sealed system problem. There is either a small leak or a restriction somewhere in the tubing. This isn't something you could've caused so don't worry about that. Unfortunately this isn't something you can fix yourself either. You require a certified refrigeration technician to fix this problem.
Posted on Nov 03, 2008
  • 25 Answers
SOURCE: Everything in Fridge side is freezing
your thermostat is probably defective. is an electronic or mechanical thermostat? there is a website called repairclinic.com. where you can enter your model number and get tech. help along with part #'s., its a very good website
Posted on May 08, 2009
Sea Breeze
  • 4654 Answers
SOURCE: everything in fridge freezes intermittently
Your vent has and electronic vent controlled by a setting on the control board. The electronic vent or circuit board are most likely the reason for the problem.
I will help you if you want, Sea Breeze
Posted on Jun 30, 2009
  • 52 Answers
SOURCE: Side by side Amana freezer/fridge. When you close
Possibly need the hinges adjusted.
Posted on Jul 15, 2009
Fridge is freezing everything
Check the top of the inside of the fridge. There is usually a flap door mechanism that sometimes falls off or sticks. This regulates the temp in the fridge.
Jan 29, 2014 | Amana ABB2524DE Bottom Freezer...
Amana ABB2224DES fridge freezes everything in the main compartment (not just the freezer). Doesn't matter what the level setting is at.
Sounds like your Temperature Control Sensor has gone bad. Could also be that the door on the duct from the freezer to the fridge is stuck open due to a bad solenoid there.
Jan 21, 2011 | Amana ABB2224DES Stainless Steel Bottom...
Amana fridge (mod #sxd22s2) is freezing foods on bottom level- dial turned to lowest setting & temp. is 28 to 32 degs.at bottom of fridge.
seeing that 32 is freezing point of water,its not suprising that food is freezing.it should be 38f or +3c.when was the last time you did a FULL defrost(NO HAIRDRYERS PLEASE).ALSO CHECK DOOR SEALS ARE TIGHT ALL ROUND.
Nov 27, 2010 | Amana 22.6 cu. ft. Side-By-Side...
My freezer side isn't freezing. fridge side seems to be working
If it worked fine to them, look at the heating and cooling C. in the back of the frig. Depending on how you transported it and how many bumbs you hit could of damanged them
Apr 03, 2010 | Amana SXD524VW Side by Side Refrigerator
Water reservoir in bottom back of frig keeps freezing up.
Too cold in fridge if it is freezing is your milk or other items freezing. Check temp in fridge with a good thermometer.
Nov 13, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana 'side by side not freezing slightly cool
sounds like you have a restriction in your filter drier. or you could be low on freon. both sealed system issues. you need an appliance tech to check your cooling system
Apr 12, 2009 | Amana ARS2464B Side by Side Refrigerator
Amana side by side
your thermostat in the frig is bad,you need to pull it and checkit with an omhs meter,let me know what you find-mike
Oct 15, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Amana fridge freezer
Replace your thermostat, aka cold control.
Jun 13, 2008 | Amana SXD524VW Side by Side Refrigerator
Refrigerators Logo
43 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
