Question about Interactive Health Ijoy 130 Massage Chair
Where can I get a slip cover for the Ijoy
Its all peeling off on the seat. I saw a cover for back rest but I need a cover for seat area.
Replacement Upholstery
I have the same problem. Did you ever find something?
Apr 29, 2013 | Interactive Health Ijoy 130 Massage Chair
I have a 2008 Kawasaki Vulcan Nomad 1600 with 35,000 Kms or 21,800 miles. It is stored im my heated garage for the winter. I usually start it up once or twice a week. I tried to put it into gear and it...
Instructions
    • 1
      Unscrew the passenger seat\'s mounting bolt, positioned on
      the rear of the seat, using a socket wrench and a 10 mm socket. Lift the
      passenger seat up and away from the rider\'s seat.
    • 2
      Flip the passenger seat upside down and place it on a clean
      work area. Pry out the seat cover\'s staples from the bottom of the seat
      pan with a small pry bar or staple puller. Pull off the vinyl cover and
      remove the foam from the seat pan.
    • 3
      Flip the seat pan over. Place the Utopia back rest bar over
      the top of the seat pan, following the contours of seat pan. Center the
      bar in the middle of the pan, then mark the location of the bar\'s
      mounting holes on the seat pan with a permanent marker. Remove the back
      rest bar.
    • 4
      Drill two holes into the seat pan at the marked locations,
      using an electric drill and a 9/32-inch drill bit. Place the back rest
      bar onto the seat pan. Screw the kit\'s bolts and lock washers through
      the bottom of the pan and into the back rest bar. Tighten the bolts with
      a 10 mm socket and a socket wrench.
    • 5
      Lay the seat\'s foam next to the seat pan. Mark the
      approximate location of the back rest bar\'s protruding neck at the front
      of the seat onto the foam with a permanent marker. Cut a slit into the
      foam at the marked area, using a sharp knife. Place the foam over the
      seat pan and push the bar\'s neck through the foam\'s newly cut slit.
    • 6
      Place the vinyl cover over the seat foam and pan. Pull the
      cover tight around the sides of the seat and staple it into place, using
      a heavy-duty staple gun. Cut a slit into the seat cover with a razor to
      allow the back rest bar\'s neck to extend outward. Remove the paper
      backing from the plastic boot included with the back rest kit. Slide the
      boot over the bar\'s neck and hold it firmly in place for 30 seconds.
    • 7
      Reinstall the passenger seat on the motorcycle and tighten
      its bolt with a 10 mm socket. Place the back rest over the bar\'s neck on
      the passenger seat. Slip a bolt through the backrest\'s mounting holes
      and into the tube on the bar\'s neck. Loosely screw a nut onto the end of
      the bolt. Adjust the angle of the back rest, then tighten the bolt and
      nut using a 10 mm socket and a 10 mm wrench.
Jan 17, 2013 | 2008 kawasaki Vulcan 1600 Nomad
How to remove a back seat from 02 toyota avensis
Hi, peel the cover from around the seat frame so that the shoulder strap hold the cover on to the seat.
Extend the set belts to their maximum length and recline the seat as far as possible.
Looking at the seat from the front, put your hand in the gap between the reat of the seat (bit that reclines) and the fromt of the fixed base (by the red dome and the instructions).
On the bit of the seat that reclines there is a 'door' that opens to reveal a metal clasp that the ends of the shoulder straps fix to at the top and the ****** belt at the bottom.
Unhook the looks from the shoulder straps from the metal clasp.
Pull the shoulder straps through the back of the seat upright. You can now pull them through the cover which is free for you to wash.
Thank you.
Jun 06, 2012 | Cars & Trucks
Hi! I have the ijoy and the percussion, kneeding and compression doesnt work. Any sugesstions? The lights on the control pad seem to works and i do hear some clicking in the chair when i press the buttons....
THE DRIVE GEAR IS BROKEN SAME PROBLE IM HAVING LOOKING FOR PARTS HTT WILL ONLY SALE ME THE WHOLE BACK REST FOR THE CHAIR WHEN ALL I NEED IS A $5.00 GEAR GOOD LUCK
Sep 06, 2010 | Human Touch Ijoy 100 Robotic Massage Chair...
We need to remove the drives side head rest to install a seat cover, but we cannot figure out how to remove the head rest. How do you remove the driver's side head rest?
Head Restraints Removal
  1. Unscrew front seat head rest guide rod retainers (610A18) .
  1. Pull up on front seat back head restraint (611A08) . Compress foam in area of front seat head rest guide rod sleeves (610A16) .
  1. Remove front seat back head restraint positioning springs. Pull front seat back head restraint up and out.
Installation
  1. Slide front seat head rest guide rod retainers onto front seat back head restraint posts.
  1. Compress foam in front seat head rest guide rod sleeve area. Install positioning springs on front seat head rest guide rod sleeves .
  1. Insert front seat back head restraint posts (notches on posts facing rearward) into front seat head rest guide rod sleeves and push down to engage positioning spring.
  1. NOTE: Front seat back head restraint must operate smoothly throughout its range of travel, must remain in any fixed position, and must not be freely removable from the seat back. If any of these conditions are not met, check for proper installation of positioning spring onto front seat head rest guide rod sleeve .
    Tighten front seat head rest guide rod retainers onto front seat head rest guide rod sleeves .
  1. Adjust front seat back head restraint by applying hand pressure, either up or down, to center area of front seat back head restraint .
Aug 21, 2010 | 1998 Ford Taurus
The seat heater light comes on but can not be shut off and the seats do not heat
I had a simular problem, only it was on the driver's side only. If you push the button multiple times, it sometimes would go off.
To fix mine, I had to peel back the leather seat cover. There was a white pad with the heating elements (wires) going through it. I saw a dark brown spot where the wire got too hot and had broken. I pulled the wires left closer together and soldered them together. Then put the seat cover back on.
It has now worked for over a year like this.
If you are good at soldering, you may be able to fix it yourself (assuming this is the problem).
Oct 17, 2009 | 2003 Buick LeSabre
How do you remove the headrest on a 1996 ford crown victoria?
Head Restraints Each front seat is equipped with dual-post design front seat back head restraint (611A08). The front seat back head restraint is installed as follows:
  • It travels on dual posts which have notches to engage a spring-loaded catch in the guide.
  • The front seat back spring assembly retains the front seat head rest guide rod sleeve (610A16).
  • The front seat back head restraint is adjustable from its normal position to a raised position of approximately 25 mm (1 inch).
  • Pull up on the front seat back head restraint to raise it. Pushing down will return it to its normal position.
Removal
  1. Unscrew front seat head rest guide rod retainers (610A18).
  1. Pull up on front seat back head restraint (611A08). Compress foam in area of front seat head rest guide rod sleeves (610A16).
Installation
  1. Compress foam in front seat head rest guide rod sleeve area. Install positioning springs on front seat head rest guide rod sleeves.
  1. Tighten front seat head rest guide rod retainers onto front seat head rest guide rod sleeves.
  1. NOTE: Front seat back head restraint must operate smoothly throughout its range of travel, must remain in any fixed position, and must not be freely removable from the seat back. If any of these conditions are not met, check for proper installation of positioning spring onto front seat head rest guide rod sleeve.
    Adjust front seat back head restraint by applying hand pressure, either up or down, to center area of front seat back head restraint.
Mar 01, 2009 | 1996 Ford Crown Victoria
Interactive Health Ijoy 130 Massage Chair Logo
379 people viewed this question
Top Interactive Health Furniture Experts
Jason Morris
Tom Chichester
Are you an Interactive Health Furniture Expert? Answer questions, earn points and help others
