Paraglow heater radient 40 giving off stronger fumes than usual
    Top Expert:
  • 14,553 Answers
Time to disconnect and have it looked at or replaced.
Posted on Dec 07, 2012
2 Suggested Answers
  • 4736 Answers
SOURCE: how to locate paraglow radiant 40 user manual on
Toyo Stoves, Kero Stoves & Paraglow Radiant Stoves are almost identical. Actually, I think one manufacturer makes all three. The link below has about 70 Owners Manuals in pdf formats that you can download and print. Look for Radiant 40, there are 3 listings for that model number. Look at all three for the one that matches your model Paraglow.
http://www.toyotomiusa.com/ownersManuals_portableHeaters.php
Hope this helps you. Please let me know.
Posted on Mar 16, 2011
Testimonial: " thank you for feedback and link, it was extremely useful. Kind regards. "
Fumes smell from gas heater
Open a window fast, carbon monoxide poisoning could cause death, and that has no smell ! are you getting headaches?? Contact manufacturer, they usually have a good warrenty. You must vent out the exhaust!!
Mar 04, 2015 | DeLonghi Heating & Cooling
I recently purchased a Holmes HQH319 heater. I want to use it in a room with tropical birds. Birds are very sensitive to chemical fumes. Is there any Teflon or other coatings on this heater that that may...
You would have to contact the makers of the heater to give you a clear answer on that , most heaters smell when first put on from new and you would have to burn this off first ,
Oct 24, 2012 | Holmes Products HQH319-U Compact Heater
How to locate paraglow radiant 40 user manual on line
Mar 15, 2011 | Heating & Cooling
Wr1589@bellsouth.neta five radient vanguard has a poping action on the top of one radients. I assume it is cracked, Can this radient be replaced or repaired?
Try cleaning first. Go to walmark and buy a can of air ( use to clean computer boards) and blow out each rack and see if that don't stop it.
Jan 22, 2011 | Vanguard International Infra Red - Medium...
Does the air intake pipe for a Goodman heater need to run outside
no both to go outside if you had fumes problem you would have fumes inside your house just example but the answer is no
Apr 10, 2010 | Goodman GMS90703BXA Heater
Reddy heater R100B gives of fumes when i use it
Not familiar with the R100B unit. Is it kerosene, propane or something else. Anytime a combustible heater gives off fumes it is not burning the fuel completely. This could be clogged filters, wrong fuel ratio or something else. Send me more info and I will try to solve your problem.
hardrocko
Jan 31, 2010 | Reddy Heating & Cooling
Radiator coolant fumes inside cabin
There is a chance you may have an engine bay coolant leak and the fumes are being drawn in through the heater ductwork so verify that first.
But....
Coolant fumes inside usually come from a leaking heater core. The heater core is like a small radiator inside your vehicle that gives off heat.
Problems like this arise from coolant that has not been flushed and creates an electrolysis that eats away at the material causing a leak.
This is not a job for a do it yourself guy(or girl). A pro could easily spend 5 to 7 hours changing this one.
Make sure whoever does this repair flushes the system.
Nov 04, 2009 | 2000 Ford Expedition
Back flow of fumes
your on demand water heater is supposed to be on a seperate vent, directly outside,and not closer then 60 inches from any other vent, the on demand pulls cold air in on the outer side of the vent and blows the hot air out the center of the flue
May 25, 2009 | RTO X-40 High Output On-Demand water...
Gas smell during startup of GE hot water heater
yes, provided there is no excessive build up. The gas and air mix must be right before the mixture will ignit. a household stove will do this each time it's turned on. That's why yhe igniter sparkk hits about three times before it lights. proper venting will confine any fumes to the cimbustion chamber to be carried out the exhaust. If the odor is strong then have the appliance checked for safety sake.
May 02, 2009 | General Electric GE SmartWater Household...
Fumes
Generally a kerosene heater will put out a strong smell for a few minutes after it is first lit, and for a few minutes after you put it out. Generally, it will be much stronger after it's extinguished. I usually extinguish mine and immediately set it out on the concrete porch to keep the smell out of the house.
Opening a window for a few minutes right after lighting the heater will help with the fumes at startup.
If your heater is constantly putting off fumes, even after burning for a little while, then it may be time to burn the wick dry. This should be done every few months anyway as general maintenance.
First, siphon all the fuel from the tank. You will need to disassemble the heater and gain access to the top of the wick. Raise the wick to it's highest point and use your fingers or a flat nosed pair of pliers to break up the hard black tar coating on the top of the wick. The smaller you can break the coating, the faster it will burn off. Once thats done, reassemble your heater, raise the wick to it's highest point and light it. It will probably burn for an hour or two because it will first burn all of the fuel soaked up in your wick, but then it will burn off the tar. Finally, it will go out.
After this, you should be ok, to refill your heater and relight as normal.
If you find when you disassemble it that the wick has a hard tar ring down inside, you may have a hard time breaking that up and cleaning it. It is possible... But I would probably just replace the wick.
Nov 21, 2008 | Corona 23-DK Compact Heater
Heating & Cooling Logo
63 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
